How can I hide all subcategories from homepage?
Hello all,
i’am search for “how can i hide all subcategories from homepage”. I would like this to do because we have now over 50 subcategories, and it becomes very long to scroll down. Is there a way to hide this subcategories from homepage from on specific maincategorie?
3.1.0.beta2 is installed.
Found this
not tested, but i thing it does something different.
Very thanks and best Regards :slight_smile:
You are so disliking this answer, but you are asking wrong question. You are now trying to solve out an issue that came from your earlier acts and the real question should be:
If I don’t and can’t show sub-categories for users at their first navigation point, and sub-categories will be kind of hidden option, why I’m using sub-categories at all and should I ditch them and use tags instead.
Hi boopsy!
Yes, it’s certainly possible with CSS, to be added in your admin panel.
Customization → Theme → Edit CSS/HTML
From the category page:
.categories-list .subcategories {
     display: none;
Can you clarify this part?
Do you use subcategories boxes?
I mean the part directly on startpage. First have one categorie and after you can add subcategories to this “i say” maincategorie. You can see the subcategories under a maincategorie. With dots and the name. This is what i would hide, because it is to long.
After i click directly in a maincategorie, i would like to see alle subcategories there, so the default again.
tested, yes it works, but with this all subcategories are now hide.
You may want to look at this theme component.
I think it will.do what your looking for.
There are also site settings that affect how categories are displayed and othet Theme component like Modern Category Boxes.
I am running Discourse version 3.5.0.beta8-dev and I need to edit the CSS of the theme to test some small changes. How can I get access to the CSS. I found some guides but looks like for the previous web interface and does not match with the current version. Thanks for your help.
There should be a theme component that is specific to your Theme. Look for one with Snippets in the name.
Remote themes and default themes do not have the section for customizations. Instead, you can make the changes in a theme component which you add to the theme.
Thank you @Moin , you are the best !
I am trying to add some CSS code to hide the SUBCategory “Otros” (this is the slug: Otros-t) that have the same name in different parent categories. I will try to add a Component as you recommend with this code:
.category-list-item.category-Otros-t {
display: none !important;
Any advice..it is very wellcome.
Just to summarize, in my case I didn’t have to hide the category, we just moved the posts to other category and removed “problematic” category. Thanks again everyone.
