Discourse aura-t-il une installation de style Plesk ?
Bonjour, j’utilise beaucoup Discourse car j’ai de nombreux forums où je suis inscrit et ils utilisent tous Discourse (heureusement), seuls quelques-uns utilisent phpBB et je n’aime pas visiter ces sites, mais je dois le faire !
Ma question est la suivante : comme j’aimerais lancer mon propre forum Discourse, le processus d’installation sera-t-il aussi simple que pour WordPress ?
Y a-t-il déjà quelque chose de prévu ou en cours de développement pour ajouter Discourse à Softaculous ou Installtron, ou pour créer une extension Plesk/cPanel pour Discourse qui gère tout le processus d’installation ?
Merci
Discourse uses a set of tools that are more difficult to configure than those that wordpress uses. The standard install document is pretty easy to follow, though getting mail configured is not.
If you want easy, then use a hosting service or have me install it for you. https://www.literatecomputing.com/discourse-installation-packages/
Thanks, the problem is my dream was to have it running on my Plesk server beside all my other websites, I don’t like to go for now with hosted solutions.
Having it run under plesk is much more complicated. A few people have done it, but it makes installing discourse more complicated and is difficult to get plesk to do it. You can search here, but it’s far from one click. It’s much easier to stick it on its own server.
Thanks! I will rent a server only for discourse and try to install it!
EDIT: But how to connect a Domain without an panel like Plesk? And does the insaller also install Postgresql ?
If you follow the install document, it does everything. You just need to create an A Record pointing your hostname to the server ip using whatever you usually use to manage dns.
@pfaffman I found now the hosting company Nodechef they have discourse hosting service, hope they are good…any expirience with them?
I do not. You can look here. There’s not much, but there’s
Thanks, this guy has pretty much the same problems I have now.
Chez www.Communiteq (anciennement DiscourseHosting), nous disposons d’un assistant de configuration qui fonctionne vraiment bien :smiley:
With a package that starts with 10$ I would come over but 20 is to much for my budget.
You can choose to self-host then.
There is a very detailed installation guide available:
discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
If You’re scared of installing yourself, consider hiring someone, I myself do installs but would totally recommend @pfaffman
