Hey all,
I’ve learned a lot using tempaltes, plugin outlets and all the wonderful magic in Discourse. Is it possible to list all tags used in a category at the top of the topic list there?
Hey all,
I can sort of accomplish this with: Discourse Popular Tag Sidebar
I’ll see what I can learn.
You can get the top_tags
easily :
Import ajax – import { ajax } from "discourse/lib/ajax";
, then →
ajax(`/c/general.json`).then((data) => {
console.log(data.topic_list.top_tags);
This is the general
category; you can replace this with a variable or theme-component setting.
If you want to display all tags unfiltered by category, /tags.json
To use the outlet above the topic list, the outlet name is /javascripts/discourse/connectors/above-main-container/{name-of-your-file}.hbs
. I would recommend seeing how this is done in other theme-components and reading Using Plugin Outlet Connectors from a Theme or Plugin.
More difficult is getting all tags. You can look at the data structure from /c/general.json
, which looks like this. Instead of doing data.topic_list.top_tags
, you could iterate each in data.topic_list.topics
and add each tags
for each topic
to an array. data.topic_list.topics.map((topic) => topic.tags);
Hope this helps!
