I keep getting this error, every time I run ./discourse-setup Any solution? (I added a dns A record that points to my VM’s ip).
Checking your domain name . . .
WARNING: Port 443 of computer does not appear to be accessible using hostname: forum.roblox-devs.com.
SUCCESS: A connection to port 80 succeeds!
This suggests that your DNS settings are correct,
but something is keeping traffic to port 443 from getting to your server.
Check your networking configuration to see that connections to port 443 are allowed.
The first thing to do is confirm that forum.roblox-devs.com resolves to the IP address of this server.
You usually do this at the same place you purchased the domain.
If you are sure that the IP address resolves correctly, it could be a firewall issue.
A web search for "open ports YOUR CLOUD SERVICE" might help.
This tool is designed only for the most standard installations. If you cannot resolve
the issue above, you will need to edit containers/app.yml yourself and then type
./launcher rebuild app
I’m sorry for the late reply,
Each time I run ./discourse-setup It shows me the following errors: WARNING: Port 443 of computer does not appear to be accessible using hostname: forum.roblox-devs.com. WARNING: Connection to http://forum.roblox-devs.com (port 80) also fails.
Is there any possible fix?
