Shopify Integration
Discourse has intergration with many social login methods already, and it’s very nice.
Can it intergrates with e-commerce platforms like Shopify so users of an existing e-commerce community can login via the same account everywhere for that company?
Example: http://forums.envato.com uses the same login everywhere throughout their site.
「いいね!」 1
Shopify supports oauth2 GitHub - Shopify/omniauth-shopify-oauth2: Shopify OAuth2 Strategy for OmniAuth 1.0 · GitHub it is possible you could simply use our existing oauth2 plugin for it. Otherwise someone could build a plugin for it.
Edit by @david, Oct 2020: Shopify oauth2 is for shop owners only, not end-users.
「いいね!」 6
Thanks, where can I find existing oauth2 plugin for Discourse? I’m new and recently just bought Discourse standard plan.
And does oauth2 plugin for discourse supported on Hosted Discourse version, standard plan?
I guess this one Discourse OAuth2 Basic
「いいね!」 2
For our hosting, OAuth 2 is only supported on the business plan and higher.
「いいね!」 1
Ah I see. I’d love to upgrade to it if I know for sure it works with Shopify user accounts. Can you let me know please? i’m not familiar with OAuth2 documentation.
How could i integrate my email service with discourse. Currently i have created a shopify store for dropshipping purpose and i write those steps as a article. So i need to know about email integration which i will also add in article. i will also share article that i have written. After 6 days no one response me you can see withintheflow.com where my friend write too many education content for drop-shipping and their platform so if you are willing then please let me know.
I’m not aware of any existing plugins that have the functionality you are looking for, but Discourse has several options for interfacing with other apps like MailChimp, ConvertKit, or Shopify. You could use webhooks, the api, and/or the data explorer to gather the email addresses you are looking for and send them to your email service. Also a custom plugin could also be created.
「いいね!」 2
Hey guys, I was wondering if there were any articles showing how to add discourse to my Shopify store. (forum.mystore.com)
Any pointers would be awesome!
There really isn’t a concept of “adding” Discourse to an existing site. You create a Discourse site, and then link to it from your existing site.
Here’s a rough overview of what that process would look like:
You’d set up a Discourse site in its own environment (hosted with us or self-hosted with Digital Ocean or any other compatible hosting service).
You’d then setup the DNS with your domain registrar so your forum can be accessed at forum.mystore.com
You can optionally install and configure an OAuth2 plugin so that your customers can log in to Discourse with their Shopify account.
Then it’s a matter of including a link to your forum from your store and including a link to your store from the forum — you can also optionally theme your Discourse site to match the design of your Shopify store too.
「いいね!」 11
Awesome, thank you so much Kris! Very helpful
「いいね!」 1
Hi @electricjared,
If you want to sell products in your Shopify store that can then be accessed in your Discourse site in private Categories, you could talk to @joebuhlig about building a technical integration between the two.
「いいね!」 1
みなさんこんにちは、Shopify と Discourse の間で OAuth を機能させようと試みているのですが、成功した方がいらっしゃいますか?Shopify は顧客アカウントに対して実際に OAuth をサポートしていないようなので、非常に苦労しています。
Shopifyから情報を取得し、DiscourseへAPIリクエストを送る、中間のWebhookを使用する必要があるかもしれません。
ただし、Shopifyからの呼び出しを直接処理するプラグインの方が簡単かもしれません。
「いいね!」 1
ウェブフック(顧客/ユーザー情報を含む)が存在しない可能性がかなり高いと考えています。完全にカスタムなプラグインを作ることは避けたいと考えています(資金が限られているため)。:slight_smile:
「いいね!」 1
プラグインが必要ない場合は、その間に Zapier などのツールが必要です。
Shopify がユーザーが作成された際や、メンバーシップに追加された際に Webhook を呼び出せない場合(これはありそうにありませんが)、それ以上どうすることもできません。
「いいね!」 2
Shopify と Discourse のログイン認証情報を両方の設定で動作させることができましたか?
「いいね!」 1
全くありません。Shopify の認証システムは、私たちが確認した限りでは、それを許可していません。
Zapier は試していません。それは、真の認証ソリューションを期待しているためです。非常に失望しています。主に Shopify に対してです。
「いいね!」 4
ああ、それは残念ですね!私も同じことを探していました!これを実現するプラグインを作成してくれる方がいれば、何人かで力を合わせて実現しませんか?
DiscourseとShopify間のSSOに関するアップデートはありますか?
