Configure Discourse to use a separate PostgreSQL server
Let’s say you’re using AWS RDS, or an existing PostgreSQL server managed elsewhere. It’s fairly straightforward to get Discourse to use such a setup, without needing to grant superuser privileges to anything that Discourse itself runs. Here’s how.
Prerequisites
Discourse requires PostgreSQL’s major version to match what we ship with in our docker images; if you try to run on a newer or older version, it might work, but we don’t guarantee it, and if something breaks in the future, you get to keep both pieces. We also require some extensions that are distributed in the postgresql-contrib package (or its equivalent). You will also need the pgvector extension (postgresql-<version>-pgvector package), which is required by the Discourse AI plugin that ships with Discourse core.
Randomly generate a password for the connection (20+ characters). In this guide, we’ll use s3kr1t as a placeholder.
Setup the DB
As a database superuser, run the following:
CREATE USER discourse PASSWORD 's3kr1t';
CREATE DATABASE discourse OWNER discourse;
\c discourse
CREATE EXTENSION hstore;
CREATE EXTENSION pg_trgm;
CREATE EXTENSION unaccent;
CREATE EXTENSION vector;
That’s all that has to be done to prepare the DB for use by Discourse.
Configure Discourse
Get Discourse setup in the usual way, and then edit containers/app.yml as follows:
  1. Remove the line - "templates/postgres.template.yml" under the templates top-level key (towards the top of the file);
  2. Under the env top-level key, set the following:
     DISCOURSE_DB_USERNAME: discourse
     DISCOURSE_DB_PASSWORD: s3kr1t
     DISCOURSE_DB_HOST: <IP or hostname>
     DISCOURSE_DB_NAME: discourse
  3. You also need to set the following if your database doesn’t use the default port (5432):
    DISCOURSE_DB_PORT: <port>
    DISCOURSE_DB_BACKUP_PORT: <port>
  4. Rebuild with ./launcher rebuild app, and you should be good to go.
39 лайков
Install the docker version with a remote postgresql
Using a PGSQL database outside of Docker?
Installation on AWS
Is there a way to install Discourse without the provided scripts?
Error when attempting install
Installation Help required
pgSQL root access - without? (docker)
Database Replication
Using Discourse with external PostgreSQL and Redis
Switching to another Redis instance?
Can I install Discourse with my own Redis and Postgres?
Running Discourse with pg_bouncer and a separate DB
Improve my DO droplet setup
How to provide HA
I want to keep PostgreSQL database on separate server [standard docker install]
Simplified Discourse install?
How do you scale discourse horizontally?
Running discourse with Postgres running in docker
Error setting up with separate Redis
Error while connecting database from aws postgresql 10.1
Migrate quickly to separate web and data containers
Why is "rebuild" so tightly coupled to container run status?
External postgres setup not working
Discourse Image Builder for Gitlab CI/CD Pipelines
Not using volumes (or automatically using S3) when hosting with Docker
Which versions of AWS Aurora Postgres are supported?
Move from standalone container to separate web and data containers
Moving postgres db to central db server: build error
Search no longer works after 3.1.0.beta1 update
How to resolve Pups exec errors during Discourse bootstrap
Any other locations where database connection IP / hostname set other than DISCOURSE_DB_HOST in app.yml?
Can Discourse Support a Shared Forum for Two Websites with Distinct Styling?
Improving Instance Performance (Megatopics, Database Size and Extreme Load)
Separate psql server / migrate
Discourse Database Question/Support
Error executing 'postInstallation': Purging temp files
Relation "selected" does not exist with external Postgres
Stateless Discourse Using AWS RDS/S3
Multiple Daily Backups
Rebuilding gives db:migrate error due to broken plugin
Can I use a later version of Postgres than Discourse?
Trust level freeze
Multiple backup schedules
There is an additional setting, DISCOURSE_DB_PORT, which can, naturally, configure the TCP port number. @mpalmer please update the post?
Thanks
This isn’t supposed to be a comprehensive description of every possible way you can configure your database connection, rather it’s a quick howto to make things a bit easier.
2 лайка
Is there somewhere more authoritative for this documentation? I even tried (unsuccessfully) to track down the source code for this…!
Thanks
2 лайка
The discourse_docker repo is where all that lives.
2 лайка
Thanks for the pointer, I’m embarrassed to admit I’ve gone through almost an entire setup without realising the wealth of documentation on that page.
That said, the only reference to DISCOURSE_DB_PORT is in web.template.yml: Repository search results · GitHub
3 лайка
Yes, it could probably stand to be promoted into the default “web_only” template, with a suitably explanatory comment. PRs welcome!
3 лайка
Hi, first thanks for this guide. I try to setup external postgresql on the same machine, where docker installed. Do I need to bind port of my external postgresql 5432 to docker? Could anybody assist how to do it, using Discourse configuration file?
Your question doesn’t make any sense. You don’t bind external listening ports to Docker.
1 лайк
I follow the instruction a the top. First I set up an ordinary docker, it works. Then I want to switch the application to external postgres. When I rebuild the app, I get an error
Is the server running on host "127.0.0.1" and accepting TCP/IP connections on port 5432?
My server has not a FQDN yet, I use 127.0.0.1 as a DB host. The database is listening on 127.0.0.1:5432, I am able to connect with psql. Where am I wrong? I tried to play with pg_hba.conf but no success, of course.
Hi guys, possible of my personal server configuration or what else.. But I found a solution by running a docker in hosted mode (not bridged as default):
/var/discourse/launcher rebuild app --docker-args --net=host --skip-mac-address
After that the discourse engine could connect to external postgres database, run at 127.0.0.1:5432. Default bridged mode does not allow docker to access ports listening at the host without tricks.
Hope this might help somebody.
1 лайк
When I run ./launcher rebuild app, I get this error PG::ConnectionBad: timeout expired during the bundle exec rake db:migrate. Has anyone comes across this issue? I can successfully access the database with a postgres client.
1 лайк
I have not tried this yet.
Here it is suggested to remove web.template.yml but i see bunch of other stuff happening in discourse_docker/templates/web.template.yml at master · discourse/discourse_docker · GitHub
What about that ?
No it doesn’t.
5 лайков
Can you take the same approach for Redis?
remove “templates/redis.template.yml” & add a line in the app.yml file for DISCOURSE_REDIS_HOST
Thanks in advance
Todd
Is there an obvious benefit that I’m maybe missing?
(I assume running redis on a separate machine will just add unwanted latency if nothing else)
Just that its managed & 1 less thing to worry about
You don’t have to worry about redis that ships with discourse. I haven’t seen it failing on me in the last 1 year of self hosting discourse.
2 лайка
Thanks @itsbhanusharma,
Do you know what the process would be even if I did?
This article, albeit a little old says to add
which is the same format as the article you so kindly mentioned, so that all makes sense.
Just not sure where to put it (maybe underneath other changes made to the app.yml file or maybe in the "templates/redis.template.yml")
and also
what if any lines or files need to be deleted
Thanks
Todd
That variable should go into the file where you declared postgres variables. Just be warned that exposing redis for a production environment is lethal. (Because of poor security practices of redis itself)
