Hi,
Do we have a feature where we can put a ‘Was this Article Helpful? Yes or No’ box below the articles?
It can help us understand user understanding better.
סיכום מבוסס בינה מלאכותית
The discussion revolves around implementing a “Was this Article Helpful? Yes or No” feature on articles within Discourse. Monika_Gupta initiates the request, seeking a built-in feature to gauge user understanding. itsbhanusharma notes that this functionality isn’t currently available, as Discourse is primarily a community platform. hawm suggests using the Topic Ratings plugin as a potential solution. maiki proposes simpler alternatives, such as using JavaScript and markup for feedback buttons or linking to a feedback category via pre-filled topics. Bcat shares a visual example and suggests using the Compose a new pre-filled topic feature or modifying the VOTING plugin for tracking feedback, emphasizing the need for a logged-in system to log votes effectively. Monika_Gupta confirms she has created a basic version but seeks a more refined solution like the one shared by Bcat.
This isn’t available as of now, Discourse is a community discussion platform not a customer support solution. However a lot of users have implemented Discourse to provide customer support but I’m yet to see anyone implement this feature.
If you mean the topic ratings, i found a similar exist solution,also you could customize your Discourse like this by plugin.
Hi..maybe we can try this. Thanks
I’ve seen external services provide this functionality, as well as some self-hosted options. I forget what that specific tech is called (like, “feedback buttons”?), but it’s just a bit of javascript and markup to include in a page footer or similar, so that may be easier than having Discourse track it.
Or include a message: “Was this article helpful? Yes or No”, and have the links Creating a link to start a new topic with pre-filled information, straight to a feedback category or private message. ![]()
If you need to log in, you can use Compose a new pre-filled topic via URL to create a sample HTM format, then export it at the comment.
Cons 1 Vote is also alone argument.
If using VOTING plugin, each post must be inserted, or automatically inserted by the template of the directory.
I think I should change the VOTING plugin instead of using another API 1 domain + database to save data like my above image.
