nathank
(Nathan Kershaw)
June 5, 2024, 7:01pm
24
I took a look at that at the same time, but couldn’t work out how to effectively target the right bit of HTML to hide it.
My issue was that I can’t seem to make SASS variables work in selectors.
If I could work out how to do that, could also make it compatible with alternate lock icon.
Glad this was bumped, I’ve had multiple users ask me how they can use a section (that they’ve always been able to use) because they just assume lock=can’t use this.
nathank
(Nathan Kershaw)
June 6, 2024, 12:38pm
26
You can use this TC to change the icon to whatever you like:
I (used to) use unlock-alt for the very reason you state - until I developed the need to hide them for some categories!!
Lilly
(Lillian Louis)
July 28, 2024, 5:38pm
28
This has been merged. Thanks @nathank .
edit: also updated the about info
nathank
(Nathan Kershaw)
July 29, 2024, 12:39am
29
Discovered a regression! When I put in a category/subcategory, it was breaking the TC due to the change above corrupting the CSS.
Fresh PR now (also tidies up something else I missed):
Lillinator:main ← nathan-nz:main
opened 12:37AM - 29 Jul 24 UTC
Fix subcategory regression (category/subcategory input was breaking TC)
Also … ensure Discourse Category Headers TC compatible with staff setting
Lilly
(Lillian Louis)
July 29, 2024, 12:49am
30
Merged. thanks Nathan. I didn’t even notice. I loaded it into my test instance and had a quick look, but I didn’t see any errors and it seemed to be working as expected (but admittedly didn’t check subcategories ).
nathank
(Nathan Kershaw)
July 30, 2024, 5:29am
31
And another one!
This one adds the ability to cope with alternative lock icons (from Category Icons ), and tidies up another loose end with the Discourse Category Headers .
opened 05:27AM - 30 Jul 24 UTC
Adds compatibility with the alternative lock icons from github.com/discourse/dis… course-category-icons
Also includes a minor buff to the Discourse Category Headers compatibility
Lilly
(Lillian Louis)
July 31, 2024, 12:42pm
32
Merged Nice add - thanks!
I really need to spend some time and finish getting the category list_type chooser working. I just need to get a working findby() function.
Stephen
(Stephen)
April 3, 2025, 6:02pm
33
Unsure if this is a regression, but noticed today that noticed that the lock icon appears next to category names when Show subcategory list above topics in this category. is selected.
Lilly
(Lillian Louis)
April 7, 2025, 2:39pm
35
where are you seeing lock icon when Show subcategory list above topics in this category is enabled? I don’t see it…
I have the general/photos subcategory set as private and hiding the badge:
I tried with rows and boxes but still couldn’t see a repro.
Stephen
(Stephen)
April 7, 2025, 8:37pm
36
Rows with featured topics works. Boxes with featured topics is where it’s broken.
Lilly
(Lillian Louis)
April 7, 2025, 9:10pm
37
can you post a screenshot? i’m still not able to get a repro with Boxes with featured topics enabled:
This has stopped working for me after a recent update (I think today but I’m not 100% sure, I just noticed now for the first time)
I think because of this recent change?
Yea that did it you can just add
.badge-category__wrapper [class*=“d-icon-category.restricted”] {
display: none;
Via CSS. You obviously lose a couple things like the staff toggle from the plugin but it works.
It’s almost becoming a part time job to figure out how to revert all these little changes every couple updates I’m getting scared to press the button
Lilly
(Lillian Louis)
July 12, 2025, 9:56am
42
thanks for letting me know, I’ll have a look at it this week.
Lilly
(Lillian Louis)
July 17, 2025, 10:33pm
45
merged and fixed! you’re awesome thank you!
works great. the component could probably use some lovin’ at some point, especially to make it a bit easier to enter the categories.
