joa
(Joachim)
1
My community has decided they want to only allow people to read the discussions if they registered.
Is there a global setting for it? I searched through the settings but didn’t find anything.
I‘m aware that I can configure the access levels for all categories and could set it to tl0, but
- that will make the Homepage and „latest“ just appear empty without explanation
- I can’t do it for the „Uncategorized“ category
- it’s difficult to do it for the „Meta“ category, as I‘d have to create a new category and move all existing topics.
bts
(Brendan Schlagel)
Yes I believe you’re looking for the setting called login required — that should do the trick globally, no category-specific access levels required!
ondrej
3
How about setting the forum (in the setup wizard) to private?
joa
(Joachim)
4
Is this the same as the login required setting?
joa
(Joachim)
5
Thank you, that’s what I was looking for but didn’t find it (searched for “registered“ instead of “login“)
joa
(Joachim)
6
Ok, that works great but is ugly. ^^
Is there a way to customize the Startpage to include a more welcoming Text/experience? not even the About-Us page is visible from the new startpage.
customize it here: admin -> customize -> text
login_required.welcome_message (or welcome_message_invite_only depending on how you set it up) is the message displayed.
