Невозможно создать новые посты с категориями при установленных шаблонах форм
Recently I installed the experimental form templates
feature as reported, but after creating a form for the category, the “create topic” button did not work.
Do I need to install anything else to enable this feature?
2 лайка
No as long as you enable the feature in settings, create a template and assign it to a category it’ll work.
Are there any errors in logs and does it occur in safe mode?
2 лайка
Thank you, after trying to turn off the plugins one by one, the form template feature is working, they are affected by the “Perspective Api” plugin, this is an offical plugin, I hope the discourse team can check and correct it.
2 лайка
Yes i second that. Its not working with Discourse Google Perspective API
1 лайк
@hoangphuctran93 / @David_Ghost could you share the following so that I can better diagnose this issue?
  • the form template(s) used
  • the perspective settings you have changed
If you can manage to reproduce the issue with a minimum of changes, that would be greatly appreciated as well :+1:
Thanks
2 лайка
Nevermind. I’m able to reproduce. Will fix :mag:
5 лайков
I have a fix in the work
6 лайков
PR is now merged.
3 лайка
Thanks, I will reinstall and get back to you with my experience.
1 лайк
This topic was automatically closed after 3 days. New replies are no longer allowed.
