Is there a way to see who changed topic category?
Is there a way to see which user changed the topic of a category? Several users may have permissions to do this, but which one actually did?
Unless an admin does a bulk recategorization, it would appear as an edit to the topic.
Here’s an example:
Thanks. I can see it in the front end, but do you know what the query to see it in the backend would look like?
If you are using the Data Explorer Plugin, you can use this query that I wrote a while ago
topics-that-changed-categories.dcquery.json (340 Bytes)
If staff check /admin/logs/staff_action_logs
