Failed to Bootstrap after upgrade
After applying the latest set of patches I’m getting a bootstrap failure…
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1581 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
The logs show…
I, [2023-09-27T09:27:53.120283 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
Gem::LoadError: can't activate ffi-1.15.5, already activated ffi-1.16.2
/var/www/discourse/lib/plugin_gem.rb:25:in `load'
/var/www/discourse/lib/plugin/instance.rb:825:in `gem'
/var/www/discourse/plugins/discourse-migratepassword/plugin.rb:28:in `activate!'
/var/www/discourse/lib/plugin/instance.rb:722:in `instance_eval'
/var/www/discourse/lib/plugin/instance.rb:722:in `activate!'
/var/www/discourse/lib/discourse.rb:347:in `block in activate_plugins!'
/var/www/discourse/lib/discourse.rb:344:in `each'
/var/www/discourse/lib/discourse.rb:344:in `activate_plugins!'
/var/www/discourse/config/application.rb:227:in `block in <class:Application>'
/var/www/discourse/lib/plugin.rb:6:in `initialization_guard'
/var/www/discourse/config/application.rb:227:in `<class:Application>'
/var/www/discourse/config/application.rb:75:in `<module:Discourse>'
/var/www/discourse/config/application.rb:74:in `<top (required)>'
<internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:38:in `require'
/var/www/discourse/Rakefile:7:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
I’m currently trying various things to bring my forum back to life.
This appears to be related to the migratepassword plugin. I can rebuild the forum with all plugins disabled but I get the bootstrap failure if I try to rebuild with only the migratepassword plugin enabled.
I’ll add a little ping for @RGJ as he may know more. :crossed_fingers:
Yes, this broke yesterday due to an updated dependency in core, the PR is already on my to-do-list and will be available later today or tomorrow.
quick fixes:
Option 1 check out Discourse 91c94f which is the commit before the breaking change
Option 2 change gem 'ffi', '1.15.5', require: false in the plugin to gem 'ffi', '1.16.2', require: false
Not sure how to do either of those. I did try putting “version: 91c94f” into app.yml but that didn’t help so I probably did the wrong thing.
I’ll just run without the plugin until the PR is ready. The vast majority of my users have already migrated from their old passwords, but there are one or two ‘legacy users’ each week who surface again from a few years ago.
What are the cmd for this or where is the file located for me to change this?
in this case how would I do that in the console I mean, the cmd to execute
No reason to ask things twice, especially when I already said there would be a fix available soon.
The new version of discourse-migratepassword is available now.
Just rebuild.
Thanks for the fix Richard. Now rebuilt without errors :grinning:
im still having the same issue, and I don’t have discourse-migratepassword in my plugin
do you have discourse-migratepassword in your plugins? because I have tried rebuilding it and I’m still having the same issue.
es:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
2023-09-27 16:50:33.227 UTC [42] LOG:  received fast shutdown request
I, [2023-09-27T16:50:33.227763 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 111
111:signal-handler (1695833433) Received SIGTERM scheduling shutdown...
2023-09-27 16:50:33.252 UTC [42] LOG:  aborting any active transactions
2023-09-27 16:50:33.262 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2023-09-27 16:50:33.265 UTC [46] LOG:  shutting down
2023-09-27 16:50:33.282 UTC [42] LOG:  database system is shut down
111:M 27 Sep 2023 16:50:33.282 # User requested shutdown...
111:M 27 Sep 2023 16:50:33.283 * Saving the final RDB snapshot before exiting.
111:M 27 Sep 2023 16:50:33.295 * DB saved on disk
111:M 27 Sep 2023 16:50:33.296 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle config --local deployment true' failed with return #<Process::Status: pid 539 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle config --local deployment true'", "su discourse -c 'bundle config --local without \"development test\"'", "su discourse -c 'bundle install --retry 3 --jobs 4'"]}
92863be4bda311c642a83b1afd97e58a64e9044ea2dc0e23f245fafb086851f7
As he wrote he has.
If you don’t, maybe you continue in the topic you started and share the full error message
