כשל בשדרוג: באג ב-Docker Manager?
Is there a problem with Docker Manager?
Docker Manager: FAILED TO UPGRADE
#<NoMethodError: undefined method `branch' for #<DockerManager::GitRepo:0x00007f1132b2ce20 @path="/var/www/discourse/plugins/discourse-onebox-assistant", @name="discourse-onebox-assistant", @memoize={"rev-parse HEAD"=>"0bf6e034f9a3ce0d23139417d05d2937132f2eaa", "symbolic-ref -q HEAD"=>"refs/heads/master", "for-each-ref --format='%(upstream:short)' refs/heads/master"=>"origin/master", "rev-parse --is-shallow-repository"=>"false", "show-branch remotes/origin/main"=>nil, "rev-parse origin/master^{}"=>"681fe5f804f444503c64a75e620b81f4f48dd1bf"}, @upgrade_key="upgrade:/var/www/discourse/plugins/discourse-onebox-assistant", @upgrade_version=nil>>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:73:in `block in upgrade'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:71:in `each'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:71:in `each_with_index'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:71:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
Am I missing anything or this a bug in docker_manager?
Could it be related to this commit?:
https://github.com/discourse/docker_manager/commit/6293c3d948f027fd48d9141b5c26a08541916b4d#diff-b7cf961a7ca9c83bda8f14283b867bc3f371c2f2e217e03166c6472ecd678504
Specifically this change?:
Yet it is still referenced here?:
Thanks in advance!
לייק 1
I had someone last night complain that a UX upgrade had crashed their site. I didn’t see the error. I’m pretty sure it was after the bump to the new base image, so this might explain their problem. It would seem like it would affect only those on beta, though?
לייק 1
this was a tests_passed upgrade.
I’m fairly sure it’s a bug.
3 לייקים
Indeed, it looks like I broke it and didn’t notice because all my repos had a main branch. :man_facepalming:
I’ll fix it soon.
2 לייקים
Yeah, thanks! Looks like an edge case :slight_smile:
I’m tempted to move the branch now, but might help to test the resolution if I don’t :thinking:
That won’t fix it until docker_manager is fixed. Give me a couple of minutes to verify my solution and create a PR…
https://github.com/discourse/docker_manager/pull/180
2 לייקים
Thanks for reporting that regression. It’s fixed now.
6 לייקים
