Discourse Verschlüsselung (veraltet)
Original Plugin Description
:discourse2: Summary Discourse Encrypt enables private, encrypted messaging between end-users. All sensitive information is stored securely on the server and is encrypted and decrypted only on the client-side.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-encrypt
:open_book: Install Guide How to install plugins in Discourse
Three easy steps to use this plugin
  1. Enable encryption and activate current device.
  1. Send an encrypted message. The recipient must also have enabled encryption.
Optionally, you can determine the time after which the whole message or specific post will be permanently destroyed
  1. Read secret messages. Encryption must be activated first to read them.
Note: In this example, the user was prompted for paper key again because encryption was deactivated (by logging out or explicitly deactivating it from preferences screen).
Technical information
This plugin gives users the possibility to communicate securely through Discourse, by using an end-to-end encryption scheme. Most of plugin’s logic is implemented on the client-side and the server-side handles only public or encrypted information. It does not encrypt any post metadata, such as names of participants in the conversation, posted time, likes, small actions, etc; uploads are encrypted, but their presence is not because the system must associate uploads with posts to prevent deleting them.
The whole code is open-source and security enthusiasts are welcome to review it. For any further information, do not hesitate to contact me or the team. :slight_smile:
read more...
Summary
The goal of this plugin is to offer integrity and confidentiality of the encrypted contents, and to protect it against information leaks and unauthorized users. The following sections describe the usual operation mode, used algorithms and threat models.
To use this system, users enroll once by generating a “user identity” consisting of two 4096-bits RSA keys, one for encryption and another for signing. Users can export their “identity” for safe keeping or store it on the server, encrypted after generating a paper key. These two methods serve as backups or are used to enroll new devices.
Paper keys (inspired by RFC 1751 and BIP-39) are human-readable keys that are used to securely store the “user identity” on the server. A paper key consists of 12 random words, picked from a list of 2048 words, offering 121-bits of entropy (the first word is used as a label). To encrypt the “user identity” with a paper key, the system will first derive the encryption key using PBKDF2 to stretch the paper key into a 256-bit AES-GCM key.
Creating an encrypted post
To create a new post, the user (their browser) will:
  1. sign the current post content using their private signing key;
  2. generate a new “topic key” (a AES-256-GCM key) - which is going to be used to encrypt the post, some post metadata and the title of the new topic (if available);
  3. fetch the public keys of all participants and encrypt the “topic key” for each of them;
  4. send to the server the encrypted post (Base64 encoded) and the encrypted topic keys (also Base64 encoded) of each participant.
The pseudocode for the encryption operation would be something like:
signature = rsa_pss_sign(current_user.identity.sign_key.private, post.raw) # 1
topic_key = topic.key || generate_aes_256_gcm_key() # 2
encrypted_title = aes_256_gcm_encrypt(topic.title, topic_key) if topic.blank?
encrypted_post = aes_256_gcm_encrypt(signature + post.raw, topic_key)
encrypted_topic_keys = recipients.map { |r| rsa_oaep_encrypt(topic_key, r.identity.encryption_key.public) } # 3
$.put("/posts/create", { title: encrypted_title, raw: encrypted_post, keys: encrypted_topic_keys }) # 4
Reading an encrypted post
To read a post, the user (their browser) will:
  1. fetch the encrypted post payload (post plaintext and signature) and encrypted topic key;
  2. use their private encryption key to decrypt the encrypted topic key;
  3. use the decrypted topic key to decrypt the encrypted post payload;
  4. fetch the public signing key of the poster and verify the post signature.
Algorithm Suite
This plugin makes extensive use of the cryptographic primitives implemented in Web Crypto API, which are available in any of the modern browsers Discourse supports (except Internet Explorer).
  • getRandomValues PRNG: It generates paper keys and 96-bits random IVs.
  • PBKDF2: It stretches the 132-bit paper keys to 256-bit keys, used for encrypting “user identities”.
  • AES-256-GCM: Used to encrypt each post’s content. It also offers authentication by producing an authentication tag of 128-bits, but this is a less important aspect because posts are verified using a signature generated by the poster (see step 1 above).
  • RSA-OAEP: Used to encrypt “topic keys” and “user identites” for safe-keeping on the server. All RSA-OAEP keys are 4096-bits long.
  • RSA-PSS: Used to sign each post’s content for verifying authenticity. All RSA-PSS keys are 4096-bits long.
Primitives
The system uses a set of primitives built on top of those provided by the browser via Web Cryptography API.
  • encrypt and decrypt: Used to encrypt and decrypt post contents. encrypt takes a JSON, an AES-256-GCM key and a RSA-PSS public key and outputs a single Base64 encoded string; decrypt takes a Base64 encoded string and an AES-256-GCM key and outputs the initial JSON object;
  • verify: Used to verify post contents after decryption;
  • exportKey and importKey: Used to export and import “topic keys”;
  • exportIdentity and importIdentity: Used to export and import “user identities”.
Types of keys:
  • topic keys (AES-256-GCM)
  • RSA key-pair (public and private keys) (RSA-OAEP and RSA-PSS, 4096-bits)
    • used to encrypt all topic keys a user has access to
    • are generated per user on the client-side by the original poster using WebCrypto’s API generateKey primitive and shared amongst all of user’s devices
    • server-side: public identity is stored as exported by the client, but the private identity will always be encrypted with the passphrase key
    • client-side: public and private keys are stored as CryptoKey in IndexedDb; if not possible, it will use window.localStorage (in Safari)
  • passphrase keys (derived using PKBDF2 with 128,000 iterations)
    • used to encrypt “user identities” for safe storage on the server
    • derived from a paper key (or user’s passphrase for legacy purposes)
Threat models
Compromised Discourse Instance
An attacker which can inject code could in theory access encrypted information by serving malicious code, which decrypts the encrypted content and sends the plaintext posts to another server. To make this possible, it is enough to have access to an administrator account and create a theme component with the malicious code.
Default protection mechanisms such as CSP can detect and mitigate Cross Site Scripting (XSS) attacks that could also represent a way of injecting malicious code.
Man-in-the-Middle Attack
In Man-in-the-Middle attacks, the attacker intercepts the communication between the user and server, giving them the ability to read or alter it. Because the plugin encrypts everything before sending, an attacker cannot decrypt anything by simply eavesdropping. Similarly, because information is authenticated the attacker cannot alter it.
However, the attacker could serve malicious code back to the user and follow a similar attack to the one presented in the previous section. This is partially mitigated by HTTPS, which is considerably reducing the attack probability.
Notes
The plugin already has a little history and that can be seen while browsing the source code and noticing the two implementations of the protocol v0 (initial, alpha-beta release) and v1. Protocol v0 is no longer used to encrypt new posts, but kept to continue decrypting old ones. New protocol includes authenticity of the ciphertexts and all posts are signed with the private key of the poster.
Other Resources
98 „Gefällt mir“
PMs are accesible by admins if the admin has the link
Are PMs truly private and not crawlable?
Can true private messages be implemented?
What to do if your Discourse is compromised
Notifications but not emails
Possible privacy flaw with DMs
Encrypted PGP Messaging
Spoiler for certain user groups?
Preserving user sessions when migrating between hosts
Generate Paper Key?
End-to-end Encryption for Chat
Make MP's actually private
Can we prevent an admin from seeing a private category?
How alert if admin/mods read users PM?
Cannot Delete or Rotate Encryption Keys
Strategies for Isolating Plugin Secrets in Discourse
Admins can see private messages in user's profiles?
Search engines and private messages?
When you started your first Discourse community, what did you find hard to do?
Upload not working in encrypted private message?
Can you edit the admin menu?
Account creation not working with discourse_encrypt
We still have Discourse Encrypt plugin - Would running community updates cause any issues?
Types of community & their characteristics
Add a warning when checking personal messages from a user public profile, as an admin
What personal data is collected and who can read/edit it?
Spoiler but only admins can see it
Disable watched words / censor in personal messages
Matrix protocol for chat
E-Mail Preview Summary: wrong number of arguments (given 10, expected 1)
Search in Encrypted messages, like in ProtonMail or Wire
No backup warn link issue
How can a group have end-to-end encryption
Images disapper from the Builder Preview in encrypted message drafts after page reload
Is there anyway to change ‘secret’ to secure?
Can someone explain `post metadata was updated without being signed again`?
Encrypt plug-in issue
Generate Paper Key?
Can't activate encrypted messages on my phone - says my paper key is incorrect or the key pair is incorrect
TypeError: Cannot set property deleteTopic of [object Object] which has only a getter
Can Discourse function without emails entirely?
Discourse Encrypt breaks replies on latest Discourse update
Thoughts on Turning Off Personal Messaging and Chats
11 Beiträge wurden in ein neues Thema aufgeteilt: Vollständiges Ausblenden von Teilbeiträgen für Rollenspiele
Wie kann ich das Senden von verschlüsselten Nachrichten an Gruppen aktivieren? Alle Benutzer der Gruppe und der Absender der Nachricht haben die Verschlüsselung aktiviert, aber ich erhalte immer noch die Fehlermeldung:
„Sie haben keine Berechtigung, verschlüsselte Nachrichten an Gruppen zu senden.“
3 „Gefällt mir“
Ich glaube nicht, dass es derzeit möglich ist, verschlüsselte PMs an Gruppen zu senden.
2 „Gefällt mir“
Bedeutet das, dass die Gruppen-Mailbox kaputt geht? Und/oder funktioniert das Einladen einer Gruppe zu einer PM nicht mehr?
Das war von vornherein nicht möglich.
Muss ich hierfür einen Fehlerbericht einreichen, da es kaputt ist?
Alles scheint aktiv zu sein, bis auf die normale Verzögerung beim Öffnen, aber PMs sind nicht verschlüsselt.
1 „Gefällt mir“
Es ist nicht nötig, es zu überpfostieren, aber wenn Sie es lieber als #bug-Bericht und nicht als #support-Anfrage behandeln möchten, können Sie diese Richtlinien befolgen und es dann neu kategorisieren - Writing an effective bug report
Es ist jedoch erwähnenswert, dass sowohl Fehlerberichte als auch Supportanfragen Zeit brauchen können, um an Fahrt zu gewinnen, insbesondere am Wochenende.
5 „Gefällt mir“
:mega: Leider wird die Unterstützung für discourse-encrypt nach der nächsten stabilen Kernveröffentlichung im ersten Quartal 2025 aufgrund der relativ geringen Akzeptanz und der hohen Wartungskosten eingestellt.
Der Originalbeitrag dieses Themas wurde mit weiteren Informationen aktualisiert, und wir werden eine automatische Warnung für Administratoren betroffener Websites einführen.
14 „Gefällt mir“
Hoffnung auf zukünftige Entwicklung. Dies ist ein sehr wichtiger/nützlicher Punkt in den Bereichen Daten/Blockchain/Sicherheit.
7 „Gefällt mir“
10 Beiträge wurden in ein neues Thema aufgeteilt: Keine Themen und PMs für Administratoren anzeigen, es sei denn, sie sind Teilnehmer
Fortsetzung der Diskussion von Discourse Encrypt (veraltet):
Die Zeit ist gekommen und das neueste Discourse-Update scheint mit Discourse Encrypt inkompatibel zu sein.
Unsere Symptome sind, dass niemand auf einen Beitrag antworten kann; das System beginnt, die Antwortansicht zu laden, schafft es aber nie, den eigentlichen Editor zu laden.
Das Deaktivieren von Discourse Encrypt beseitigt das Problem, das erneute Aktivieren bringt das Problem zurück.
Da dieses Plugin veraltet ist, melde ich es nicht als Fehler, sondern nur, damit andere dieses Verhalten erwarten können.
Außerdem, wenn jemand Ressourcen kennt, auf die wir für Personen verweisen könnten, die verschlüsselte Nachrichten herunterladen und offline entschlüsseln möchten, wäre das eine Hilfe.
5 „Gefällt mir“
