I had a problem after the upgrade.
The page took a long time to come and the top of me was gone.
After upgrading to Discourse 2.6.0.beta2, user Bank_Live experienced a loading error with posts failing to display properly. jomaxro suggested checking third-party plugins, as the issue likely stems from a conflicting plugin. neounix confirmed the problem was resolved when plugins were disabled and recommended isolating the faulty plugin by enabling them one at a time. Stephen advised testing upgrades on a copy of the site first, especially given the 17 installed plugins. Bank_Live confirmed the issue was resolved after removing the âdiscourse-newâ plugin.
Youâll need to check your third-party plugins. When I load the page with non-official plugins disabled, it works.
https://eleceasy.com/t/mcu-esp-8266-reset-code/2081?safe_mode=only_official
Hi @Bank_Live
Using the âturn off the pluginsâ method as described by @jomaxro, I also checked your site for you and the posts displayed properly with plugins disabled.
https://eleceasy.com/t/mcu-esp-8266-reset-code/2081?safe_mode=only_official 2
Normally, we need to disable plugins, one-at-a-time, until we find the offending plugin.
So, your next step is to either disable all the plugins from your admin panel and see if that fixes the problem and then turn them back on, one-at-a-time, until it breaks. This will isolate which plugin is causing the error.
Or you can go the other direction, and turn them off, one-step-at-a-time, until the problem resolves, isolating the problem in the other direction.
Then, when you isolate the offending plugin, you can contact the plugin owner and let them know.
Hope this helps.
Also @Bank_Live, you might check your theme components; as this JS error may be related to a theme component.
I would always recommend upgrading a copy of your site before upgrading the live copy for this very reason.
You have 17 plugins installed, including a number of third-party plugins. Itâs quite likely upgrades will trip you up periodically if you arenât doing any validation beforehand.
Yes i remove discourse-new after my page normal.
