פופאפ כניסה לא מוצג
סיכום מבוסס בינה מלאכותית
Login popup not displaying issue
b.iyer is experiencing an issue where the login popup does not appear in their Discourse instance installed on Oracle Virtual Box with Ubuntu. They have followed the installation steps on https://meta.discourse.org/t/install-discourse-on-ubuntu-or-debian-for-development/14727 and have restored staging data.
twofoursixeight suggested checking the Docker error message, but b.iyer clarified that they are not using Docker. Instead, they are using a Ubuntu instance on Oracle VM.
isaac recommended trying to reproduce the issue in safe mode as described in https://meta.discourse.org/t/how-to-use-discourse-safe-mode/53504. b.iyer found the issue and is working on a solution.
Hello,
I have done following steps to install Discourse:
  1. install Ubuntu on Oracle Vitrual box.
  2. follow the steps given on URL: Install Discourse on Ubuntu or Debian for Development to install Discourse instance.
  3. install pgvector and enable in each discourse database.
  4. Run the discourse instance using bin/ember-cli -u.
  5. Discourse app is running on browser.
  6. restore staging data into development environment.
  7. using Ubuntu IP; requested for the site.
  8. Click on login button, no popup appears.
Can someone has any solution for this error?
Thank you.
Can you please provide the Docker error message? It will help the people here troubleshoot the issue. A console log is usually vague and may not show where the error is.
Hello,
I am not using Docker, My installation is on Oracle VM → Ubuntu instance.
Can you tell me, how can I check log using CLI; as I am not able to login into the System?
Thank you.
@b.iyer can you repro in safe mode?
Thank you. I got my issue and trying to fix it.
