Configuration du domaine et des serveurs de noms DO
I’m setting up my forum but i was just wondering if i should use Digitalocean’s nameservers or not.
or should i only point my website to DO ipadress?
thanks in advance
Hi there,
It’s better to use Digital Ocean DNS than just using domain provider’s (ex., godaddy /namecheap) default DNS
  • Change Name servers at Domain Registrar (godaddy) to Digital Ocean Nameservers (ns1.digitalocean.com etc)
    Now you can manage DNS records at digital ocean
  • Add A record to point to Digital Ocean droplet IP (domain.com) in Digital Ocean Networking
Hope this helps
1 « J'aime »
Really? I don’t think that’s the recommended approach:
3 « J'aime »
It really depends on where domain purchased. Some domain registrar’s DNS lookup times are really horrible.
yes. but as suggested by @codinghorror the thread contains all relevant information to choose which way you should go
Thank you.
1 « J'aime »
And some of them have horrible interfaces for management.
If you don’t have enough traffic that you’ve hired someone who has a strong opinion, it mostly doesn’t matter as long as you can remember where it is that you need to go to make changes next time you need to.
2 « J'aime »
