Discourse Encrypt (deprecated)
The Discourse Encrypt plugin has been deprecated, with support ending in Q1 2025 due to low adoption and high maintenance costs. Admins can now disable new encrypted messages via allow_new_encrypted_pms and enable decryption of existing ones using allow_decrypting_pms. Commands are provided to check the number of remaining encrypted messages. The plugin used advanced cryptographic methods like AES-256-GCM, RSA-OAEP, and RSA-PSS via the Web Crypto API. Users have raised questions about group messaging and encryption issues, with some reporting incompatibility with the latest Discourse update. While no official bug report is needed due to deprecation, the plugin’s end-of-life is confirmed, and users are encouraged to migrate. original announcement
Original Plugin Description
:discourse2: Summary Discourse Encrypt enables private, encrypted messaging between end-users. All sensitive information is stored securely on the server and is encrypted and decrypted only on the client-side.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-encrypt
:open_book: Install Guide How to install plugins in Discourse
Three easy steps to use this plugin
  1. Enable encryption and activate current device.
  1. Send an encrypted message. The recipient must also have enabled encryption.
Optionally, you can determine the time after which the whole message or specific post will be permanently destroyed
  1. Read secret messages. Encryption must be activated first to read them.
Note: In this example, the user was prompted for paper key again because encryption was deactivated (by logging out or explicitly deactivating it from preferences screen).
Technical information
This plugin gives users the possibility to communicate securely through Discourse, by using an end-to-end encryption scheme. Most of plugin’s logic is implemented on the client-side and the server-side handles only public or encrypted information. It does not encrypt any post metadata, such as names of participants in the conversation, posted time, likes, small actions, etc; uploads are encrypted, but their presence is not because the system must associate uploads with posts to prevent deleting them.
The whole code is open-source and security enthusiasts are welcome to review it. For any further information, do not hesitate to contact me or the team. :slight_smile:
read more...
Summary
The goal of this plugin is to offer integrity and confidentiality of the encrypted contents, and to protect it against information leaks and unauthorized users. The following sections describe the usual operation mode, used algorithms and threat models.
To use this system, users enroll once by generating a “user identity” consisting of two 4096-bits RSA keys, one for encryption and another for signing. Users can export their “identity” for safe keeping or store it on the server, encrypted after generating a paper key. These two methods serve as backups or are used to enroll new devices.
Paper keys (inspired by RFC 1751 and BIP-39) are human-readable keys that are used to securely store the “user identity” on the server. A paper key consists of 12 random words, picked from a list of 2048 words, offering 121-bits of entropy (the first word is used as a label). To encrypt the “user identity” with a paper key, the system will first derive the encryption key using PBKDF2 to stretch the paper key into a 256-bit AES-GCM key.
Creating an encrypted post
To create a new post, the user (their browser) will:
  1. sign the current post content using their private signing key;
  2. generate a new “topic key” (a AES-256-GCM key) - which is going to be used to encrypt the post, some post metadata and the title of the new topic (if available);
  3. fetch the public keys of all participants and encrypt the “topic key” for each of them;
  4. send to the server the encrypted post (Base64 encoded) and the encrypted topic keys (also Base64 encoded) of each participant.
The pseudocode for the encryption operation would be something like:
signature = rsa_pss_sign(current_user.identity.sign_key.private, post.raw) # 1
topic_key = topic.key || generate_aes_256_gcm_key() # 2
encrypted_title = aes_256_gcm_encrypt(topic.title, topic_key) if topic.blank?
encrypted_post = aes_256_gcm_encrypt(signature + post.raw, topic_key)
encrypted_topic_keys = recipients.map { |r| rsa_oaep_encrypt(topic_key, r.identity.encryption_key.public) } # 3
$.put("/posts/create", { title: encrypted_title, raw: encrypted_post, keys: encrypted_topic_keys }) # 4
Reading an encrypted post
To read a post, the user (their browser) will:
  1. fetch the encrypted post payload (post plaintext and signature) and encrypted topic key;
  2. use their private encryption key to decrypt the encrypted topic key;
  3. use the decrypted topic key to decrypt the encrypted post payload;
  4. fetch the public signing key of the poster and verify the post signature.
Algorithm Suite
This plugin makes extensive use of the cryptographic primitives implemented in Web Crypto API, which are available in any of the modern browsers Discourse supports (except Internet Explorer).
  • getRandomValues PRNG: It generates paper keys and 96-bits random IVs.
  • PBKDF2: It stretches the 132-bit paper keys to 256-bit keys, used for encrypting “user identities”.
  • AES-256-GCM: Used to encrypt each post’s content. It also offers authentication by producing an authentication tag of 128-bits, but this is a less important aspect because posts are verified using a signature generated by the poster (see step 1 above).
  • RSA-OAEP: Used to encrypt “topic keys” and “user identites” for safe-keeping on the server. All RSA-OAEP keys are 4096-bits long.
  • RSA-PSS: Used to sign each post’s content for verifying authenticity. All RSA-PSS keys are 4096-bits long.
Primitives
The system uses a set of primitives built on top of those provided by the browser via Web Cryptography API.
  • encrypt and decrypt: Used to encrypt and decrypt post contents. encrypt takes a JSON, an AES-256-GCM key and a RSA-PSS public key and outputs a single Base64 encoded string; decrypt takes a Base64 encoded string and an AES-256-GCM key and outputs the initial JSON object;
  • verify: Used to verify post contents after decryption;
  • exportKey and importKey: Used to export and import “topic keys”;
  • exportIdentity and importIdentity: Used to export and import “user identities”.
Types of keys:
  • topic keys (AES-256-GCM)
  • RSA key-pair (public and private keys) (RSA-OAEP and RSA-PSS, 4096-bits)
    • used to encrypt all topic keys a user has access to
    • are generated per user on the client-side by the original poster using WebCrypto’s API generateKey primitive and shared amongst all of user’s devices
    • server-side: public identity is stored as exported by the client, but the private identity will always be encrypted with the passphrase key
    • client-side: public and private keys are stored as CryptoKey in IndexedDb; if not possible, it will use window.localStorage (in Safari)
  • passphrase keys (derived using PKBDF2 with 128,000 iterations)
    • used to encrypt “user identities” for safe storage on the server
    • derived from a paper key (or user’s passphrase for legacy purposes)
Threat models
Compromised Discourse Instance
An attacker which can inject code could in theory access encrypted information by serving malicious code, which decrypts the encrypted content and sends the plaintext posts to another server. To make this possible, it is enough to have access to an administrator account and create a theme component with the malicious code.
Default protection mechanisms such as CSP can detect and mitigate Cross Site Scripting (XSS) attacks that could also represent a way of injecting malicious code.
Man-in-the-Middle Attack
In Man-in-the-Middle attacks, the attacker intercepts the communication between the user and server, giving them the ability to read or alter it. Because the plugin encrypts everything before sending, an attacker cannot decrypt anything by simply eavesdropping. Similarly, because information is authenticated the attacker cannot alter it.
However, the attacker could serve malicious code back to the user and follow a similar attack to the one presented in the previous section. This is partially mitigated by HTTPS, which is considerably reducing the attack probability.
Notes
The plugin already has a little history and that can be seen while browsing the source code and noticing the two implementations of the protocol v0 (initial, alpha-beta release) and v1. Protocol v0 is no longer used to encrypt new posts, but kept to continue decrypting old ones. New protocol includes authenticity of the ciphertexts and all posts are signed with the private key of the poster.
Other Resources
PMs are accesible by admins if the admin has the link
Are PMs truly private and not crawlable?
Can true private messages be implemented?
What to do if your Discourse is compromised
Notifications but not emails
Possible privacy flaw with DMs
Encrypted PGP Messaging
Spoiler for certain user groups?
End-to-end Encryption for Chat
Preserving user sessions when migrating between hosts
Make MP's actually private
Generate Paper Key?
Add a warning when checking personal messages from a user public profile, as an admin
Types of community & their characteristics
What personal data is collected and who can read/edit it?
We still have Discourse Encrypt plugin - Would running community updates cause any issues?
Matrix protocol for chat
Can you edit the admin menu?
Discourse Encrypt breaks replies on latest Discourse update
Upload not working in encrypted private message?
E-Mail Preview Summary: wrong number of arguments (given 10, expected 1)
When you started your first Discourse community, what did you find hard to do?
Search in Encrypted messages, like in ProtonMail or Wire
No backup warn link issue
How can a group have end-to-end encryption
Images disapper from the Builder Preview in encrypted message drafts after page reload
Is there anyway to change ‘secret’ to secure?
Can someone explain `post metadata was updated without being signed again`?
Encrypt plug-in issue
Generate Paper Key?
Can't activate encrypted messages on my phone - says my paper key is incorrect or the key pair is incorrect
Search engines and private messages?
TypeError: Cannot set property deleteTopic of [object Object] which has only a getter
Can Discourse function without emails entirely?
Admins can see private messages in user's profiles?
Thoughts on Turning Off Personal Messaging and Chats
Spoiler but only admins can see it
Account creation not working with discourse_encrypt
Strategies for Isolating Plugin Secrets in Discourse
Disable watched words / censor in personal messages
Cannot Delete or Rotate Encryption Keys
How alert if admin/mods read users PM?
Can we prevent an admin from seeing a private category?
11 posts were split to a new topic: Full hide of partial posts for role-playing game
How can I enable sending encrypted messages to groups? All users of the group and the message sender have encryption enabled, but I still get error message:
“You do not have permission to send encrypted messages to groups.”
I don’t believe it’s currently possible to send encrypted PMs to groups.
Does this mean that group mailbox becomes broken? and/Or inviting a group to pm would not work?
This, it wasn’t possible in the first place.
Do I need to submit a bug report on this being broken?
Everything appears active short missing the normal lag in opening but PM’s are not encrypted
There’s no need to cross-post, but if you’d like to make it a Contribute > Bug report rather than a Support request you can follow these guidelines and then recategorise it - Writing an effective bug report
Though it’s worth noting that both bug reports and support requests can take time to pick up traction, especially at the weekend.
:mega: Unfortunately due to the relatively low adoption rate, and high cost of maintenance, support for discourse-encrypt will be dropped after core’s next stable release in Q1 2025.
The original post of this topic has been updated with more information, and we’ll be introducing an automatic warning for admins of affected sites.
Hope for dev this on future.
This is very important/useful one in data/blockchain/security.
10 posts were split to a new topic: Do not show topics and PMs to admins unless they are participants
Continuing the discussion from Discourse Encrypt (deprecated):
The time has come and the latest Discourse update appears to be incompatible with Discourse Encrypt.
Our symptoms are that nobody is able to reply to a post; the system starts to load the reply view but never manages to load up the actual editor.
Toggling off the Discourse Encrypt eliminates the problem, toggling it back on brings the problem back.
As this plugin is deprecated, I’m not reporting it as a bug, I’m just reporting it so that others can expect this behavior.
Also, if anyone knows of resources that we could point to for individuals who would like to be able to download encrypted messages and decode them offline, that would be appreciated.
