Now I want to set up a Discourse forum for production use.
what should I do? ![]()
(like: https://discourse.example.com)
Setting up a Discourse forum for production use
sysdl132 wants to set up a Discourse forum for production use, but is having trouble accessing the installation instructions. merefield suggests following the instructions on GitHub, but sysdl132 is behind the âGreat Firewallâ and cannot access the site.
merefield recommends using a local provider or a VPS with Ubuntu 18.04. sysdl132 asks for VPS server recommendations, and schleifer suggests Vultr, Scaleway, AWS Lightsail, and OVH Cloud.
sysdl132 considers installing Discourse on Yunohost, but Stephen advises against using third-party installation packages. hawm shares a link to a Discourse community for Chinese users, but merefield questions its authenticity.
riking suggests using Alibaba Cloudâs VPS offering, which may be a more suitable option for users in mainland China. sysdl132 considers using Yunohost, but has not installed it yet.
Follow the instructions here: discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
Are you behind the âgreatâ firewall?
It can be installed on most VPSâs with Ubuntu 18.04 offerings. Try a more local provider.
any more VPS server is recommended?(except digitalocean)
Plenty, but maybe the local regime doesnât regard them like we do in the West, so even if they are not blacklisted now, they soon might be.
I would recommend you use something within the walls.
Perhaps a local Discourse admin can chime in.
Thanks for your answer.Iâll try another server soon.
Hereâs another relevant Topic: Our Discourse is blocked by The Great Firewall of China, any tips? - #3 by singmajesty
Seems they were using Linode for a while, then âŠ
I can try it on Yunohost! GitHub - YunoHost-Apps/discourse_ynh: Discourse package for YunoHost · GitHub
Discourse for Chinese
https://meta.discoursecn.org/
We canât support third party installation packages here.
That installation doesnât use docker which is also unsupported. It appears to be for ARM processors.
You need to find a host where you can use the standard installation method.
Is that an official or officially sanctioned CDCK site, or a rip-off?
He make the community, i think he was contact someone in the @team before?
There are no officially recommended VPS providers besides Digital Ocean.
Any hosting service which provides a standard Ubuntu image will likely work using the same instructions. Some examples would be:
- vultr
- scaleway
- AWS lightsail
- OVH cloud
Depending on your ISP/city some or all of those may also be blocked. (Even if not blocked, performance from inside the Mainland will be wildly variable for your users.)
[NOT SPONSORED, NOT THE OFFICIAL OPINION OF ANYONE]
Iâm pretty sure Alibaba Cloud has a VPS offering. Thatâs probably the first place you should be checking, and would also allow you to have servers outside the mainland in case you have an international audience.
I think I can use yunohost,but not installed right now.
