Topic subject letter's case not editable
In a support thread titled ‘Topic subject letter’s case not editable,’ fearlessfrog reports an issue on Discourse 1.8.0.beta12 where topic titles cannot be edited to change letter casing — for example, changing ‘VEAO p-40f’ to ‘VEAO P-40F’ reverts automatically. Screenshots show the edit appears to save but doesn’t persist. fearlessfrog confirms via Chrome console that the PUT request succeeds with a 200 response, yet the title remains unchanged. featheredtoast and codinghorror suggest disabling the ‘title prettify’ site setting, which resolves the issue. fearlessfrog confirms the fix and adds that enabling ‘allow uppercase posts’ was also necessary, referencing a related topic for context. The user humorously notes their initial difficulty recalling the term ‘capitalization’ that might have led them to the solution sooner.
Hi!
We’re on 1.8.0.beta12 and have noticed an odd thing with not being able to edit topics to be able to change the case of the subject:
Example:
a. We spot a topic subject that someone asks us to update because it’s in lower case:
b. I’ll go in an update it (pilots are really into their letter casing being correct :slight_smile: )
c. It doesn’t take, as in doesn’t seem to edit:
Not sure if a bug or just a misunderstanding. It just seems like an issue on editing and not creating new topics. We’ve also tried doing things like adding a character like ‘-’ on the end to force a change, but it still always reverts back to how it was.
Thanks for any help.
In Chrome console the PUT seems to go through ok (cookie/CSRF blanked):
Response with 200:
{“basic_topic”:{“id”:1742,“title”:“VEAO p-40f”,“fancy_title”:“VEAO p-40f”,“slug”:“veao-p-40f”,“posts_count”:36,“category_id”:7}}
You want the “title prettify” site setting.
Turn off title prettify in site settings
Thank you! F/A-18C here we come!
I’m now more worried that I couldn’t think of the word ‘capitalization’ that would have led me to that search result :slight_smile:
EDIT: We also needed ‘allow uppercase posts’ to be enabled as well:
