Local de acesso ao tópico fechado
It might make sense to go into a closed read topic (ones without a close comment maybe?) at the last written post instead of at the close notification.
It’s a little annoying having it load with only the close notification at the very top of the screen and having to scroll up to see the content again.
3 curtidas
I am not following what you mean here. Do you mean “closed”? Screenshot?
2 curtidas
Yeah I meant closed - lemme fix the OP.
I’m not really following. Unless you had a previous read position, you’d enter at the top.
2 curtidas
I’m saying that I think that even after someone reads a whole topic - if they go back to it, it might be a bit better to go in at
vs. the above
Just so there’s some content on entry vs. just a closed message.
3 curtidas
Ooh yeah another reason is that in the former case you need to scroll up to even access the topic scrollbar while in the latter it’s already just there.
I agree. It makes no sense to focus on the ‘Closed’ entry ever. Just default to visiting the last post before the closure.
This is especially evident when you do, for example, a pinned site announcement. The second time someone visits it they will move to see the Closed message. This is pointless. They surely will have wanted to revisit the main message.
1 curtida
I agree there is merit to this request, but I worry about adding complex logic to our “where should we scroll to” routines.
3 curtidas
Maybe have a setting that auto hides the lock/pin announcements? Been hiding them manually in the case @merefield described earlier with pinned/closed announcements.
Another thing that might help is moving the location of the topic timeline at the end of topics e.g.
