跳转到第一个未读帖子的功能
Continuing the discussion from How should I disable automatic redirection to the Last reply?:
Maybe doing both of those is overkill… The first one seems more useful.
Here are a few mockups:
  1. First Unread post is before you:
  2. First Unread post is after you:
  3. Simpler alternative
    Pre-populate number in the “go” box with the first unread post:
EDIT just found this old topic discussing some similar stuff:
I personally find all these confusing. I don’t want to end up with one of those interfaces that’s just really full of butons.
3 is cleaner but confusing as most of the time that field is pre-populated with the current post.
I think there is likely a better solution to this problem.
2 个赞
I personally think this work should be on hold till we implement a custom scrollbar.
A custom scroll bar has a ton of other advantages, it can use colors to denote areas that are unread, it can display month name or year to the left of the scrollbar as you scroll around. It can be virtual so it can encompass the full topic. It allows us to control scroll position without complex browser hacks.
6 个赞
Totally agree if there are plans to eventually do a custom scrollbar!
我重新开启了这个话题,因为它让我想起了讨论中提到的问题的另一种解决方案:
1 个赞
也许我们应该合并它,因为这本质上是同一个功能请求?
