The release notes for 2.4.0.beta9 make various references to sub-sub-categories.
Are these actually enabled in this release, or are they coming soon?
On a related point is there a roadmap for future releases available anywhere?
They are currently behind a hidden site setting, max_category_nesting. Should you wish to test them out, modify the site setting via the console to 3 instead of 2.
Sure, see the releases category for a high-level overview of planned features.
Great, thanks - I was searching for roadmap because I assumed that releases were what had already been released… :doh: (wot, no Homer emoticon! )
Is there any reasonable chance this setting will be going away? In other words, how “safe” is it to use for production use as a data structure, even if the UX changes significantly?
لا، ليس هناك. هذا الإعداد سيبقى. لقد اخترنا إخفاءه لأننا نريد تشجيع المواقع على التفكير بعمق في بنية المعلومات (dfn) الخاصة بها، وما إذا كان بإمكانهم جعلها تعمل مع مستوى واحد فقط من الفئات الفرعية. كما أن تجربة المستخدم لهذا التغيير لا تزال قيد التطوير بينما نعمل على ضبط كل التفاصيل.
Yeah agree, that makes very good sense. We are only considering it for internal administrative type stuff that already has a lot of hierarchy, and those categories would be hidden from non-staff.
Quick guide to set it from 2 (default) to 3 via the console:
cd /var/discourse/
./launcher enter app
rails c
read current value:
[1] pry(main)> SiteSetting.max_category_nesting
=> 2
write new value:
[2] pry(main)> SiteSetting.max_category_nesting = 3
=> 3
6 posts were split to a new topic: Cannot move sub-sub-category from UI
Hello jomaxro, whatever can you teach me up level category to 4 or up to 5?
There is no support for category nesting greater than 3.
This seems like an awkward implementation for users. After setting up sub categories and then later wanting to move them, I ran across this level restriction. I had to adjust my implementation as a result.
And now I see that it’s possible to have more levels … but (a) the feature is hidden and undocumented and (b) it’s still limited to 3.
I appreciate the update and work, but just don’t understand the restrictions and how they’re supposed to make sense to implementers.
We haven’t designed the UI or tested performance beyond 3 category levels, so we don’t support it. Supporting 3 is meant to cover some exceptions and wasn’t intended to be the norm, which is why it’s not easily discoverable.
أواجه هذه الخطأ:
يمكنني إنشاء موضوع في فئة فرعية فرعية (A) عندما أكون داخل الفئة A، ولكن في الصفحة الرئيسية عند إنشاء موضوع، لا يعرض واجهة المستخدم لاختيار الفئة جميع الفئات الفرعية الفرعية (بما في ذلك A)
لقد قمت بترقية Discourse إلى أحدث إصدار.
لذا، لقد اكتشفت خطأً فادحًا يتعلق بالفئات الفرعية من المستوى الثاني.
بعد إنشاء فئة، ثم إنشاء فئات فرعية، دخلت إلى الفئة، وسمح لي بتعيين فئة فرعية منها كوالد لها.
