No se puede activar el tutorial avanzado de Discobot
The command @discobot start advanced user isn’t trigger the advanced user tutorial on my site. Discobot just responds with the generic “Hi! To find out what I can do, say @discobot display help” reply.
To try to troubleshoot the issue, I’ve checked that:
  • The users are sending the message in a DM
  • They have completed the new user tutorial
  • There’s no error logs related to this
Is there anything else that might be stopping the tutorial from starting?
Hi Alex, try with
  • @discobot start tutorial
    and
  • @discobot start advanced tutorial
See Rename @discobot's start new user command for more info
That worked, thanks!
