ميزة الصفحة الرئيسية
We have started testing this component today and noticed that the featured topics are in the order as they would appear in the Latest view - that is, the order will change as soon as anyone posts a reply to one of these topics. We’d like to be in control of these topics, and have them ordered by tagging date (with the most recently tagged first). Is this possible?
إعجابَين (2)
I posted a request on #marketplace to address sorting by tagging date. Fingers crossed!
إعجابَين (2)
I’ve made some updates!
  • You can now choose to show up to 5 topics (6 didn’t quite fit).
  • If there are no topics with images available the component does not display.
  • By default the topics now appear in the order they were created, so it will show the most recent topics (this allows admins to control positioning better). There’s a theme setting you can disable (sort_by_created) if you’d rather have these sorted by latest activity.
  • I switched the plugin-outlet this uses, so the topics now appear below site banners
9 إعجابات
Great @awesomerobot, now it is perfect. No more loading bar, when no topics are featured :grinning:
إعجابَين (2)
Very nice and useful new features, thanks! :+1:
3 إعجابات
Hey, I noticed you removed the ‘Show on All’ option? Was that on purpose? We’d rather like to keep it :slight_smile:
إعجابَين (2)
It was intentional; moving the plugin outlet made it harder to keep the all option… and I wasn’t sure if anyone was using it.
Anyway, it’s back now!
One downside is that there’s not an easy way to keep the topics below the banner and use the all option at the same time. Also note there’s an additional setting ,above main container, that you’ll want to enable when using all.
إعجابَين (2)
Hello !
Thank you so much !
With these last functions the plugin becomes essential :slight_smile:
Could there be a setting to choose which topic will be displayed on mobile?
Or better, the possibility of having a topic only on mobile and others only on Desktop? (or both if necessary)
Thank you !
إعجاب واحد (1)
Hello, how do you select the topics to be displayed in the 3 featured topics in the forum?
The theme will feature the three most recent topics tagged featured. You can change which tag it is looking at in the settings.
إعجابَين (2)
thx. can I also convert the 3 teasers into static links that link to the website or is there a similar component?
@sebastianzepper If you are looking for something static, maybe Versatile Banner works better for you?
Sliders are actually just unnecessary bloating, because users just don’t use them. Sliders make a site just heavier and are more or less just old hype than something needed…
But sure, it should or would be an option if a webmaster wants to use such thing for some reason.
In the bigger context - everything that makes harder to reach real content - meaning one mile long scrolling :wink: - is always bad idea. Same thing than why e-commerce tries to find shorter way from product to checkout.
Yes, I know - off topic. Sorry.
إعجاب واحد (1)
كيف يمكنني عرض هذا في صفحة الوثائق؟ يظهر في صفحات القائمة العلوية الأخرى ولكن ليس في الوثائق.
شكرًا لك
رياكس.
هل من الممكن تنسيق عنوان الموضوع ليظهر فوق الصورة، محاذياً للقاع، مع نسبة شفافية بسيطة للخلفية؟
سيؤدي ذلك إلى توفير المساحة الرأسية في الحالات التي تكون فيها الصور مرغوبة، ولكن لا بأس بإظهارها مع نص متداخل.
مرحبًا كريس،
هل من الممكن اختيار الخيار ليظهر في موقع التصنيف بدلاً من الصفحة الرئيسية؟
إعجابَين (2)
نعم، يجب أن تتمكن من القيام بذلك مع قليل من تنسيقات CSS:
.featured-topic-wrapper .featured-topics .featured-topic {
  position: relative;
.featured-topic-wrapper .featured-topics .featured-topic h3 {
  position: absolute;
  bottom: 0;
  background: #ffffffaa;
  padding: 0.2em;
  width: 100%;
ليس من الممكن مع مكون هذا القالب، لكن إصدار مخصص للتصنيفات يبدو كطلب معقول يمكنني دراسته في وقت ما في المستقبل.
5 إعجابات
شكرًا جزيلاً لك! يبدو رائعًا.
إعجاب واحد (1)
هذا يمكن استخدامه في الفئات. يمكن استخدامه أيضًا مع هذا.
إعجابَين (2)
هذا رائع حقًا، لقد زدت عدد المشاركات إلى 10 ولكن أريد فقط عرض 5 على الصفحة الرئيسية وإضافة شريط تمرير لـ 10 أخرى، هل يمكنك مساعدتي في ذلك، لقد أضفت
<!-- Left and right controls -->
  <a class="left carousel-control" href="#myCarousel" data-slide="prev">
    <span class="glyphicon glyphicon-chevron-left"></span>
    <span class="sr-only">Previous</span>
  </a>
  <a class="right carousel-control" href="#myCarousel" data-slide="next">
    <span class="glyphicon glyphicon-chevron-right"></span>
    <span class="sr-only">Next</span>
  </a>
</div>
ولكن لا أعرف كيف أدمجها مع الكود الخاص بك
@awesomerobot
4 إعجابات
