Feedback UX sulla rimozione dei tag
Hi team, not sure if this is the right place for feedback - but the recent changes to how tag input works keeps throwing me off, so I thought I would mention it here.
Currently if you want to remove a tag from a topic, you press edit, and then you end up here:
Now, if IIRC, I could previously either X in this box or type in it. Either way: I could remove a tag. But with the UI above, there is no obvious way to get rid of it. Can click anywhere in the box and nothing happens at all.
The only way to remove it, which is really counter-intuitive, is to click on the + icon, to add a new tag :thinking:
5 Mi Piace
I have noticed it this morning and fixed it while fixing another bug, it was a recent regression. A click on the component should correctly expand it now.
7 Mi Piace
This topic was automatically closed after 26 hours. New replies are no longer allowed.
