هل التسجيلات مقتصرة على المدعوين فقط؟
Hi. I don’t want registrations to be possible from the main login page. I disabled new registrations, thinking that invites would still work. But they appear to be disabled also – the links get a “registration not permitted” error page. How can I permit invite-only registrations? Thanks.
Don’t disable allow new registrations. Doing so prevents all new registrations. Instead, enable invite only - which allows new registration by invite only.
Well, I had it half right. Invite-only checked, but also no registrations. Thanks!
This is also something you can easily change by re-running the setup wizard again at /wizard – it asks if you want a public or private site in one of the first steps.
