I get this error in /logs. Can I clean up the invalid record somehow?
Our forum is only 8 years old ![]()
Message
Job exception: PG::DatetimeFieldOverflow: ERROR: timestamp out of range: "2735882-02-03 08:00:19.479554 BC"
LINE 1: ...addresses"."action_type" = 1 AND (last_match_at < '2735882-0...
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-4.0.1/lib/patches/db/pg/alias_method.rb:109:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-4.0.1/lib/patches/db/pg/alias_method.rb:109:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:167:in `perform_query'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:556:in `block (2 levels) in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract_adapter.rb:1017:in `block in with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract_adapter.rb:986:in `with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:555:in `block in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract_adapter.rb:1137:in `log'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:554:in `raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:591:in `internal_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:547:in `internal_exec_query'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:693:in `select'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:73:in `select_all'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/query_cache.rb:262:in `select_all'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/querying.rb:68:in `_query_by_sql'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/relation.rb:1459:in `block (2 levels) in exec_main_query'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:416:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_handling.rb:312:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/relation.rb:1458:in `block in exec_main_query'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/relation.rb:1480:in `skip_query_cache_if_necessary'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/relation.rb:1442:in `exec_main_query'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/relation.rb:1420:in `block in exec_queries'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/relation.rb:1414:in `exec_queries'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/goldiloader-6.0.0/lib/goldiloader/active_record_patches.rb:40:in `exec_queries'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/relation.rb:1191:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/relation.rb:353:in `records'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/relation.rb:1000:in `destroy_all'
/var/www/discourse/app/jobs/scheduled/clean_up_unmatched_ips.rb:21:in `execute'
/var/www/discourse/app/jobs/base.rb:318:in `block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-7.0.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-7.0.0/lib/rails_multisite/connection_management.rb:17:in `with_connection'
/var/www/discourse/app/jobs/base.rb:305:in `block in perform'
/var/www/discourse/app/jobs/base.rb:301:in `each'
/var/www/discourse/app/jobs/base.rb:301:in `perform'
/var/www/discourse/app/jobs/base.rb:381:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_scheduler-0.18.0/lib/mini_scheduler/manager.rb:137:in `process_queue'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_scheduler-0.18.0/lib/mini_scheduler/manager.rb:77:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_scheduler-0.18.0/lib/mini_scheduler/manager.rb:63:in `block (2 levels) in ensure_worker_threads'
