Bloqueio de Categoria de Discurso
This plugin allows you to restrict access to topic pages in a category. Topic titles will still show up in topic lists, search, user activity & digest emails. This is a great way to advertise the activity in a “members-only” category, which may charge for access.
It IS NOT designed to keep the contents of the category 100% private - if someone is determined enough they will be able to piece together the content from search results.
Each category has a couple of new settings in the Security tab:
“Locked down” topics will show a (configurable) icon in the topic list if the user does not have access:
Once clicked, unauthorised users will be redirected to a defined URL (e.g. your payment gateway). This link can be internal or external. The static pages plugin works great for this.
Plugin repository: https://github.com/paviliondev/discourse-category-lockdown
Thanks to @DiscourseMetrics.com for funding the development of this plugin.
Authored by @david
Now maintained by Pavilion
51 curtidas
Login required to see topic info
Partial view of hidden content
Private category
Making topics private and visible for not logged in users
Is this new category access a feasible feature? "see topic title"
How do I allow people to see categories but not access topics?
Permissions for users not logged in?
Prompt subscription to groups for non members
Only register users can see more
Premium Categories Visibility
Update and add features to the Category Lockdown plugin
Asking for access to a private category
Discourse Memberful integration
Share single topics / categories with unregistered users
Enabling category previews for restricted paid access categories
Preventing non-registered users from viewing posts
Allow setting visibility of Event attendees
Ability to show topics in a category but not open?
Guest Gate Theme Component
Major upgrade -- best practices?
Private Topics Plugin
Charge one-time fee to post in a category?
Show topic title even if you don't have access
Partial view of "private" content
Can't load topics
Public community, private community, or a mix? (context: migrating from Facebook)
Latest topics on homepage with only members to read in detail?
Private discourse and crawling, can it happen?
Chat compatibility with the category lockdown plugin
Paid Groups
Paid Groups
Paid Groups
I need a theme to promote some hidden categories
Make chats visible to "reply"
Gated Topics in Category
Monetisation: how to partially hide posts to non-members?
Allow to hide part of a post content with "login to see" or "reply to see" function
just checked in on this plugin (which looks exactly like what i’ve been looking for) and it looks like the build is failing. anyone using in production?
O que deve ser colocado para Grupos?
Só uma curiosidade: por que este plugin está em #plugin:broken-plugin? Estamos usando sem nenhum problema.
1 curtida
Não tenho certeza, mas @david provavelmente fez isso por um motivo em meados de 2019?
Lembram de 2019? :woozy_face:
1 curtida
Hmm, acho que movi porque
Vou mover de volta para #customização:plugin, já que parece estar funcionando :slight_smile:
Não uso nem mantenho esse plugin mais, e ele não é oficial. Se alguém quiser adotá-lo, me avise.
8 curtidas
Estou disposto a assumi-lo, pois estou fazendo algum trabalho para @davidkingham sobre isso.
9 curtidas
Ótimo, obrigado por assumir isso @fzngagan. Reatribuí o OP a você e iniciei a transferência no GitHub.
5 curtidas
Obrigado por tudo isso, David. :slight_smile:
1 curtida
Acabei de instalar este plugin e notei que ele permite que os usuários criem novos tópicos em uma categoria bloqueada. Isso pode ser corrigido?
1 curtida
Você precisa alterar as configurações de segurança da sua categoria para que todos possam ‘ver’, mas apenas os membros do grupo correto possam criar tópicos. Veja como a minha está configurada:
2 curtidas
Ah, certo, então eu mudo “todos” para ver apenas e depois concedo permissões completas ao meu grupo “membro pago”. Entendi. Obrigado!
5 curtidas
Com o plugin Discourse Subscriptions avançando em desenvolvimento, adoraria ver uma integração estreita com o plugin Category Lockdown.
Ao testar agora com a versão mais recente, um usuário que não é membro do grupo especificado consegue ver a categoria e as postagens nela.
O plugin está ativo e a configuração de segurança da categoria é esta:
Se eu remover a configuração todos podem ver, a categoria deixa de ser visível para o usuário que não é membro. Portanto, o comportamento é como se o plugin Category Lockdown não estivesse ativo.
Não há erros no log. Será que estou perdendo alguma outra configuração para fazer isso funcionar?
4 curtidas
Sim, isso está correto, porque:
2 curtidas
Quais são as restrições de entrada para o grupo current_member?
Estou com um fórum executando ambos os plugins; funcionou bem com um grupo privado na última verificação que fiz.
2 curtidas
Ugh! :man_facepalming: Eu estava ignorando o óbvio e não tinha isso marcado na parte inferior das configurações da categoria:
Tudo certo!
3 curtidas
O plugin de assinaturas já deve estar fazendo isso. Ele está intimamente integrado aos grupos do Discourse, que por sua vez estão intimamente integrados às configurações de segurança de categorias. :wink:
2 curtidas
Estava procurando por um plugin que faça quase exatamente isso (e não percebi que ele já existia!). Poderia esclarecer o que essa afirmação significa? Apenas que o tópico será indexado no Google?
Se um usuário que não está no grupo ou que não está logado navegar até o tópico, ele sempre será redirecionado para o gateway de pagamento (ou qualquer outro link), certo?
1 curtida
Sim, mas a entrada do tópico e alguns trechos do conteúdo aparecem nos resultados de pesquisa. Se isso for aceitável para você, então está tudo resolvido.
Recentemente, adicionei um recurso para permitir redirecionamentos específicos por categoria.
Se você deseja algo mais abrangente, pode consultar Discourse Subscriptions Plugin
3 curtidas
Isso parece mais ideal para o meu caso do que as assinaturas do Discourse, pois estou usando o WordPress e o SSO para a associação. Vou experimentar.
1 curtida
