למה אני רואה את ‘#number’ לצד טקסטים באתר?
סיכום מבוסס בינה מלאכותית
The user Truest asked why they were seeing ‘#number’ patterns next to site texts in Discourse, which was resolved by disabling the ‘verbose localization’ site setting simon. Truest confirmed the issue was fixed. JammyDodger advised splitting multiple questions into separate topics for better organization and searchability.
I am in a situation where I have installed Discourse on Github using DigitalOcean. I have a few questions here (Discourse Version 3.3.0 beta2)
  1. I would like to know why I am seeing the #number pattern as shown in the attached picture and how to remove it, is there any way?
Questions split off into separate topics
I want to install Discourse AI on Discourse
I would like to edit the theme rules
Hi @Truest, I can answer your first question:
The numbers you are seeing in the UI are related to the “verbose localization” feature. Details about how tit can be used to modify the user interface text of your site are here: Find a translation key with verbose localization. The most likely reason you are seeing the numbers is because you have enabled the “verbose localization” site setting:
Disabling the setting and refreshing the page should make the numbers go away.
Thank for your reply. #number The problem has been resolved.
Hello and welcome @Truest :slight_smile:
Just to reiterate this :point_up: It is much more useful for us to have one issue per topic so we can make use of all of the features to better organise our content.
Moin has very helpfully answered in different posts to make it easier to split out the answers, if you wouldn’t mind splitting your extra questions up into new topics. :pray:
