Enquête Plugin (Experimenteel) - Probleem met Font Awesome 6 niet-aangevinkte iconen
Related to the Discourse Surveys Experimental Plugin
I think that this is related to the upgrade to Font Awesome 6, where checked icons do not render:
When I look in the code, this seems to have been addressed:
https://github.com/discourse/discourse-surveys/commit/5dfd599c07c358508b562d6780ae5c9dda2e466f
However, in the rendered HTML we have the old icon (which no longer exists):
<svg class="fa d-icon d-icon-far-check-circle svg-icon svg-node" aria-hidden="true"><use xlink:href="#far-check-circle"></use></svg>
I think I fixed the icon names in this week’s rewrite. Could you try updating, and see if the problem persists?
Yup - you are absolutely correct! I was just updating it to check that (after seeing the code updates).
Works a treat now:
