Check email of a flagger without a log note
I ran into a little glitch the other day. The system is designed so that if a mod or an admin.checks somebody’s email, a note is left on the staff action log. There is a systematic way to circumvent that, though, when they flag a post.
You just click their avatar on the active flags listing (/admin/flags/active). You are taken to their admin/users page, where their email is visible instead of being hidden like it is when you enter the same page in a more usual way.
I can’t check if it works that way on Meta or try.discourse.org obviously, but I am quite confident it does. Hence Contribute > Bug instead of Support.
Fixed via:
https://github.com/discourse/discourse/commit/5d9d2cf2871ce127c207f2efa192c2eb2eeb35f2
Thanks for reporting this issue @rizka :thumbsup:
