Looks like we’ve got a regression where hitting R to bring up the reply composer while viewing a post prints an “R” in the composer window, where it should be a blank composer. I can reproduce this on both meta and try.
Possibly due to the recent composer work, @nbianca ?
「いいね!」 4
fhe
(Florian)
2019 年 1 月 22 日午後 7:21
In addition, it seems that reply to post via r is not working anymore, shift + r shows the above-mentioned behavior.
jomaxro
(Joshua Rosenfeld)
2019 年 1 月 22 日午後 7:22
3
Reply to post also prints an r into the composer, but it works. Have you selected a post to reply to first via j and k ?
「いいね!」 4
Ninja’d!
I also noticed that the same issue exists on the r shortcut, too
「いいね!」 1
fhe
(Florian)
2019 年 1 月 22 日午後 7:26
5
Thanks for pointing. I was unaware of that necessity, learning new Discourse features every day
「いいね!」 2
jomaxro
(Joshua Rosenfeld)
6
Yep, without it Discourse doesn’t know which post you’re replying to .
「いいね!」 1
fhe
(Florian)
2019 年 1 月 22 日午後 7:29
7
I thought it takes the one which is active in the address bar, e.g, 107202/4 or 107202/5 (it somehow already knows which post I’m looking at).
「いいね!」 1
j.jaffeux
(Joffrey Jaffeux)
2019 年 1 月 22 日午後 8:03
9
Might be ember3 , will look tomorrow
「いいね!」 5
zogstrip
(Régis HANOL)
2019 年 1 月 23 日午後 2:52
11
We can’t do that based on the URL alone when there are multiple posts in the viewport, we can’t know which one you are replying to
「いいね!」 4
fhe
(Florian)
2019 年 1 月 23 日午後 3:10
12
Somehow I knew that I was missing something Thanks for the clarification!
「いいね!」 1
