The discussion centers on how Discourse announces new users, with Derrek suggesting replacing the gender-neutral “them” with the user’s actual name for grammatical and inclusive clarity. Moin-1 notes the German translation uses “the new member” as a neutral alternative and invites comparison with other language versions. HAWK questions whether the current system needs fixing, while sam clarifies that all strings, including this one, are editable in the admin panel — though no global change is planned. Heather_Dudley defends the use of singular “they,” citing authoritative sources like APA Style, the OED, and Grammarly, noting it’s grammatically valid, historically rooted (since at least the 1500s), and increasingly standard — especially when gender is unspecified. She acknowledges that site admins can customize the message but argues that replacing “them” with the name isn’t more grammatical, just stylistically different. The conversation reflects a balance between user preference, linguistic convention, and platform flexibility.
Singular they is not ungrammatical; while some style guides have been slow to catch up to current convention, it is acceptable and understandable for most, if less common, but it is quickly catching up.
If you’d like to make the change your site, that’s fine, but it is not more grammatical to repeat a name to avoid using a common gender-neutral term that’s been around since at least the 1500s. It’s a completely grammatically acceptable default gender-nonspecific pronoun that’s a good choice for a default when gender is not otherwise specified.
