خطأ إملائي في الفرنسية
During the forum set up, I noticed a typo mistake:
“Dévrivez” => “Décrivez”
Is it the right place to post such error? Should I do an issue on Github? or even a PR?
إعجابَين (2)
Well spotted :wink:
The right place to fix this is on Transifex.
Thank you
8 إعجابات
I asked to join the team.
إعجابَين (2)
Thanks for accepting me joigning the team. One question: I’m unable to find “Dévrivez” when searching because it seems that we can only search by resource name and I don’t know how to identify which resource it correspond. Any tip?
One easy way to solve your problem is to select “All resources” on Transifex and then use the search function. “All resources” is located on the bottom left on the https://www.transifex.com/discourse/discourse-org/translate/#fr page.
Normally it’s useful to translate one resource at a time to keep track. You can also open the GIT blame of the respective English locale file on Github. Then it’s super easy to see what has changed and why.
6 إعجابات
Ok found! Thank you for your help!
4 إعجابات
