Testing out with the default wordpress theme twenty fifteen and it doesn’t display anything. Switch to old default theme and it displays “Add your comments”
Anyone else having this problem? What files need modification to allow it to work with twenty fifteen theme?
Tried two more themes and one works and the other didn’t. What is the WordPress plugin looking for specifically? Any hints as to which file may need tweaking to support more themes?
The setting for Discourse is already enabled since commenting works with the older WordPress default theme. It’s only a problem when I switch to the newest default theme. Will test with another install.
