Discourse forum laadt helemaal geen pagina's
The user tpglitch reports that their Discourse forum at https://study.tpglit.ch won’t load in Chrome, even after rebuilding and restarting the server. Firepup650 confirms it loads for them. tpglitch discovers the issue occurs only after logging in and finds that accessing the site via /?safe_mode=no_themes,no_plugins resolves it Moin suggests using safe mode to isolate the problem. tpglitch identifies an official plugin as the culprit and asks if a rebuild updates plugins. Firepup650 recommends checking console logs and testing safe mode options individually to pinpoint the failing plugin. tpglitch confirms they are already rebuilding the forum and notes a past memory issue with the “solved” plugin.
My forum at the above URL in Discourse wont load whatsoever for me in my Chrome browser.
Not sure why. Things I’ve tried
  • Rebuilding Discourse
  • Restarting the server
Loads for me, I get the login page.
AYYY ITS FIREPUP!
Interesting.. Is it possible to like clear Chrome cache or something to fix it?
I’m not sure, as I’m not sure what the issue is.
Odd.. Getting the same with the downloaded PWA
Hi Tyler,
Does it happen if you enable the safe mode?
I cannot enable safe mode, it does not load
Also I noticed after clearing cache, that this problem only occurs upon logging in.
Did you try the tip?
This works! Now, how can I diagnose what went wrong?
I’d try the parts of safe mode individually:
  1. Plugins: /?safe_mode=no_plugins does it break?
  2. Themes: /?safe_mode=no_themes does it break?
  3. Unofficial Plugins: /?safe_mode=no_unofficial_plugins does it break?
If it breaks on themes and none of the other ones, it’s an unofficial plugin, conversely, if it breaks on unofficial Plugins and themes it’s an official plugin. Otherwise, it’s a theme bug.
Ok. I now know that it is an official plugin that is failing. I think I heard about it having some troubles recently :laughing:. If I rebuild Discourse does it rebuild all plugins with latest build?
If possible, can you check console logs? That should help pinpoint which plugin is failing.
Also yes, a rebuild should upgrade plugins, but knowing which one causes it would help too.
I cannot on school devices sorry, but I will try rebuilding the forum
I think when I rebuilt last, there was a memory issue happening with solved.
Does the forum use docker? If so, you could try the admin upgrade page while in safe mode. (Thus avoiding the rebuild and downtime it mandates)
:laughing: Shoot! I didn’t think about that. I am already rebuilding it so I will just do that (plus the forum is already technically down)
