imrehg
(Gergely Imreh)
2 Octubre, 2017 08:25
1
We are using Discourse-hosted Discourse, and found that the Data Explorer plugin errors out when trying to export the results in CSV format.
We do a query, if we select “download results” in JSON it works, if in CSV, then got a HTTP 500 result…
Any idea what might be going on? Is it a known issue?
1 me gusta
How many rows / results are you attempting to export as CSV?
imrehg
(Gergely Imreh)
2 Octubre, 2017 10:38
3
Even with a single row we get an error (e.g. running a query with SELECT .... LIMIT 1).
I wonder if the othet CSV issue reported, CSV export of reports fails is related.
dax
(Daniela)
2 Octubre, 2017 10:55
4
I also believe that they are related.
Can you check the /logs page to see if you have the same error?
imrehg
(Gergely Imreh)
2 Octubre, 2017 12:17
6
Checked, and no new log shows up in the /logs when trying to do the Data Exporter. Though have tried to do the “reports” export as mentioned in the other thread, and it fails the same way (no logs then either). So definitely feels related (and that thread is probably duplicate of this one, as this was filed earlier).
jomaxro
(Joshua Rosenfeld)
2 Octubre, 2017 16:29
7
Looks like @techAPJ resolved this. Try updating to latest and retest?
Fixed via:
Thanks for reporting this issue @AxelN
1 me gusta
jomaxro
(Joshua Rosenfeld)
3 Octubre, 2017 02:31
9
pfaffman:
Has it been pushed yet?
It has now. Apologies, @imrehg , I glossed over that we hosted you.
3 Me gusta
pfaffman
(Jay Pfaffman)
3 Octubre, 2017 03:40
10
Proof that you’re trying to help everyone, not just customers!
3 Me gusta
imrehg
(Gergely Imreh)
3 Octubre, 2017 11:00
11
Hey, tried the other linked issue, that one was fixed (now it’s .csv.gz that’s downloaded?). My original report, of the Data Explorer does not export to CSV is still erroring out the same way, so this issue is still open.
2 Me gusta
techAPJ
(Arpit Jalan)
3 Octubre, 2017 17:57
13
I can repro this issue here on meta. Added on my list to fix.
4 Me gusta
techAPJ
(Arpit Jalan)
4 Octubre, 2017 12:24
14
4 Me gusta
techAPJ
(Arpit Jalan)
Cerrado
5 Octubre, 2017 12:30
15
This topic was automatically closed after 24 hours. New replies are no longer allowed.
