Upgrade to latest release failed 8/21/25
The latest upgrade required rebuilding the app in launcher, but it failed.
First it complained about having the adplugin as a separate install, so I removed that.
Looks like then it failed trying to migrate the secondsite database:
2025-08-21 06:44:42.493 UTC [867] discourse@discourse_nu ERROR: must be owner of extension vector
2025-08-21 06:44:42.493 UTC [867] discourse@discourse_nu STATEMENT: ALTER EXTENSION vector UPDATE TO ‘0.7.0’;
1 migrations failed!
Failed to migrate secondsite
Cause
  • The migration tries to upgrade the “vector” extension.
  • The PostgreSQL user running the migration (e.g. discourse) must be the owner of the extension, but it’s owned by a different user (often postgres).
Solution
  • Connect to your database as the owner
  • Run the update as the owner
Checkout the discussion on the same Still an issue: ERROR: must be owner of extension vector - #2 by Falco
That fixed it.
However, the problem with nginx and secondsites that I reported over a year ago is still there,
in the nginx config files within the container, it checks to see if the URL is not for the first site and changes it to that. I commented out that code–again.
There have been big changes in how the nginx config is handled.
Do you have a multisite setup with no reverse proxy?
Well, it’s been nearly 2 years since I’ve looked at nginx much, but this problem existed when I first moved over to Discourse 2 years ago, so it is not new.
Here’s an excerpt from the nginx.conf file:
server {
    server_name  huskerlist.tssi.com;
    root         /var/www/html;
    allow 162.210.7.125;
    allow 162.210.7.112;
    allow 162.210.7.116;
    allow 76.84.125.160;
    allow 172.17.0.2;
    allow 72.250.242.47;
    allow all;
    if ( $lockdown ) {
       set $custom_server_name "lists.tssi.com";
       return 300 "site is down for maintenance";
    client_max_body_size 100M;
    # Load configuration files for the default server block.
    #include /etc/nginx/default.d/*.conf;
    location / {
            proxy_pass https://127.0.0.1:8443/;
            #proxy_pass http://unix:/var/discourse/shared/standalone/nginx.http.sock;
            proxy_set_header Host $http_host;
            proxy_http_version 1.1;
            proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
            proxy_set_header X-Forwarded-Proto $scheme;
            proxy_set_header X-Real-IP $remote_addr;
    error_page 404 /404.html;
        location = /usr/share/nginx/html/40x.html {
    error_page 500 502 503 504 /50x.html;
        location = /usr/share/nginx/html/50x.html {
listen [::]:443 ssl; # managed by Certbot
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/lists.tssi.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/lists.tssi.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
    server_name  nu-sports.tssi.com;
    root         /var/www/html;
    allow 172.17.0.2;
    allow all;
    if ( $lockdown ) {
       rewrite ^ https://lists.tssi.com/n-maint.html;
    location / {
            #proxy_pass http://unix:/var/discourse/shared/standalone/nginx2.http.sock:;
Apparently every time it set up a new container (such as during a reboot) it rewrites the
/etc/nginx/conf.d/outlets/server/20-https.conf file, and these lines cause a redirect to the default discourse system:
if ($https_host != huskerlist.tssi.com) {
rewrite (.$) https://huskerlist.tssi.com
Is there a way to avoid this? What purpose does this code serve?
