Staging/Test server ignored the environment variable
I followed the following setup in my staging/test server in web_only.yml. But it seems that the backups are still going in the latest discourse? Seems that it is ignoring the environment variable.
  ## Staging server specific settings
  DISCOURSE_AUTOMATIC_BACKUPS_ENABLED: false
  DISCOURSE_LOGIN_REQUIRED: true
  DISCOURSE_DISABLE_EMAILS: 'yes'
  DISCOURSE_S3_DISABLE_CLEANUP: true
  DISCOURSE_ALLOW_RESTORE: true
The automatic_backups_enabled setting has been removed in August… :sob:
Use backup_frequency (DISCOURSE_BACKUP_FREQUENCY: 0) instead.
Thanks for the solution.
I also just updated the Wiki here:
It was still referring to the old method.
