| Summary | Discourse Checklist allows checkboxes to be added to posts with simple Markdown | |
| Repository Link | https://github.com/discourse/discourse-checklist | |
| Install Guide | How to install plugins in Discourse |
Features
With this release comes a few enhancements.
You can disable the plugin in its entirety from the Admin > Settings area (strike through still gets processed, but the checkboxes won’t render and won’t be clickable)
You can keep checking/unchecking boxes on the same post without having to refresh the page.
Any issues should be reported either here. I also welcome translation file PRs, or general enhancement PRs.
Usage
Create a checkbox with the following syntax:
[]or[ ]for an unchecked box -
[x]or[X]for a checked box
Special thanks
- @lightyear for creating the initial version
- @cpradio for porting it to our new patterns and maintaining it for years!
CHANGELOG
TODO
If you were running this plugin prior to 2020-07-23T05:00:00Z, you may need to run
rake discourse_checklist:migrate_old_syntaxfrom your app container to convert to the new checkbox are format in Markdown.Caveat: this rake task only changes occurrences at the beginning of a line. Other instances may need to be manually updated.
