2024-04-09 @pfaffman edited this to say that this is no longer necessary, as the current NGINX config in the standard install redirects everything to
https://HOSTNAME
. You can test this by entering your IP address and see that it gets redirected. If you want multiple domains pointed to your server, you probably want them to have valid https certificates. To do that, follow instructions at Set up Let’s Encrypt with multiple domains / redirects.
So you want to redirect domain(s) to your Discourse instance? Great, let’s get started!
In this tutorial we’ll show how to redirect www.example.com
and example.com
to talk.example.com
Update DNS Record
Update the A record for the domain(s) you want to redirect to original domain.
Edit Configuration FIle
Open configuration file app.yml
. From console, run these commands:
cd /var/discourse
git pull
nano containers/app.yml
Configuration file will open in nano editor. Search for hooks (with Ctrl+W) in the file:
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
Add after_web_config
block to the hooks
(proper indentation is important):
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
after_web_config:
- replace:
filename: /etc/nginx/nginx.conf
to: |
server_names_hash_bucket_size 64;
sendfile on;
- file:
path: /etc/nginx/conf.d/discourse_redirect_1.conf
contents: |
server {
listen 80;
server_name example.com;
return 301 $scheme://talk.example.com$request_uri;
- file:
path: /etc/nginx/conf.d/discourse_redirect_2.conf
contents: |
server {
listen 80;
server_name www.example.com;
You can add as many file
blocks as you want, depending on number of domain(s) you want to redirect:
- file:
path: /etc/nginx/conf.d/discourse_redirect_3.conf
contents: |
server {
listen 80;
server_name discourse.example.com;
Modify the file name discourse_redirect_3
and domain name to which you want to redirect discourse.example.com
as per your need.
Note that original domain name talk.example.com
will remain same in all file
blocks.
After completing your edits, press Ctrl+O then Enter to save and Ctrl+X to exit.
Rebuild Container
Run this command:
./launcher rebuild app
Congratulations, that’s it! Try visiting example.com
and www.example.com
, they both will redirect to talk.example.com
