DiscourseHub notification menu blocked by the user interface (iPad)
A user reports that the notification menu in the DiscourseHub app is partially blocked by the top user interface on an iPad mini 5th generation, making some menu elements and notifications inaccessible. This issue occurs specifically on the “new” forum type and is reproducible on the Meta forum. The problem appears to be isolated to the DiscourseHub app, as it does not occur in Safari. Other users confirm the issue is likely specific to the iPad mini, with one noting that the app may no longer support older iPad mini models. twofoursixeight provided images demonstrating the issue, and JammyDodger and Stephen noted the issue is not present on other devices like the iPad Pro. Decorbuz suggested testing in Safari, which confirmed the issue is app-specific.
When opening my notifications, it is slightly blocked by the user interface on the top. It is kind of annoying because you cannot see some of the menu elements or the notifications.
This only applies to the “new” forum type.
Images:
Can you replicate this on Meta? I’ve had a try with DiscourseHub Android and iPhone and the menu appears fine to me.
I can reproduce this on the Meta forum.
That looks like you may be using an ipad or tablet?
Correct. This is an iPad mini 5th generation tablet.
This may be specific to the iPad mini, I can’t reproduce it here on an iPad Pro.
Can you try to reproduce the issue in Safari?
No issue here in Safari:
Okay, so it’s likely an issue that’s specific to the Discourse Hub application.
I have an iPad mini 2 that I could try to reproduce the issue with, but it’s packed away in a box somewhere. Besides, I’m not even sure the Discourse Hub application still supports it.
