Hoe verifieer ik toegang tot mijn Mailjet inbox om op de admin-verificatielink te klikken?
Lampard_NK encountered issues verifying their Discourse admin account because they were using a custom domain email (lampardnk@lampardnk.xyz) that wasn’t receiving the verification email, despite setting it up with Mailjet. agungor suggested forwarding emails via Namecheap, which partially worked for test emails but not for Discourse’s verification email. merefield advised using a regular email like Gmail for admin verification, warning against overcomplicating with domain-specific addresses. Even after switching to Gmail, delivery still failed. merefield asked if DNS records (SPF/DKIM) and server ports (25/587) were properly configured — Lampard_NK confirmed they were, using 587 as recommended. merefield noted 587 may also be blocked and suggested checking with the VPS provider. Ultimately, Lampard_NK resolved the issue by changing the Discourse notification and admin email settings to their personal Gmail account, bypassing the custom domain email entirely. The root cause was likely email delivery restrictions or misconfiguration around custom domain emails, which are unnecessary for admin account management.
So I finished discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub until step 7. I can access the site. When I try step 8, I register the admin account but when it asks for me to confirm my email I don’t know how since my admin email is lampardnk@lampardnk.xyz, how do I open its inbox?? I added lampardnk@lampardnk.xyz as one of the sender emails on mailjet already but still doesnt work, please help, thank you.
It looks like your domain’s mail exchanger records currently point to Namecheap. If you do not already have a mailbox there, perhaps you can configure forwarding to get your emails in one of your existing email accounts.
Thank you for your help, this works BUT to an extent only. I can now use an alt gmail account to send to lampardnk@lampardnk.xyz and would receive that email in my main inbox nguyenkhackhanhlam@gmail.com after setting up a catch-all in namecheap.
However, I STILL can not receive the verification email from discourse. I tried discourse-doctor, the mail was sent successfully and the telnet test is successful, but I still can’t find the verification email even in spam inbox.
Please help, I can provide any extra information needed
Your admin account normally uses a ‘regular’ email account, eg gmail, yahoo, just like any other regular user account. Use that for password resets, email notifications and account verification of your admin user. Do not confuse that with site email contacts for third parties. That’s a special domain specific email address and is not usually used to manage a specific user account. Perhaps you can do it, but that’s kind of over complicating things, more fragile and is unnecessary.
Even when I use my @gmail.com account it still doesnt deliver
Have you validated your domain fully with Mailjet by adding the appropriate DNS records? (see Mailjet documentation) Have you opened the appropriate ports on your server? Sometimes SMTP ports are blocked until you validate your VPS service provider account with your government provided ID. (a measure to discourage spammers from jumping between services)
Yes, both SPF and DKIM records are correctly added. I used the ports that Mailjet specified (25 or 587 but I use 587 because they said 25 is sometimes blocked)
587 is often also blocked. Check with your VPS providers support team. There may be a GUI for the fire wall rules if you are lucky.
Sorry for being an idiot, I solved this by changing the discourse notification and admin email to my personal gmail
