Sorry, last question on this: so if I want to deliver a better, more nuanced prompt to the LLM, I’m using “system.tagging” and not “prompt.tag”, correct?
Heads up, about 5 hours ago my site became inoperable due to a 500 error again. I had made no changes, using GPT 4. Could be that @RGJ pushed an update (but unlikely, since I didn’t see a note). Turned off the plugin, and the error resolved.
Only AI-related 500 error what I get, started yesterday, is (or was, I have not examined further yet) automatic alt. Why I didn’t start digging it deeper? Because error 500 comes really often from OpenAI.
It seems like the plugin on your site regressed to an older version somehow.
@ncaming215 My apologies, this is most likely our fault. I’ve put it back on 0.2.2 now and going to find out what went wrong. For now @merefield no need to worry.
Looks like you are trying to enter the database in the “web only” container?
You may need to enter the data container instead in your case
The good news is that judging by this this may now be unnecessary (at least for tests-passed) as I believe core has finally upgraded the vector extension via their standard scripting, so you may only have to fully rebuild.
