In a private Discourse forum that requires login, users occasionally see a banner stating “Due to extreme load, this is temporarily being shown to everyone as a logged out user would see it.” meriksson points out this is misleading — since logged-out users can’t view the site at all — and raises concerns about confusion and perceived security issues. neounix explains the banner is triggered by a cookie (dosp) tied to server queue delays, not overall CPU or memory load. codinghorror and sam agree the message is inappropriate for private sites and suggest replacing it with a more accurate “site is overloaded, try again later” blue screen. sam initially wanted to wait for another report, but after anon82467725 confirmed similar issues on a small private site — including 502 errors and misleading banners — codinghorror urged action. sam confirmed the change will be included in the next release. The threshold for triggering the warning can be adjusted via DISCOURSE_FORCE_ANONYMOUS_MIN_QUEUE_SECONDS and DISCOURSE_FORCE_ANONYMOUS_MIN_PER_10_SECONDS, and adding more unicorn workers may help prevent overload. The key takeaway: private sites should not display misleading anonymous-user banners during load spikes — a clearer, more accurate message is coming.
Now and then we get this notification at the top of our forum:
I have a few observations and questions about this:
First, the server does not seem to be under extreme load. The last time I saw the warning our server monitoring showed that CPU load peaked at 24%, memory usage was just above 50% etc. As far as I know, no noticeable decrease in performance for users. So I wonder: What is the threshold for this warning and is it reasonably calibrated?
Secondly, and more importantly for me, the forum I run is completely private. Logged out users can not see anything except the login page. So the notification is incorrect, i.e. the page is not shown as a logged out user would see it, because such a user would not be able to see it at all. This has created confusion a few times because it has been taken to imply that the posts of our private forum are suddenly available to unauthorized users. I was myself quite alarmed the first time I saw it and from time to time I get questions about it from users.
Perhaps this warning should be rewritten? Or changed/disabled for private forums?
Is it possible to disable it for a particular forum?
def initialize(app, settings = {})
@app = app
def call(env)
helper = Helper.new(env)
force_anon = false
if helper.should_force_anonymous?
force_anon = env["DISCOURSE_FORCE_ANON"] = true
helper.force_anonymous!
Reference:
See also:
MIN_TIME_TO_CHECK = 0.05
ADP = "action_dispatch.request.parameters"
def should_force_anonymous?
if (queue_time = @env['REQUEST_QUEUE_SECONDS']) && get?
if queue_time > GlobalSetting.force_anonymous_min_queue_seconds
return check_logged_in_rate_limit!
elsif queue_time >= MIN_TIME_TO_CHECK
if !logged_in_anon_limiter.can_perform?
false
I am going to wait here for 1 more independent complaint.
Best we can do under extreme load, for “requires login” sites, is simply to render a blue screen saying “site is overloaded, try again later”. Would like to wait a bit before adding this and see 1 more complaint.
It is happening on a very small private Discourse community I visit often. Gave me a 502 bad gateway nginx error, then it wouldn’t load at all. Eventually, it loaded, but it showed me the aforementioned banner message.
