Sidebar Theme Toggle
:discourse2: Summary Sidebar Theme Toggle adds a theme selector in the sidebar menu’s footer provided there is more than 1 user selectable theme. This selector works with both logged-on users and anonymous users. Be sure to add this to all your user-selectable themes for easy toggling.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-sidebar-theme-toggle
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
We may do some additional work here in the future to make this a more comprehensive menu that allows users to choose colors, font-sizes, and theme from one menu — but for now this grants sites the same basic behavior as the Hamburger Theme Selector! :rocket:
Name Description
toggle icon
hide theme name
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
Will it work someday with iPhone/iPad too?
It should already work on mobile devices, but let us know if there are any issues!
Well… it doesn’t :wink: Not here, not on my own.
ah I see, I’ll have to double check the app, looks like the footer’s getting cut off there… thanks for mentioning it!
You are totally right. The issue is the Hub.
This is a great idea for a component, but I’m having a little difficulty getting it to work. I’ve installed it and included it in all my themes but the drop-down doesn’t appear. If I toggle the “hide theme name” setting, the keyboard shortcut icon moves from the left side of the sidebar footer to the right, but no theme selector.
Thanks Kris, unfortunately it’s not working on my site. Did a hard refresh of course, tried different themes that have no other components, don’t see anything relevant in the console or logs…
Rebuild your instance. It will fix all of the issues mentioned above so far.
oh yes, I should have mentioned that if you haven’t updated Discourse in the past few days you should do that as well
I think I’m on the most recent version…
Screenshot 2022-10-24 at 18.32.16
I’ll try rebuilding later. Our users tend to freak out a bit if the site goes offline with no warning.
You should consider this :sunglasses:
What about a dark theme selector? For light, dark and auto. That seems broken since I switched to the sidebar.
A post was merged into an existing topic: While loading a new component on the site, the site is down
It would be nice to add color palettes as well. Is this possible?
Just create a separate Theme with a different name and configure its colour pallette differently. Done.
Weird thing on the Meta, the “Hidden Whispers” theme only appears when the current theme is “Central”, “Default (full-width)”, “Fully”, “Meta Branded”, or “redditish”. Example:
Default:
redditish:
Not sure if it’s relevant, but I noticed while writing this that the themes where “Hidden Whispers” shows up are also the ones where the reply box covers up the theme toggle.
Hidden Whispers also doesn’t have a description in the theme category that I can find. This appears to be the only other mention of its existence? I feel like I’m losing my mind :smile:
edit: This might not be related to this theme-commponent, I see the same behavior in the profile > interface > theme menu.
That’s a theme that the staff uses in cases where they may be taking a screenshot of Meta or something similar and don’t want whispers to be included. We have a separate theme component meant to hide it from the themes list for normal non-staff accounts, but it wasn’t added everywhere.
I think it should be fixed now, it shouldn’t appear in the list for you while using any theme. Apologies for the confusion!
Ah, thank you for the clarification, the world makes sense again!
Very good,I like it
