Saif
(Saif Murtaza )
2025 年10 月 20 日 19:03
91
Period : 2025-10-13 to 2025-10-20
Overview
This week, AI discussions spanned search UX improvements , localization quirks , embeddings configuration , and bug fixes post-upgrade. Administrators and developers delved into making AI search results more discoverable, tweaking Gemini embeddings settings, and resolving errors introduced in the 3.6.0 beta. Community members also explored using Discourse for niche groups, tested local LLM integrations, and reported composer glitches with pasted images. Major themes hit #ai-support , ai-search , Bug , Community , and UX .
“We just deployed a big improvement to the underlying tech that powers semantic search…” — Falco ref
“Many users are still wary of AI so they don’t toggle the switch…” — RBoy ref
Interesting Topics
Hiding XX results found using AI—enable toggle by default (Support ai ai-search )
RBoy kicked off the thread by noting that AI search results were hidden by default. NateDhaliwal pointed to existing docs ref , and Falco explained how it now auto-toggles when native results are missing ref . A temporary theme script to force the toggle was also shared ref .
Falsche Übersetzung, wenn post locale = UI locale (Bug ai dynaloc content-localization )
Jakob_Naumann reported that English posts were showing up in German after a default-locale change ref . Falco recommended purging and re-creating the localization cache ref .
Gemini API Embedding Configuration Clarification (Support ai )
RBoy asked what sequence length maps to in the embedding settings and how to throttle API backfills to avoid 429 errors ref . Falco confirmed sequence length equals the model’s token capacity (2048) and pointed out the hidden ai_embeddings_backfill_batch_size setting ref .
Exploring Reranking Options for Discourse AI (Support ai )
In a longer-running thread, Falco rolled out a major semantic search improvement ref , expected to reduce reliance on external rerankers. tpetrov queried support for uploaded RAG documents versus forum topics ref , and Falco confirmed the change covers all embedding use cases ref .
Would this work for a community of women over 45+ (Community ai )
bessnlj wondered if Discourse with AI-powered search fits a niche dating/coaching site ref . tobiaseigen clarified that meta.discourse.org is for Discourse hosts but encouraged spinning up a trial for custom use ref and pointed to existing communities for inspiration ref .
Local Ollama is not working with the Plugin (Support ai )
Tikkel faced an “Internal Server Error” when Discourse called the Ollama service, despite successful cURL tests ref . Falco asked for container logs ref , and Tikkel confirmed that adjusting DISCOURSE_ALLOWED_INTERNAL_HOSTS syntax to use pipes solved it ref .
Gemini Embeddings Issue After Discourse Update to 3.6.0 Beta 2 (Support ai )
Upgrading to 3.6.0.beta2 broke embedding tests for RBoy , who spotted that Gemini’s old embedding-001 model was retired ref . He fixed it by switching to gemini-embedding-001 in the plugin settings ref .
Embedding error with 3.6.0 beta 2 (Bug ai )
A related bug, reported by RBoy , showed “invalid input syntax for type halfvec: “[NULL]”” when querying embeddings post-upgrade ref . This points to null-vector handling issues in the new release.
After sending the image, add this to the beginning of the message: [object InputEvent] (Bug ai )
kuaza discovered that copy-pasting images into the composer prepends an [object InputEvent] string ref . Uploading via the file selector avoids the glitch, leading to further UX tweaks.
How to solve discourse ai: No endpoints found that support tool use (Support ai )
whitewaterdeu saw a 404 “No endpoints found that support tool use” error testing OpenRouter’s qwen3-8b model ref . Disabling native tool integration resolved the issue ref .
Activity
Falco posted 7 times across:
Hiding XX results found using AI—enable toggle by default ,
Falsche Übersetzung, wenn post locale = UI locale ,
Gemini API Embedding Configuration Clarification ,
Local Ollama is not working with the Plugin ,
Gemini Embeddings Issue After Discourse Update to 3.6.0 Beta 2 ,
Exploring Reranking Options for Discourse AI ,
Exploring Reranking Options for Discourse AI .
RBoy posted 11 times in:
Embedding error with 3.6.0 beta 2 .
tobiaseigen guided new users in:
Would this work for a community of women over 45+ ,
Would this work for a community of women over 45+ .
Tikkel debugged Ollama integration with 3 posts :
Local Ollama is not working with the Plugin .
whitewaterdeu resolved model routing in:
How to solve discourse ai : No endpoints found that support tool use ,
How to solve discourse ai : No endpoints found that support tool use .
bessnlj explored community use with 3 posts in:
tpetrov inquired about RAG support in:
dennisjbr voiced interest in tiered AI access in:
Discourse AI .
Jakob_Naumann reported locale mismatches in:
Falsche Übersetzung, wenn post locale = UI locale .
NateDhaliwal added context on AI search toggles in:
Hiding XX results found using AI—enable toggle by default .
Thanks for reading, and I’ll see you again next week!
Saif
(Saif Murtaza )
2025 年10 月 27 日 19:01
92
{“content”:“每周 AI 活动摘要:2025-10-20 → 2025-10-27 \n\n—\n\n## 概述\n\n本周在 Meta 上的 ai 讨论涵盖了 API 故障排除 、内容本地化 、用户对翻译的反馈 以及插件错误修复 。\n\n在 Support 类别中,\u003ca class="mention" href="/u/Enit"\u003eEnit\u003c/a\u003e 通过在使用 REST API 创建主题时遇到 400 Bad Request Using API 错误,开启了一次深入探讨。\u003ca class="mention" href="/u/supermathie"\u003esupermathie\u003c/a\u003e 指向了 Discourse REST API documentation 并请求了身份验证详细信息 ref 。\u003ca class="mention" href="/u/Moin"\u003eMoin\u003c/a\u003e 随后请求了日志摘录 ref ,并澄清这是否仅仅是一个 API 问题,还是与 AI 插件有关 ref 。最终,当在 /logs 下出现了正确的日志 ref 后,这个谜团得以解决。\n\n在 #Site Management 前沿,Content Localization - Manual and Automatic with Discourse AI 的讨论中,\u003ca class="mention" href="/u/cmdntd"\u003ecmdntd\u003c/a\u003e 提议将 tl URL 参数提供给所有用户,而不仅仅是访客 ref 。\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 澄清目前它在全球范围内适用 ref 。\u003ca class="mention" href="/u/wenqin"\u003ewenqin\u003c/a\u003e 随后测试了该功能,并为多语言学习者建议了一个“默认(无翻译)”选项 ref ,而 \u003ca class="mention" href="/u/Moin"\u003eMoin\u003c/a\u003e 帮助找到了查看原始内容的切换按钮 ref 。Wenqin 确认该解决方案完美运行 ref 。\n\n#Community 中的 Multilingual user feedback on Automatic Translations 的社区反馈继续进行,\u003ca class="mention" href="/u/FINDarkside"\u003eFINDarkside\u003c/a\u003e 要求提供每种语言的翻译偏好设置。\u003ca class="mention" href="/u/NateDhaliwal"\u003eNateDhaliwal\u003c/a\u003e 澄清了 Support 查询标题为 我已关闭Discobot,但它仍然运行 的问题实际上是关于 AI Search Discoveries,可以在用户偏好设置中进行切换 ref 。\n\n在插件方面,性能调整和错误报告取得了进展。在 Discourse AI Failing to translate large number of posts and topics 中,\u003ca class="mention" href="/u/DevTeVe"\u003eDevTeVe\u003c/a\u003e 通过禁用流式传输提高了吞吐量。同时,Embedding error with 3.6.0 beta 2 被追溯到 ProblemChecks 的一个错误,并由 \u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 修补 ref 。一个功能请求——Hiding XX results found using AI - enable toggle by default —被移至 Feature 以便更广泛地讨论。\n\n—\n\n## 有趣的话题\n\n- 400 Bad Request Using API (Support rest-api ai ):Enit 的 API 调用返回了 400 Bad Request ,导致 supermathie 和 Moin 进行了身份验证检查、日志诊断和插件上下文澄清。\n- Content Localization - Manual and Automatic with Discourse AI (#Site Management ai content-localization ):cmdntd 和 Falco 讨论了是否将 ?tl= 参数公开给所有用户,wenqin 请求了“无翻译”默认选项,Moin 发现了时间线切换按钮。\n- Multilingual user feedback on Automatic Translations (Community ai dynaloc content-localization ):FINDarkside 汇总了用户对每种语言翻译偏好和选择退出控件的请求。\n- 我已关闭Discobot,但它仍然运行 (Support ai ):一个被误判的 Discobot 问题得到解决,NateDhaliwal 解释说这是 AI Search Discoveries 功能,可以在偏好设置中切换。\n- Discourse AI Failing to translate large number of posts and topics (Support ai content-localization ):DevTeVe 通过禁用流式传输提高了翻译的可靠性。\n- Discourse AI - Sentiment (#Site Management ai ai-sentiment content ):keegan 询问了关于调整情感阈值的问题,但得知它在代码中是固定的。\n- Hiding XX results found using AI - enable toggle by default (Feature ai ai-search ):tobiaseigen 建议默认启用 AI 结果隐藏切换按钮,以获得更简洁的用户界面。\n- Embedding error with 3.6.0 beta 2 (Bug ai ):sam 和 RBoy 报告了速率限制峰值和嵌入失败;Falco 禁用了 ProblemChecks 并发布了补丁 ref 。\n\n—\n\n## 活动\n\n- \u003ca class="mention" href="/u/Enit"\u003eEnit\u003c/a\u003e:主导了 API 深入探讨,发布了五条帖子——初步报告 ref ,插件上下文澄清 ref ,日志详情 ref ,解决方案确认 ref ,以及更广泛的 AI 内存讨论 ref 。\n- \u003ca class="mention" href="/u/supermathie"\u003esupermathie\u003c/a\u003e:提供了 API 文档指导 ref 。\n- \u003ca class="mention" href="/u/Moin"\u003eMoin\u003c/a\u003e:探查了日志 ref ,澄清了插件范围 ref ,指导了日志访问 ref ,并协助了本地化切换 ref 。\n- \u003ca class="mention" href="/u/NateDhaliwal"\u003eNateDhaliwal\u003c/a\u003e:翻译了语言支持见解 ref 和 AI Discoveries 设置帮助 ref 。\n- \u003ca class="mention" href="/u/wenqin"\u003ewenqin\u003c/a\u003e:测试了本地化视图 ref 并称赞了切换的用户体验 ref 。\n- \u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e:解释了全局区域设置行为 ref 并修复了嵌入错误 ref 。\n- \u003ca class="mention" href="/u/FINDarkside"\u003eFINDarkside\u003c/a\u003e:为用户控制的翻译提供了关键反馈 ref 。\n- \u003ca class="mention" href="/u/Jagster"\u003eJagster\u003c/a\u003e:强调了语言支持的局限性 ref 。\n- \u003ca class="mention" href="/u/keegan"\u003ekeegan\u003c/a\u003e:询问了关于情感阈值的问题 ref 。\n- \u003ca class="mention" href="/u/DevTeVe"\u003eDevTeVe\u003c/a\u003e:通过禁用流式传输优化了翻译吞吐量 ref 。\n\n—\n\n感谢阅读,下周再见!:)”, “target_locale”:“zh_CN”}
Saif
(Saif Murtaza )
2025 年11 月 3 日 19:01
93
每周AI活动摘要:2025-10-27至2025-11-03
概述
本周在meta.discourse.org上,#ai、 #content-localization、 #feature和 #support等板块的讨论非常活跃。从多语言翻译偏好 和对未披露的自动翻译 的担忧,到隐藏的配置设置和对AI驱动格式化功能的需求,社区深入探讨了Discourse AI如何才能更灵活、更透明。贡献者还处理了LLM错误 ,辩论了结构化输出 的要求,寻求AI功能的成本估算 ,并探索了嵌入的token限制 。总的来说,重点仍然是改善用户控制、提高可靠性和扩大提供商支持。
有趣的话题
多语言用户对自动翻译的反馈 (ai content-localization Community )
\u003ca class="mention" href="/u/MiikkaLaitila"\u003eMiikkaLaitila\u003c/a\u003e 在多语言用户对自动翻译的反馈 中询问了支持多种语言偏好 的情况,而\u003ca class="mention" href="/u/Moin"\u003eMoin\u003c/a\u003e 指出了现有的多语言偏好功能请求 。
高度侵入性和未披露的自动翻译 (translation content-localization UX )
\u003ca class="mention" href="/u/Ethaphu"\u003eEthaphu\u003c/a\u003e 在高度侵入性和未披露的自动翻译 中指出,Roblox Devforum上的每个帖子都自动翻译了,但没有明确的指示。\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 在第3条 中解释了翻译指示,\u003ca class="mention" href="/u/tobiaseigen"\u003etobiaseigen\u003c/a\u003e 同意在第4条 中需要改进信号,而\u003ca class="mention" href="/u/nat"\u003enat\u003c/a\u003e 在第5条 中调查了Roblox的自托管限制。
如何配置Ai translation backfill hourly rate的ai翻译? (ai Support )
\u003ca class="mention" href="/u/whitewaterdeu"\u003ewhitewaterdeu\u003c/a\u003e 在如何配置Ai translation backfill hourly rate的ai翻译 中遇到了缺少设置的问题,\u003ca class="mention" href="/u/NateDhaliwal"\u003eNateDhaliwal\u003c/a\u003e 在第2条 中分享了指南,解决方案由\u003ca class="mention" href="/u/Moin"\u003eMoin\u003c/a\u003e 在第4条 中揭示为一个隐藏设置,而\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 在第6条 中指出现在可以取消隐藏它。
使用AI格式化帖子内容的按钮 (ai Feature )
\u003ca class="mention" href="/u/hameedacpa"\u003ehameedacpa\u003c/a\u003e 在使用AI格式化帖子内容的按钮 中请求了一个AI格式化按钮 。\u003ca class="mention" href="/u/NateDhaliwal"\u003eNateDhaliwal\u003c/a\u003e 在第2条 中指出了现有的Discourse AI Helper ,并在第6条 中演示了一个自定义提示。
发生错误:在启用聊天之前需要默认LLM模型 (ai Support )
\u003ca class="mention" href="/u/viswanatha"\u003eviswanatha\u003c/a\u003e 在发生错误:默认LLM… 中遇到了重置错误,而\u003ca class="mention" href="/u/NateDhaliwal"\u003eNateDhaliwal\u003c/a\u003e 在问题解决之前在第2条 中链接到了现有线程。
我认为discourse-ai API需要回归 (ai Dev )
\u003ca class="mention" href="/u/MoRanYue"\u003eMoRanYue\u003c/a\u003e 在我认为discourse-ai API需要回归 中提议放弃结构化输出 以获得更广泛的提供商支持。\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 在第2条 中解释了结构化输出的重要性,而MoRanYue在第3条 中提供了类似XML的分隔符作为替代方案。
探索Discourse AI的重排选项 (ai Support )
\u003ca class="mention" href="/u/tpetrov"\u003etpetrov\u003c/a\u003e 在探索Discourse AI的重排选项 中测试了新的嵌入,\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 在第15条 中跟进了模型可用性。
使用discourse ai时出现嵌入警告“输入必须少于8192个token” (ai Support )
\u003ca class="mention" href="/u/whitewaterdeu"\u003ewhitewaterdeu\u003c/a\u003e 在嵌入警告… 中遇到了token限制,\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 在第2条 中解释了提供商规则,讨论一直持续到第6条 。
支持AI机器人为社区论坛配置… (ai Support )
\u003ca class="mention" href="/u/viswanatha"\u003eviswanatha\u003c/a\u003e 在支持AI机器人配置… 中分享了LLM和Persona设置,\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 在第2条 中建议使用工具强制搜索,并在第4条 中提供了模型推荐。
估算启用Discourse AI以获取相关内容和搜索的成本 (ai Support )
\u003ca class="mention" href="/u/SubStrider"\u003eSubStrider\u003c/a\u003e 在估算启用Discourse AI… 中询问了成本基准,\u003ca class="mention" href="/u/NateDhaliwal"\u003eNateDhaliwal\u003c/a\u003e 在第2条 中澄清了搜索与LLM的区别,而Falco在第3条 中概述了自托管选项。
活动
\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 在技术澄清方面发挥了主导作用,从高度侵入性和未披露的自动翻译 中的翻译指示、Ai translation backfill hourly rate 中的隐藏设置,到API回归讨论 中的结构化输出原理、token限制警告 中的嵌入建议,以及估算成本… 中的成本细分。
\u003ca class="mention" href="/u/Moin"\u003eMoin\u003c/a\u003e 提出了现有的解决方案并回答了支持查询:在自动翻译 中指出了多语言偏好,并在Ai translation backfill hourly rate 中揭示了隐藏设置。
\u003ca class="mention" href="/u/NateDhaliwal"\u003eNateDhaliwal\u003c/a\u003e 提供了指南和提示,链接到自动翻译 的内容本地化文档,在Ai translation backfill hourly rate 中回答了回填设置问题,并在格式化按钮请求 中提供了SEO友好的AI格式化技巧。
\u003ca class="mention" href="/u/whitewaterdeu"\u003ewhitewaterdeu\u003c/a\u003e 测试了功能并在多个线程中报告了bug,从Ai translation backfill hourly rate 中的翻译回填,到token限制警告 中的嵌入错误,以及ai翻译帖子时出错 中的翻译异常。
\u003ca class="mention" href="/u/hameedacpa"\u003ehameedacpa\u003c/a\u003e 在使用AI格式化帖子内容的按钮 中倡导格式化增强,并在第5条 中迭代了期望的输出。
\u003ca class="mention" href="/u/viswanatha"\u003eviswanatha\u003c/a\u003e 在支持AI机器人配置… 中分享了AI机器人设置详情,并在默认LLM模型错误 中报告了重置错误。
\u003ca class="mention" href="/u/MoRanYue"\u003eMoRanYue\u003c/a\u003e 在API回归讨论 中推动API灵活性,并在第3条 中建议了解析替代方案。
\u003ca class="mention" href="/u/MiikkaLaitila"\u003eMiikkaLaitila\u003c/a\u003e 在自动翻译反馈 中强调了多语言需求。
\u003ca class="mention" href="/u/nat"\u003enat\u003c/a\u003e 在自动翻译UX 中调查了外部实现。
\u003ca class="mention" href="/u/Ethaphu"\u003eEthaphu\u003c/a\u003e 在未披露的自动翻译 中强调了UX差距。
\u003ca class="mention" href="/u/tpetrov"\u003etpetrov\u003c/a\u003e 在探索重排选项 中测试了嵌入。
\u003ca class="mention" href="/u/SubStrider"\u003eSubStrider\u003c/a\u003e 在估算成本… 中发起了成本讨论。
感谢阅读,下周再见!
Saif
(Saif Murtaza )
2025 年11 月 17 日 19:04
96
Overview
Over the past week, the community dove into several translation and rate-limit challenges, as well as fresh plugin releases and AI helper configuration issues. Key themes included:
Below are the 10 most interesting topics from the week, followed by a breakdown of who said what .
Interesting Topics
AI translation backfill misconfiguration (Support ai content-localization )
In AI translation backfill not working after all settings configured , RBoy initially thanked nat for enabling backfill but encountered a “limit” exception in the logs, which nat traced to integer rounding in post 25 .
AI bot infinite loop and spamming (Support ai-bot )
wisewords reported that after creating a new persona the AI began delaying responses and posting repetitive spam in AI bugging out, having a mental breakdown , and Falco explained it was due to the LLM hitting an infinite generation loop at certain temperature settings in post 2 .
Staff override for translation max age (Feature translation ai content-localization )
jrgong requested the ability for staff to bypass the AI translation backfill max age days setting when manually translating older posts in post 1 , and Falco tested and confirmed the manual translation button already overrides this backfill restriction in post 3 .
Discourse llms.txt Generator Plugin released (Plugin ai )
kaktak introduced the Discourse llms.txt Generator Plugin in post 1 , which automates the generation of llms.txt files to improve forum discoverability by LLMs.
Resetting Proofreader settings (Support ai-helper )
bksubhuti sought guidance on restoring missing Proofreader options in the AI helper menu in post 1 , and Moin and OP resolved it by rebuilding after correcting trust level configurations in post 4 .
Missing language switcher after auto-translation (Support ai content-localization )
After successfully backfilling translations, EasyChen could not see the language switcher on translated posts in post 1 , with nat guiding them through enabling the site setting and checking post locale detection in post 2 and post 7 .
LLM and Discourse AI settings hidden (Support ai )
Nima1 reported missing LLM tabs in the AI plugin on a Persian-locale site in post 1 , and nat clarified that the “Discourse AI enabled” setting must be saved first to reveal the rest in post 2 .
Default LLM model dropdown empty (Support ai )
undasein was unable to select a default model due to an empty dropdown in post 1 , and NateDhaliwal pointed them to configure LLMs under “Plugins > AI > LLMs” in post 2 .
Gemini Pro thinking budget error (Bug ai )
RBoy encountered a “Budget 0 is invalid” error when setting a zero or negative budget for the gemini-pro-latest model in post 1 , and the team acknowledged they will investigate in post 2 .
AI model cost input restriction (Bug ai )
RBoy noted that the cost fields for AI model input and output prevent values below 0.1 in Can’t enter AI model cost of less than 0.1 , overriding entries like 0.075 back to zero.
Activity
Falco weighed in on AI translation backfill not working after all settings configured , AI bugging out, having a mental breakdown , and Staff should be able to override/ignore “AI translation backfill max age days” setting (also chipped in at post 4 ), as well as advising on Support for AI Bot to Configure for a Support the community forum .
nat was highly active, troubleshooting rate-limit errors on the backfill job in post 25 , post 27 , post 29 , and clarifying paid vs free tiers in post 33 , post 38 , and post 40 . nat also guided the override behavior for manual translations in post 3 and supported others in post 2 , post 5 , post 7 , as well as revealing the AI tab reveal trick in Can’t find Discourse AI and LLM settings .
kaktak unveiled the new Discourse llms.txt Generator Plugin .
Moin helped bksubhuti reset their Proofreader settings in How to reset Proofreader settings .
manuel closed the AI helper menu hiding issue on Android tablets by merging a fix in post 17 .
EasyChen investigated missing language switchers in post 1 , post 3 , and post 4 .
wisewords kicked off the week’s discussions by reporting the AI persona loop behavior in AI bugging out, having a mental breakdown .
undasein tested LLM settings and learned to configure them under Plugins > AI > LLMs, with help in Can’t choose default LLM model and post 3 .
RBoy posted extensively on backfill rate limits in post 24 , post 26 , post 28 , post 32 , post 34 , and post 35 , raised cost-limit bugs in Can’t enter AI model cost of less than 0.1 , and reported budget errors in Thinking budget for Gemini Pro .
jrgong initiated the staff override feature request in post 1 and suggested enhanced logging in post 5 .
Nima1 sought help finding AI settings on a Persian-locale site in Can’t find Discourse AI and LLM settings .
sam acknowledged the budget error report for Gemini Pro in post 2 .
NateDhaliwal resolved the default LLM dropdown issue for undasein in post 2 .
bksubhuti kicked off the Proofreader reset thread and later confirmed a rebuild fix in post 1 and post 4 .
tobiaseigen followed up on an embedding error in Error when translate post by ai .
viswanatha updated their configuration steps after guidance on AI persona tooling in Support for AI Bot to Configure for a Support the community forum .
Saif
(Saif Murtaza )
2025 年11 月 24 日 19:03
97
每周 AI 活动摘要 (2025-11-17 至 2025-11-24)
概览
在上周 ,meta.discourse.org 上的 ai 和 ai-bot 空间共产生了 36 条新帖子 ,涉及 5 个新主题 ,讨论了集成错误、垃圾邮件过滤、插件灵活性和内容格式化等问题。亮点包括:
本周的顶级贡献者是 \u003ca class="mention" href="/u/sam"\u003esam\u003c/a\u003e、\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e、\u003ca class="mention" href="/u/lilydjwg"\u003elilydjwg\u003c/a\u003e 和 \u003ca class="mention" href="/u/NateDhaliwal"\u003eNateDhaliwal\u003c/a\u003e。
有趣的主题
Google gemini-3-api helper API 响应错误 Bug ai ai-bot
\u003ca class="mention" href="/u/honeymoose"\u003ehoneymoose\u003c/a\u003e 发现了 Gemini 辅助调用中缺少 thought_signature 错误;\u003ca class="mention" href="/u/sam"\u003esam\u003c/a\u003e 在几天内实施了修复。
对 AI 垃圾邮件检测器的沮丧 Support ai spam
\u003ca class="mention" href="/u/lilydjwg"\u003elilydjwg\u003c/a\u003e 努力研究角色提示(persona prompts)和分词器(tokenizers);\u003ca class="mention" href="/u/nat"\u003enat\u003c/a\u003e 提供了可行的设置和最终解决方案。
关于 AI 插件选项的询问 Support ai
\u003ca class="mention" href="/u/beitmenotyou"\u003ebeitmenotyou\u003c/a\u003e 询问了使用本地 LLM(例如 Ollama)的情况,\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 和 \u003ca class="mention" href="/u/sam"\u003esam\u003c/a\u003e 展示了该插件与提供商无关的设计和免费模型提示。
AI 摘要泄露隐藏标签 Bug ai
\u003ca class="mention" href="/u/tvavrda"\u003etvavrda\u003c/a\u003e 注意到 AI 生成的摘要暴露了私有标签;该问题已被分派以快速更正。
使用情况未显示 LLM 模型 Bug ai
\u003ca class="mention" href="/u/RBoy"\u003eRBoy\u003c/a\u003e 报告称“使用情况”标签显示的是原始模型 ID 而不是配置的 LLM 名称;\u003ca class="mention" href="/u/sam"\u003esam\u003c/a\u003e 确认了对更清晰细分的请求。
使用 AI 格式化帖子内容的按钮 Feature ai
\u003ca class="mention" href="/u/jrgong"\u003ejrgong\u003c/a\u003e 和社区成员提出了关于自定义编辑器角色和格式化模板的想法。
Gemini Flash 2.5 图像 - 现已在 Discourse 上可用 Announcements ai
\u003ca class="mention" href="/u/sam"\u003esam\u003c/a\u003e 介绍了 Nano Banana 3 图像支持;\u003ca class="mention" href="/u/NateDhaliwal"\u003eNateDhaliwal\u003c/a\u003e 称赞了其质量的提升。
Discourse llms.txt 生成器插件 Plugin ai
\u003ca class="mention" href="/u/Ivan_Rapekas"\u003eIvan_Rapekas\u003c/a\u003e 分享了 llms.txt 生成器的初步测试,并请求思维导图(mind-map)格式化。
Discourse AI 中的 PDF 支持 #Site Management how-to ai
\u003ca class="mention" href="/u/kuaza"\u003ekuaza\u003c/a\u003e 询问了 PDF 的嵌入和处理,探讨了哪些模型最能处理附件。
Discourse AI – 大型语言模型 (LLM) 设置页面 #Site Management how-to ai
\u003ca class="mention" href="/u/beitmenotyou"\u003ebeitmenotyou\u003c/a\u003e 重新审视了缺失的 LLM 标签,并寻求配置界面的清晰说明。
活动
感谢阅读,我们下周再见!
Saif
(Saif Murtaza )
2025 年12 月 1 日 19:03
98
Overview
This past week on #discourse-ai saw a mix of new feature rollouts, in-depth configuration guides, localization debates, and crucial bug reports. keegan unveiled Improved Image Generation Support in Discourse AI , making it effortless to hook up OpenAI, Google Gemini, Flux, or custom providers for on-the-fly images. Hosting admins explored credit management options in Running Out of AI credits? as Discourse explained plan upgrades and fallback paths. Translators hashed out formality levels in KI Übersetzungen (formal, informal) , while broader localization topics bubbled up in Content Localization - Manual and Automatic with Discourse AI . Support questions ranged from third-party proxy setups in Does Discourse AI support third-party relay/proxy APIs (e.g., NewAPI)? to multisite PM bot regressions in AI Bot PM replies stopped working on one multisite instance . Community members also prototyped automations in AI Triaging & persona and pitched UX enhancements in AI supporting Micro-Features . Finally, key bugs like AI is being cutoff before it finishes writing and Search/Read Private not working for a Persona-driven RAG search on forums? kept everyone on their toes, with Chinese-language troubleshooting captured in 有关ai的问题 .
Interesting Topics
keegan announced Improved Image Generation Support in Discourse AI (Announcements ai ai-helper ), introducing a streamlined interface for configuring AI-powered image creation with presets for OpenAI’s GPT-Image 1, Google Gemini Nano Banana, Flux 1.1 Pro, Flux 2 Pro, or custom providers.
Discourse explained what happens when you Run Out of AI credits (#Hosted_Customers explanation ai ), detailing daily credit allotments, plan upgrade paths, and how to connect your own LLM to avoid service interruptions.
asa kicked off KI Übersetzungen (formal, informal) (Feature ai content-localization ), asking if German translations should default to formal “Sie” or informal “Du,” and Falco walked through creating a custom translation persona to suit a “per Du” community.
DevTeVe reported that the AI is being cutoff before it finishes writing (Bug ai ), sharing logs that show complete responses but a UI truncation issue, and sam traced a potential fix landed mid-week.
tom_eric asked whether Discourse AI supports OpenAI-compatible third-party proxies like NewAPI in third-party relay/proxy APIs (e.g., NewAPI)? (Support ai ), and whitewaterdeu demonstrated configuring custom LLM endpoints and personas to resolve 500-level errors.
Akunna_Ndubuisi experimented with AI Triaging & persona (Support automation ai ) to auto-categorize misfiled posts, with NateDhaliwal and RGJ guiding through triggers, logs, and a data explorer query to inspect AI audit records.
Neil_Evans uncovered a private search issue in Search/Read Private not working for a Persona-driven RAG search on forums? (Bug ai ), finding that read/search permissions must align between the user and persona, and testing parent vs. subcategory settings.
Naman_Gala reported that on one multisite instance the AI chat icon spawns a normal topic instead of a PM in AI Bot PM replies stopped working on one multisite instance (Support chat ai ), noting missing AI custom fields and seeking diagnostics on why it regressed.
iamcapote proposed AI supporting Micro-Features (Feature ai ), advocating for per-persona auto-greetings, internal system notes, and richer AI menu metadata (display names, tooltips, docs links) to make each persona self-explanatory.
派蒙pm from the Chinese community shared screenshots and 502 errors in 有关ai的问题 (Support ai ), asking for help troubleshooting AI connectivity, and offering to provide logs or configs for deeper analysis.
Activity
keegan (1 post, 11 likes) authored the rollout in Improved Image Generation Support in Discourse AI .
Discourse (1 post, 5 likes) detailed credit management in Running Out of AI credits? .
Falco (4 posts, 4 likes) weighed in on KI Übersetzungen (formal, informal) , Does Discourse AI support third-party relay/proxy APIs (e.g., NewAPI)? , Search/Read Private not working for a Persona-driven RAG search on forums? , and offered guidance on Support for AI Bot to Configure for a Support the community forum with latest version of Discourse .
DevTeVe (4 posts, 3 likes) documented and tested UI truncation issues in AI is being cutoff before it finishes writing .
sam (5 posts, 2 likes) proposed fixes and shared commit references in AI is being cutoff before it finishes writing and offered firewall and proxy advice in API works manually, but AI (Grok/xAI) does not reach VPS .
whitewaterdeu (4 posts, 2 likes) demonstrated proxy setup in Does Discourse AI support third-party relay/proxy APIs (e.g., NewAPI)? and pinpointed a locale detector mis-persona in Error when translate post by ai (Job exception: undefined method `strip’ for an instance of DiscourseAi::Completions::StructuredOutput) .
asa (1 post, 1 like) flagged translation tone concerns in KI Übersetzungen (formal, informal) .
pmusaraj (1 post, 1 like) confirmed that group titles can’t yet be localized in Content Localization - Manual and Automatic with Discourse AI .
RGJ (1 post, 1 like) shared a Data Explorer query in AI Triaging & persona .
派蒙pm (2 posts, 0 likes) supplied error logs for Chinese AI issues in 有关ai的问题 .
Akunna_Ndubuisi (2 posts) tested automations in AI Triaging & persona .
NateDhaliwal (1 post) clarified triggers and log expectations in AI Triaging & persona .
tom_eric (1 post) evaluated third-party proxy support in Does Discourse AI support third-party relay/proxy APIs (e.g., NewAPI)? .
Neil_Evans (4 posts) debugged private search scopes in Search/Read Private not working for a Persona-driven RAG search on forums? .
iamcapote (1 post) sketched out micro-feature requirements in AI supporting Micro-Features .
Naman_Gala (1 post) described PM bot regression details in AI Bot PM replies stopped working on one multisite instance .
viswanatha (1 post) requested a review in Support for AI Bot to Configure for a Support the community forum with latest version of Discourse .
typed-sigterm (1 post) inquired about group localization in Content Localization - Manual and Automatic with Discourse AI .
概览
本周 ai 类别的工作涵盖了 错误排查 、支持故障排除 和 功能演进 的混合内容。贡献者们协作完成了以下工作:
“如果您的 AI 在写入所有内容之前就被截断了,并且您恰好使用了 Cloudflare 的 AI Gateway,第一步是直接查询模型 API!”
— DevTeVe (post 8 )
热门话题
活动
感谢阅读,下周再见!
## 概述
在过去的一周里,Discourse AI 插件得到了显著的增强、错误修复以及社区支持讨论。得益于 keegan 在 [使用我们的托管 LLM 解锁所有 Discourse AI 功能](https://meta.discourse.org/t/-/390985/1?silent=true) #Announcements #ai 中宣布的消息,托管客户现在可以免费使用内部的、开放权重的 LLM。我们还发布了**原生的 PDF 和文档附件支持**——已在 [Discourse AI 中的原生 PDF 和附件支持](https://meta.discourse.org/t/-/391007/1?silent=true) 中宣布,并在 [将 PDF 和附件支持与 AI 机器人一起使用](https://meta.discourse.org/t/-/391005/1?silent=true) #Site Management #how-to 中进行了说明。我们对几个错误进行了分类和解决:[切换“AI 搜索发现”偏好设置不起作用](https://meta.discourse.org/t/-/391135/1?silent=true) #Bug 中的偏好设置切换问题,[AI 机器人 2025.12.0-latest 上的 400 错误](https://meta.discourse.org/t/-/390794/1?silent=true) #Bug 修复了 AI 机器人请求中的 400 错误,[缺少版主的情绪分析页面](https://meta.discourse.org/t/-/391033/1?silent=true) #Bug 解决了版主缺少情绪分析页面的问题,以及 [LLM 使用页面中的次要 UI 错误](https://meta.discourse.org/t/-/391273/1?silent=true) #UX 中跟踪的 UI 小故障得到了纠正。最后,社区深入探讨了高级主题,例如 [Qwen3-VL-8b 图像识别问题和 Gemma3-27b 混合文本图像内容](https://meta.discourse.org/t/-/391017/1?silent=true) #Support 中对第三方模型的图像支持,以及 [如何使用具有自定义分词器的 AI 模型](https://meta.discourse.org/t/-/391238/1?silent=true) #Support 中对自定义分词器的讨论,同时 RGJ 在 [Discourse AI 不尊重“everyone”组](https://meta.discourse.org/t/-/292048/5?silent=true) #Bug 中重新提出了一个权限错误。
## 热门话题
- **面向所有层级的托管、开放权重 LLM**
keegan 在 [使用我们的托管 LLM 解锁所有 Discourse AI 功能](https://meta.discourse.org/t/-/390985/1?silent=true) 中揭晓了“CDCK 托管小型 LLM”,使 Starter 到 Enterprise 客户无需第三方依赖即可访问所有 Discourse AI 功能。mcmcclur 在帖子 [2](https://meta.discourse.org/t/-/390985/2?silent=true) 中询问了 API 访问权限,Falco 在帖子 [3](https://meta.discourse.org/t/-/390985/3?silent=true) 中确认自托管用户将无法获得 API 访问权限。#Announcements #ai
- **AI 机器人的原生 PDF 和附件支持**
sam 在 [Discourse AI 中的原生 PDF 和附件支持](https://meta.discourse.org/t/-/391007/1?silent=true) 中实现了期待已久的在 AI 对话中上传 PDF 和其他文档的功能,并在 [将 PDF 和附件支持与 AI 机器人一起使用](https://meta.discourse.org/t/-/391005/1?silent=true) 中提供了详细配置。#ai #how-to
- **“AI 搜索发现”偏好设置切换错误**
Moin 报告称,更改 **AI 搜索发现**设置在 [切换“AI 搜索发现”偏好设置不起作用](https://meta.discourse.org/t/-/391135/1?silent=true) 中无效。核心维护者 zogstrip 在帖子 [7](https://meta.discourse.org/t/-/391135/7?silent=true) 中提出了一个带有新 `valueTransformer` 的 PR,其中包含了 david 在帖子 [6](https://meta.discourse.org/t/-/391135/6?silent=true) 中的反馈。#Bug
- **2025.12.0 更新后的 AI 机器人 400 错误**
MachineScholar 在 [AI 机器人 2025.12.0-latest 上的 400 错误](https://meta.discourse.org/t/-/390794/1?silent=true) 中发现每个 AI 机器人请求都返回了 `400 Unknown parameter` 错误。Falco 在帖子 [2](https://meta.discourse.org/t/-/390794/2?silent=true) 中指出了最近的重构,sam 在帖子 [6](https://meta.discourse.org/t/-/390794/6?silent=true) 中发布了修复(PR 36572),并在帖子 [8](https://meta.discourse.org/t/-/390794/8?silent=true) 中确认已解决。#Bug #ai-bot
- **版主缺少情绪分析页面**
putty 在 [缺少版主的情绪分析页面](https://meta.discourse.org/t/-/391033/1?silent=true) 中指出,版主无法在侧边栏中看到情绪分析报告。awesomerobot 很快在帖子 [2](https://meta.discourse.org/t/-/391033/2?silent=true) 中合并了一个侧边栏修复。#ai-sentiment #Bug
- **LLM 使用页面中的次要 UI 错误**
RBoy 在 [LLM 使用页面中的次要 UI 错误](https://meta.discourse.org/t/-/391273/1?silent=true) 中发现新 LLM 在 `llm_validator` 下显示为未命名。zogstrip 在帖子 [2](https://meta.discourse.org/t/-/391273/2?silent=true) 中确认 PR 36694 将更正下拉菜单。#UX #pr-welcome
- **Qwen3-VL-8b 图像识别限制**
Ivan_Rapekas 在 [Qwen3-VL-8b 图像识别问题和 Gemma3-27b 混合文本图像内容](https://meta.discourse.org/t/-/391017/1?silent=true) 中探讨了非 Anthropic/OpenAI/Google 模型如何处理图像。sam 在帖子 [2](https://meta.discourse.org/t/-/391017/2?silent=true) 中澄清 LMStudio 缺乏 PDF 支持,Ivan 在帖子 [3](https://meta.discourse.org/t/-/391017/3?silent=true) 中的后续评论标记了问题已解决。#ai #Support
- **自定义分词器配置**
RBoy 在 [如何使用具有自定义分词器的 AI 模型](https://meta.discourse.org/t/-/391238/1?silent=true) 中询问 Discourse AI 是否可以使用自定义分词器来处理 moonshotai/Kimi-K2-Instruct。Falco 在帖子 [2](https://meta.discourse.org/t/-/391238/2?silent=true) 中建议选择最接近的内置分词器并调整上下文窗口。#Support #ai
- **AI 组权限错误:“everyone”组未被尊重**
RGJ 在 [Discourse AI 不尊重“everyone”组](https://meta.discourse.org/t/-/292048/5?silent=true) 中重新提出了一个旧问题,即设置 **AI 机器人允许组**为 `everyone` 仍然会阻止机器人,并指出了核心中错误的 `allowed_groups_map` 检查。#Bug
## 活动
以下是过去一周我们最活跃的社区成员的贡献细分:
- **sam**
• 在 [391007/1](https://meta.discourse.org/t/-/391007/1?silent=true) 中宣布了原生的 PDF 和附件支持,并撰写了操作指南 [391005/1](https://meta.discourse.org/t/-/391005/1?silent=true)。
• 在 [390794/6](https://meta.discourse.org/t/-/390794/6?silent=true) 中修复了 AI 机器人 400 错误,并在 [390794/8](https://meta.discourse.org/t/-/390794/8?silent=true) 中确认了解决方案。
• 在 [391017/2](https://meta.discourse.org/t/-/391017/2?silent=true) 中澄清了 Qwen3-VL-8b 的图像支持。
- **Falco**
• 在 [390985/3](https://meta.discourse.org/t/-/390985/3?silent=true) 中建议托管 LLM API 不会对自托管用户开放。
• 在 [390794/2](https://meta.discourse.org/t/-/390794/2?silent=true) 中协助诊断了 AI 机器人的 400 错误。
• 在 [391238/2](https://meta.discourse.org/t/-/391238/2?silent=true) 中指导了关于自定义分词器的建议。
- **keegan**
• 在 [390985/1](https://meta.discourse.org/t/-/390985/1?silent=true) 中启动了 CDCK 托管 LLM,并在 [390985/2](https://meta.discourse.org/t/-/390985/2?silent=true) 中详细说明了配置。
- **stephtara**
• 在 [381120/36](https://meta.discourse.org/t/-/381120/36?silent=true) 中分享了多语言翻译的专业知识。
• 在 [385877/8](https://meta.discourse.org/t/-/385877/8?silent=true) 中提供了社区建设方面的建议。
- **zogstrip**
• 在 [391135/5](https://meta.discourse.org/t/-/391135/5?silent=true) 中为偏好设置错误提出了核心 `valueTransformer`。
• 在 [391273/2](https://meta.discourse.org/t/-/391273/2?silent=true) 中批准了 LLM 使用过滤器(LLM Usage filters)的 UI 修复。
- **RGJ**
• 在 [292048/5](https://meta.discourse.org/t/-/292048/5?silent=true) 中强调了“everyone”组权限错误。
- **awesomerobot**
• 在 [391033/2](https://meta.discourse.org/t/-/391033/2?silent=true) 中修复了缺失的版主情绪分析链接。
- **putty**
• 在 [391033/1](https://meta.discourse.org/t/-/391033/1?silent=true) 中报告了版主缺失情绪分析页面的问题。
- **david**
• 在 [391135/6](https://meta.discourse.org/t/-/391135/6?silent=true) 中就偏好设置值转换的核心方法提供了建议。
- **MachineScholar**
• 在 [390794/1](https://meta.discourse.org/t/-/390794/1?silent=true) 中报告了 AI 机器人 400 错误,并在 [390794/8](https://meta.discourse.org/t/-/390794/8?silent=true) 中确认已解决。
感谢阅读,我们下周再见!:slight_smile:
Overview
This week the ai category on Meta Discourse saw a blend of critical bug fixes, forward-looking feature proposals, and nuanced usage discussions:
Interesting Topics
twofoursixeight discovered that the AI silence link redirects non-admins to an inaccessible admin URL, prompting a collaborative Bug discussion with per1234 , NateDhaliwal , and Moin on whether to retarget the link to the machine account profile or conditionally hide it based on permissions.
Discourse AI silence link takes you to an inaccessible link as a normal user (Bug ai )
Lilly reported an LLM configuration error when testing a self-hosted model—“Target can’t be blank” —to which zogstrip responded with a link to a pull request that fixes parameter validation.
LLM error in Discourse AI - “Target can’t be blank” (Bug ai )
joo proposed threaded/branched AI bot conversations , akin to Discourse Chat threads, allowing sub-topics to inherit context and remain organized under the AI bot’s umbrella.
Request: AI Bot Chat Threads Support (Threaded/Branched Conversations with AI) (Feature ai )
祁同伟 explored integrating NVIDIA’s embedding models via the NIM API, shared API key details, and encountered case-sensitive model naming quirks before Falco posted a working configuration screenshot.
希望ai插件可以支持nvidia的嵌入向量模型 (Feature ai )
westes questioned the practicality of 15K daily AI credits for summarize-on-demand, advocating per-post summaries and clearer cost indicators, while Falco and keegan clarified token-to-credit ratios and per-user quota tooling.
Unlock All Discourse AI Features with Our Hosted LLM (Announcements ai )
Falco confirmed that the AI spam detection “Scan log” no longer truncates, resolving a months-old moderator pain point.
Discourse AI spam detection “Scan log” is frequently truncated (Bug ai )
ToddZ critiqued the ambiguity of “Suggested” vs “Related” links under posts, leading to discussion on tab naming conventions and AI-driven relevance curation.
Do we want to tweak “suggested” and “Related” links at bottom of posts? (Site feedback #ai-related-topics suggested-topics )
iamcapote drew parallels between Discourse AI’s artifact storage and Google’s A2UI agent-driven interfaces, suggesting complementary workflows for user-generated AI content.
AI Artifact User storage (Announcements ai-artifacts )
tvavrda spotted a non-functional “How does it work?” button in the Conversational AI Search info dialog, highlighting a minor UI oversight ahead of the broader rollout.
Conversational AI Search coming to Discourse AI (Feature ai-search )
Jason_Hsia celebrated the launch of the Discourse MCP moderation framework and envisioned Cursor integration, while sam reminded users to simply enable it via the MCP config.
Discourse MCP is here! (blog ai mcp )
Activity
每周 AI 活动摘要:2025 年 12 月 22 日–29 日
概述
上周,社区围绕 AI 相关的讨论,在 UX 改进、Support 咨询、Bug 整理和 Feature 规划等方面进行了互动。 \u003ca class="mention" href="/u/Lilly"\u003eLilly\u003c/a\u003e 提出的 DMenu 下拉菜单的选中/悬停/焦点状态有点令人困惑 指出了扩展代码片段模式中不一致的样式,并由 \u003ca class="mention" href="/u/jordan.vidrine"\u003ejordan.vidrine\u003c/a\u003e 进行了修复。关于核心 AI 功能的澄清来自 Discourse 源代码是否支持 AI 模式和 AI 概述? 的讨论,而像账户在删除垃圾信息标记后仍被禁言等管理边缘案例则在 用户删除垃圾信息标记的帖子后,账户未经验证仍被禁言 中暴露出来。与此同时,像 “使用 AI 整理帖子” 这样的 automation 脚本以及与本地 LLM(ai , chat )的集成引发了错误报告和设计讨论。
有趣的话题
活动
感谢阅读,下周再见!
每周 AI 活动摘要
周期: 2025-12-29 至 2026-01-05
概述
本周,Meta Discourse 上有四项值得关注的与 AI 相关的讨论:
Lilly(\u003ca class="mention" href="/u/Lilly"\u003eLilly\u003c/a\u003e)提出了一项建议,排除特定版块 以控制 AI 摘要生成器的成本和噪音(允许指定要从 AI 摘要中排除的版块 )。
关于新的 Discourse 审核助手(MCP)的本地化支持 问题,jrgong(\u003ca class="mention" href="/u/jrgong"\u003ejrgong\u003c/a\u003e)询问了如何提取德语内容并提供英文翻译,这引发了对 REST API 中需要一个 locale 参数的附带请求(Discourse MCP 来了! )。
RBoy(\u003ca class="mention" href="/u/RBoy"\u003eRBoy\u003c/a\u003e)报告了 LLM 使用情况页面中缓存/用户界面错误 ,该错误阻止了时间范围更改刷新模型列表(LLM 使用情况 UI 中的错误 )。
Heliosurge(\u003ca class="mention" href="/u/Heliosurge"\u003eHeliosurge\u003c/a\u003e)指出了每日摘要工具 中的故障,摘要显示为代码块,并且错误地对帖子进行了分类(每日摘要(在 Meta 上) )。
这些帖子涵盖了 Feature 请求、Bug 修复以及在 #ai-summarize、 #mcp、 UX 和 #site-management 中的改进。
热门话题
Lilly(\u003ca class="mention" href="/u/Lilly"\u003eLilly\u003c/a\u003e)请求对 AI 功能进行更细粒度的控制,要求排除特定版块 (以及可能的标签)不进行 AI 摘要生成,以实现成本管理 (ai-summarize , Feature )。
jrgong(\u003ca class="mention" href="/u/jrgong"\u003ejrgong\u003c/a\u003e)称赞了 MCP,但询问了区域设置参数 以获取德语到英语的翻译,这导致了添加参数到读取工具的建议(Discourse MCP 来了! , 支持请求 )ai , #mcp。
Falco(\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e)支持区域设置参数的想法,并将其与 REST API 的 tl-lang 参数 联系起来,以确保跨工具的一致性。
RBoy(\u003ca class="mention" href="/u/RBoy"\u003eRBoy\u003c/a\u003e)在 LLM 使用情况 UI 中发现了一个持续的缓存问题 ,选择“过去 24 小时”仍然显示上个月的模型(LLM 使用情况 UI 中的错误 ,参见早前的轻微 UI 错误 )Bug , UX , #ai。
Heliosurge(\u003ca class="mention" href="/u/Heliosurge"\u003eHeliosurge\u003c/a\u003e)报告了两个每日摘要异常:摘要作为代码块发布,以及将一个插件错误地归类为主题组件(每日摘要(在 Meta 上) ,原始报告在这里 ,跟进在这里 )Bug , #site-management , #automation。
fokx(\u003ca class="mention" href="/u/fokx"\u003efokx\u003c/a\u003e)重新讨论了 NSFW 检测,建议预提交图像扫描 以减少隐藏被标记内容时的延迟,如果用户等待审核,这可能是可以接受的(how-to , moderation , automation , ai )在您的社区中设置 NSFW 检测 。
活动
Lilly(\u003ca class="mention" href="/u/Lilly"\u003eLilly\u003c/a\u003e)撰写了排除版块以进行 AI 摘要 的功能请求,获得了 5 个赞 。
jrgong(\u003ca class="mention" href="/u/jrgong"\u003ejrgong\u003c/a\u003e)在 MCP 帖子中发布了两次——第一次在第 12 楼 询问区域设置支持,第二次在第 14 楼 链接到 REST API 请求——共获得 2 个赞 。
Falco(\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e)在第 13 楼 提出了关于如何实现区域设置参数的关键建议(2 个赞 )。
RBoy(\u003ca class="mention" href="/u/RBoy"\u003eRBoy\u003c/a\u003e)在第 1 楼 报告了 LLM 使用情况 UI 错误,获得了 1 个赞 。
Heliosurge(\u003ca class="mention" href="/u/Heliosurge"\u003eHeliosurge\u003c/a\u003e)在第 1 楼 标记了每日摘要问题,获得了 1 个赞 。
fokx(\u003ca class="mention" href="/u/fokx"\u003efokx\u003c/a\u003e)在第 4 楼 就 NSFW 检测发表了看法,获得了 1 个赞 。
感谢阅读,我们下周再见!
## 概述
本周在 #ai 频道,社区讨论了从集成和设置到错误修复和功能请求的各种主题。在 #Marketplace 频道中,<a class="mention" href="/u/Geenicetea">Geenicetea</a> 寻求关于 [DiscourseConnect & AI 设置](https://meta.discourse.org/t/-/393147/1?silent=true) 的帮助,并得到了 <a class="mention" href="/u/jahan_gagan">jahan_gagan</a> [参考](https://meta.discourse.org/t/-/393147/2?silent=true) 和 <a class="mention" href="/u/itsbhanusharma">itsbhanusharma</a> [参考](https://meta.discourse.org/t/-/393147/3?silent=true) 的指导。
在 #Bug 频道中,Discobot 搜索结果中出现外部链接的神秘现象被 <a class="mention" href="/u/Moin">Moin</a> [参考](https://meta.discourse.org/t/-/393260/3?silent=true) 诊断为地址替换的怪癖,此前 <a class="mention" href="/u/Lilly">Lilly</a> 报告了意外的 OOPS 页面 [参考](https://meta.discourse.org/t/-/393260/1?silent=true)。
在 #Support 频道,用户深入研究了将 Discourse AI 配置为*仅限内部*使用 [参考](https://meta.discourse.org/t/-/393030/1?silent=true),并发现了隐藏的网络搜索成本,这导致一位管理员更换了提供商 [参考](https://meta.discourse.org/t/-/393030/7?silent=true)。同时,在 #Bug #ai-summarize 频道中,一个关于登出后 AI 积分状态出现 403 错误的奇怪问题浮出水面 [参考](https://meta.discourse.org/t/-/393261/1?silent=true)。
功能请求涵盖了自动化改进——仅针对主题创建者触发 AI 回复 [参考](https://meta.discourse.org/t/-/393157/1?silent=true)——以及在 #Feature #ai-bot 频道中对 AI 机器人的附件进行更深入的控制 [参考](https://meta.discourse.org/t/-/393178/1?silent=true)。
> “有没有办法完全限制 AI 机器人的文件上传?”
> —<a class="mention" href="/u/m_terenui">m_terenui</a>
有关 SSO 的深入探讨,请参阅我们的 [Marketplace 帖子](https://meta.discourse.org/t/-/393147/1?silent=true)。
您还可以重温 [仅限内部的 Discourse AI 讨论](https://meta.discourse.org/t/-/393030/1?silent=true)。
在调查 UI 错误时,请参阅 [此控制台错误报告](https://meta.discourse.org/t/-/392652/3?silent=true)。
## 有趣的话题
- **DiscourseConnect & AI 单点登录** (#Marketplace #wp-discourse #discourseconnect #ai)
<a class="mention" href="/u/Geenicetea">Geenicetea</a> 在 [有人能帮我设置 discourseconnect & ai 吗](https://meta.discourse.org/t/-/393147/1?silent=true) 中询问了 SSO 指南。
- **Discobot 搜索显示外部链接** (#Bug #search #ai)
<a class="mention" href="/u/Lilly">Lilly</a> 标记了 [Meta 上的“Discobot 发现”搜索结果](https://meta.discourse.org/t/-/393260/1?silent=true) 返回了非 Meta 的 URL,<a class="mention" href="/u/Moin">Moin</a> 解释了 URL 重写 [参考](https://meta.discourse.org/t/-/393260/3?silent=true)。
- **仅限内部的 Discourse AI 配置** (#Support #ai)
<a class="mention" href="/u/Thefacto">Thefacto</a> 探讨了 [如何为仅限内部使用设置 Discourse AI](https://meta.discourse.org/t/-/393030/1?silent=true) 并发现了隐藏的网络搜索成本 [参考](https://meta.discourse.org/t/-/393030/7?silent=true)。
- **AI 积分状态出现 403 错误** (#Bug #ai-summarize)
<a class="mention" href="/u/Moin">Moin</a> 报告了登出时出现 [403 错误 /discourse-ai/credits/status?features[]=topic_summaries](https://meta.discourse.org/t/-/393261/1?silent=true)。
- **AI 自动化仅针对主题所有者** (#Feature #automation #ai)
<a class="mention" href="/u/kuaza">kuaza</a> 建议 [仅为主题创建者提供 AI 自动化](https://meta.discourse.org/t/-/393157/1?silent=true),以便自动回复仅针对主题作者触发。
- **Discourse MCP 增强功能** (#Blog #ai #mcp)
<a class="mention" href="/u/jrgong">jrgong</a> 在 [Discourse MCP 来了!](https://meta.discourse.org/t/-/386983/15?silent=true) 中提出了权限参数。
- **LLM 用法 UI 中的错误** (#UX #ai)
<a class="mention" href="/u/zogstrip">zogstrip</a> 在 [LLM 用法 UI 中的错误](https://meta.discourse.org/t/-/392652/3?silent=true) 中修复了缓存处理。
- **限制 AI 机器人的文件上传** (#Feature #ai-bot)
<a class="mention" href="/u/m_terenui">m_terenui</a> 在 [探索在与 AI 机器人交互时阻止文件上传](https://meta.discourse.org/t/-/393178/1?silent=true) 中询问了移除文件上传功能的事宜。
- **筛选 AI 对话** (#Feature #ai)
<a class="mention" href="/u/kuaza">kuaza</a> 重新讨论了 [将人工智能对话单独列在一个页面上](https://meta.discourse.org/t/-/362711/10?silent=true)。
- **源代码中对 AI 模式的支持** (#Support #ai)
<a class="mention" href="/u/toanvoc">toanvoc</a> 在 [Discourse 源代码是否支持 AI 模式和 AI 概述?](https://meta.discourse.org/t/-/392260/10?silent=true) 中询问 Discourse 是否支持各种 AI 模式。
- **AI 上下文菜单未更新** (#Support #ai-helper #bug)
<a class="mention" href="/u/mcmcclur">mcmcclur</a> 在 [AI contextual_menu 不可靠地更新](https://meta.discourse.org/t/-/392930/1?silent=true) 中描述了菜单刷新问题。
## 活动
- <a class="mention" href="/u/Geenicetea">Geenicetea</a> 发起了 SSO 集成帖子 [有人能帮我设置 discourseconnect & ai 吗](https://meta.discourse.org/t/-/393147/1?silent=true?silent=true)。
- <a class="mention" href="/u/jahan_gagan">jahan_gagan</a> 在 [有人能帮我设置 discourseconnect & ai 吗](https://meta.discourse.org/t/-/393147/2?silent=true) 中提供了帮助。
- <a class="mention" href="/u/itsbhanusharma">itsbhanusharma</a> 也在 SSO 设置方面提供了意见 [有人能帮我设置 discourseconnect & ai 吗](https://meta.discourse.org/t/-/393147/3?silent=true)。
- <a class="mention" href="/u/Lilly">Lilly</a> 报告了 Discobot 搜索异常 [Meta 上的“Discobot 发现”搜索结果](https://meta.discourse.org/t/-/393260/1?silent=true),并为仅限内部的 AI 设置帖子做出了贡献 [如何为仅限内部使用设置 Discourse AI](https://meta.discourse.org/t/-/393030/2?silent=true)。
- <a class="mention" href="/u/Moin">Moin</a> 解释了 Discobot 搜索中的 URL 重写 [参考](https://meta.discourse.org/t/-/393260/3?silent=true),并报告了 [403 错误 /discourse-ai/credits/status](https://meta.discourse.org/t/-/393261/1?silent=true) 中的 403 错误。
- <a class="mention" href="/u/Thefacto">Thefacto</a> 主导了**仅限内部 AI** 的讨论 [如何为仅限内部使用设置 Discourse AI](https://meta.discourse.org/t/-/393030/1?silent=true),迭代了帖子 [参考](https://meta.discourse.org/t/-/393030/3?silent=true),[参考](https://meta.discourse.org/t/-/393030/5?silent=true),并通过解决方案 [参考](https://meta.discourse.org/t/-/393030/7?silent=true) 结束了循环。
- <a class="mention" href="/u/kuaza">kuaza</a> 提出了两项功能请求:针对作者的 AI 自动化 [仅为主题创建者提供 AI 自动化](https://meta.discourse.org/t/-/393157/1?silent=true) 和筛选 AI 对话 [将人工智能对话单独列在一个页面上](https://meta.discourse.org/t/-/362711/10?silent=true)。
- <a class="mention" href="/u/Falco">Falco</a> 在 [Discourse MCP 来了!](https://meta.discourse.org/t/-/386983/15?silent=true) 中审查了 PR 的可能性,并欢迎进一步的贡献 [参考](https://meta.discourse.org/t/-/386983/16?silent=true)。
- <a class="mention" href="/u/zogstrip">zogstrip</a> 在 [LLM 用法 UI 中的错误](https://meta.discourse.org/t/-/392652/3?silent=true) 中解决了缓存问题。
- <a class="mention" href="/u/Bruce5051">Bruce5051</a> 在 [Meta 上的“Discobot 发现”搜索结果](https://meta.discourse.org/t/-/393260/2?silent=true) 中提出了“AI 幻觉?”的疑问。
- <a class="mention" href="/u/merefield">merefield</a> 在 [Discourse 源代码是否支持 AI 模式和 AI 概述?](https://meta.discourse.org/t/-/392260/11?silent=true) 中要求澄清。
- <a class="mention" href="/u/toanvoc">toanvoc</a> 在 [Discourse 源代码是否支持 AI 模式和 AI 概述?](https://meta.discourse.org/t/-/392260/10?silent=true) 中询问了 AI 模式支持。
- <a class="mention" href="/u/mcmcclur">mcmcclur</a> 在 [AI contextual_menu 不可靠地更新](https://meta.discourse.org/t/-/392930/1?silent=true) 中报告了 AI 菜单问题。
- <a class="mention" href="/u/m_terenui">m_terenui</a> 在 [探索在与 AI 机器人交互时阻止文件上传](https://meta.discourse.org/t/-/393178/1?silent=true) 中探讨了文件上传限制。
感谢阅读,下周再见!:slight_smile:
每周 AI 活动摘要 (2026-01-12 → 2026-01-19)
概述
本周在 Meta Discourse 的 ai 频道中,社区讨论了以下内容:
热门话题
活动
感谢阅读,我们下周再见!
sam
(Sam Saffron)
2026 年1 月 20 日 23:59
106
Gemini 产生幻觉 ```markdown 太烦人了……我去看看有没有简单的解决方法。
Period: 2026-01-19 to 2026-01-26
Overview
This week the Discourse community engaged in a diverse set of ai discussions across Support , UX , Plugin , #Self-Hosting , Bug , and Announcements categories. At the core were localization and translation improvements—most notably in Related Topics not translated where multilingual sites regained proper locale-based topic suggestions. Plugin power-users explored write-tool availability in Discourse MCP is here! and proposed enhancements to LLM management in Feature request: improve Discourse AI LLM setup (model discovery) and add AI config import/export . In UX , debates around User Interface Preferences: include setting to disable AI nudges emphasized user control versus built-in guidance. Infrastructure conversations ranged from adding custom HTTP headers in self-hosted LLM setups (Self-Hosting an OpenSource LLM for DiscourseAI ) to diagnosing Discobot’s search hallucinations (The “Discobot discoveries” search results on Meta ) and translation key tweaks (Is ‘in’ translateable in relative_reset_time? ). Developers also tackled schema errors in custom AI tools (AI bot - Custom tools ), integration with image generation APIs (Improved Image Generation Support in Discourse AI ), and even community-contributed recommendation scripts in Discourse AI .
Interesting Topics
Related Topics not translated (Support , ai , related-topics , content-localization )
stance455 kicked off this thread by noting that auto-translated pages still showed English “related topics” ref , Lilly requested reproduction steps ref , Moin provided the #solution to set ai embeddings model to multilingual-e5-large ref , and stance455 confirmed all was well afterward ref .
Discourse MCP is here! (blog , ai , mcp )
SkhemaDeveloper verified access to “write” tools after configuring the —allow_writes flag ref and later resolved the issue by regenerating an admin key as system ref . sam announced a new release with considerations for admin-only endpoints ref , while rey.riel proposed and submitted a PR for email and group access behind admin keys ref , later sharing the PR link ref and a doc-caveat on “single user = system” in key creation ref .
User Interface Preferences: include setting to disable AI nudges (UX , ai-summarize )
conartist6 asked about disabling AI suggestion buttons via a user setting ref . Moin suggested a local CSS workaround ref . conartist6 then contemplated a PR for a new toggle ref , with Canapin noting the team’s caution on adding settings ref . conartist6 highlighted broader ethical concerns ref , chapoi recommended gauging community traction with a Feature request ref , awesomerobot pointed out the existing admin-level toggle ref , and conartist6 confirmed that hiding the button suffices for personal preference ref .
Self-Hosting an OpenSource LLM for DiscourseAI (#Self-Hosting , ai )
pacharanero requested the ability to inject a custom HTTP header (e.g., SubscriptionKey) into LLM requests ref . pfaffman suggested either a Discourse plugin or an NGINX proxy workaround ref .
The “Discobot discoveries” search results on Meta (Bug , search , ai )
ondrej reported that Discobot’s AI-powered suggestions pointed to a non-existent category ref , prompting discussion on whether to disable AI discoveries here ref .
AI bot – Custom tools (#Site Management, how-to , ai )
jorge-gbs encountered a schema validation error when defining an array parameter in a custom tool ref and asked for known limitations or UI paths.
Improved Image Generation Support in Discourse AI (Announcements , ai , ai-helper )
David_Ghost inquired about using Stability API keys in a custom tool for image generation ref .
Discourse AI (Plugin , official , included-in-core , ai )
祁同伟 shared a community-built Tampermonkey script integrating Twitter’s open-sourced recommendation algorithm into Discourse’s AI recommendations ref .
Is ‘in’ translateable in relative_reset_time? (#Translations , ai )
zogstrip caught a missing %{in} translation key and linked to a fix PR ref , with Moin confirming multilingual behavior works for both time formats ref .
Feature request: improve Discourse AI LLM setup (model discovery) and add AI config import/export (Support , ai )
tom_eric proposed UX enhancements for auto-discovering OpenAI-compatible models and adding import/export for AI configurations, to streamline multi-env admin workflows ref .
Activity
Moin (3 posts, 5 likes) provided the #solution for locale-aware related topics in Related Topics not translated , suggested a CSS workaround in User Interface Preferences: include setting to disable AI nudges , and confirmed translation key behavior in Is ‘in’ translateable in relative_reset_time? .
stance455 (2 posts, 5 likes) reported the related-topics translation issue here and later confirmed it was resolved here .
Lilly (1 post, 4 likes) assisted with reproduction steps for related-topics translation in Related Topics not translated .
SkhemaDeveloper (2 posts, 1 like) debugged write-tool access in Discourse MCP is here! and fixed the API key scope issue here .
rey.riel (3 posts, 2 likes) proposed behind-admin API enhancements here , created a PR here , and offered key-creation caveats here .
Canapin (1 post, 1 like) weighed in on balancing new settings vs. complexity in User Interface Preferences: include setting to disable AI nudges .
ondrej (1 post, 1 like) flagged Discobot’s broken discovery link in The “Discobot discoveries” search results on Meta .
chapoi (1 post, 1 like) encouraged a feature-request approach for UI toggles in User Interface Preferences: include setting to disable AI nudges .
David_Ghost (1 post, 1 like) asked about Stability API integration in Improved Image Generation Support in Discourse AI .
jorge-gbs (1 post, 1 like) reported a schema error for array parameters in a custom AI tool here .
conartist6 (4 posts, 0 likes) led the discussion on user-level AI toggle preferences in User Interface Preferences: include setting to disable AI nudges , explored PR feasibility here , voiced ethical objections here , and affirmed the CSS-only fix here .
pfaffman (1 post, 1 like) suggested plugin or NGINX proxy workarounds for custom headers in Self-Hosting an OpenSource LLM for DiscourseAI .
pacharanero (1 post, 1 like) requested custom-header support for self-hosted LLMs here .
zogstrip (1 post, 1 like) filed a PR to translate “in” for credit-reset timing in Is ‘in’ translateable in relative_reset_time? .
sam (1 post, 1 like) released updates to mcp tools and outlined future admin-API expansions in Discourse MCP is here! .
tom_eric (1 post, 0 likes) proposed LLM model auto-discovery and AI config import/export UX in Feature request: improve Discourse AI LLM setup (model discovery) and add AI config import/export .
Weekly AI Activity Summary (2026-01-26 to 2026-02-02)
Overview
This week the ai tag on Meta Discourse saw a flurry of conversations around spam protection , semantic search , theming , summarization reliability , translation UX , content localization , and API enhancements .
A new Support thread, Yan_Fridland ’s How do I configure AI Spam protection , kicked off best-practices for fighting AI-generated spam using solutions like discourse-ai-spam-detection and the existing spam documentation .
In Discourse’s search broken? the team examined why exact matches fall back to semantic results when few hits exist, sparking proposals for clearer UI indicators (semantic fallback behavior , Falco’s take ).
On the theming front, Lilly released the Discourse Topic Excerpts & AI Gists Button Theme component, complete with an install guide and a prerequisite Topic List Excerpts component.
A bizarre payload bug surfaced in Text gets mysteriously reversed in AI Summarization payload , where half of the text was sent backwards – a defect quickly patched by Falco via PR #36498 .
TroLLoBloger and Moin weighed in on Multilingual user feedback on Automatic Translations , debating transparency controls (Moin’s UX note ) and cultural subtleties (further reflections ).
Extended discussion in Content Localization – Manual and Automatic with Discourse AI saw michaelh0 report intermittent broken images after translation and eisammy highlight emoji handling quirks ).
A fresh Feature proposal, Provide topic count via Discourse AI tool API discourse.getUser function , suggested enriching AI personas with a topic_count field (see the discourse.getUser docs and custom tools overview ).
Finally, the longstanding Summarize – Gists how-to was revisited, as Saif and Lilly clarified its availability on self-hosted vs. hosted environments (initial feature note ).
Interesting Topics
Activity
Meta Discourse 上每周 AI 活动摘要
日期范围: 2026-02-02 至 2026-02-09
概述
在上周,关键进展包括 Data Explorer 集成到 Discourse MCP 中,以及在官方 AI 插件中进行的细微的错误修复和功能请求。亮点包括:
这些主题说明了围绕 ai 的 Announcements (公告)、Feature (功能)、Bug (错误)、Support (支持)和 #Site Management(站点管理)讨论的健康组合。
有趣的话题
将 Data Explorer 集成到 Discourse MCP 中
\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 通过 帖子 1 Announcements data-explorer ai sql-query 宣布了 Discourse MCP CLI 中无缝的 Data Explorer 支持。这建立在 Discourse MCP 来了! blog ai mcp 的最初发布之上,\u003ca class="mention" href="/u/Moin"\u003eMoin\u003c/a\u003e 在 帖子 26 中询问了插件依赖项,而 \u003ca class="mention" href="/u/NateDhaliwal"\u003eNateDhaliwal\u003c/a\u003e 在同一主题中澄清了标签的使用。
Discourse AI 插件:缺少模型发现和合理的默认设置
\u003ca class="mention" href="/u/tom_eric"\u003etom_eric\u003c/a\u003e 就自动模型列表开启了详细的 功能请求 Feature #ai。他跟进了关于手动 ID 输入的 帖子 2 ,关于上下文窗口设置的 帖子 3 ,并且 \u003ca class="mention" href="/u/Moin"\u003eMoin\u003c/a\u003e 在 帖子 4 中指出了重叠的工作,链接到一个现有的 插件提案 。
Discobot “发现”搜索故障
\u003ca class="mention" href="/u/Canapin"\u003eCanapin\u003c/a\u003e 发现 “Discobot 发现”搜索结果 返回了不相关的机器人输出,而不是有用的摘要。Bug search ai
Discourse Helper 使用 Gemini 3 表现完美……直到现在!
\u003ca class="mention" href="/u/StevePlex"\u003eStevePlex\u003c/a\u003e 报告了 简单工具调用时的崩溃 Support ai ,描述了 帖子 2 中无休止的内省循环。\u003ca class="mention" href="/u/Falco"\u003eFalco\u003c/a\u003e 在 帖子 3 中建议了重试策略,并在 帖子 4 中提供了进一步的调试细节。
Discourse AI – 垃圾邮件检测
\u003ca class="mention" href="/u/sps"\u003esps\u003c/a\u003e 在 Discourse AI 垃圾邮件检测流程 #Site Management how-to ai moderation 中标记了一个问题,即批准垃圾邮件标记后仍然会自动静音新用户,而 \u003ca class="mention" href="/u/sam"\u003esam\u003c/a\u003e 在 帖子 25 中回应了关于平衡选择的问题。
通过 Discourse AI 工具 API 提供主题计数
\u003ca class="mention" href="/u/zogstrip"\u003ezogstrip\u003c/a\u003e 修复了 用户序列化器 中缺失的 topic_count 字段,从而支持更丰富的 AI 查询。Feature ai
Discourse Gemini 的 embedding-001 调用错误
\u003ca class="mention" href="/u/honeymoose"\u003ehoneymoose\u003c/a\u003e 在 帖子 1 Support ai 中遇到了 embedding-001 的 404 错误。\u003ca class="mention" href="/u/Lilly"\u003eLilly\u003c/a\u003e 在 帖子 2 中检查了设置,并在 帖子 5 中指出了 URL 不匹配。更正端点后,在 帖子 9 中报告了成功。
Summarize – Gist 默认布局
\u003ca class="mention" href="/u/markschmucker"\u003emarkschmucker\u003c/a\u003e 在 Summarize – Gists 中询问 AI 生成的 Gist 是否可以默认为展开视图。#Site Management how-to ai-summarize
活动
• 在 使用 Discourse MCP 探索您的 Discourse 数据 中宣布了 Data Explorer
• 在 Gemini 3 崩溃 中指导了重试策略
• 在 帖子 1 中发起了模型发现功能请求
• 在 帖子 2 和 3 中阐明了 UX 差距
• 在 帖子 4 中强调了重叠
• 在 Discourse MCP 来了! 中质疑了插件依赖性
• 报告了 Discobot 搜索故障
• 描述了 Gemini 3 Helper 崩溃
• 在 帖子 2 和 4 中分享了循环细节
• 在 Discourse AI 垃圾邮件检测 中提出了自动静音的担忧
• 在 帖子 25 中回应了版主 UX
• 在 Discourse AI 工具 API 中修复了 topic_count 问题
• 报告了 embedding-001 404 错误
• 在 帖子 8 中确认了解决方案
• 在 帖子 2 和 5 中诊断了模型设置问题
• 在 Summarize – Gists 中询问了 Gist 布局默认设置
• 在 Discourse MCP 来了! 中澄清了 ai 标签的使用
感谢阅读,下周再见!
概览
本周共出现了九个以人工智能为重点的讨论串(ai ),涵盖了 #站点管理、 #功能、 #支持、 #主题组件 和 #社区。在 内容本地化 - 使用 Discourse AI 进行手动和自动翻译 中,David_Ghost 对 Google Search Console 的警告表示担忧,nat 澄清了最佳实践。关于 使用 AI 的自动回复器 的讨论催生了一个新的“停滞主题”触发器 PR。Don 推出了 Quizmaster 主题组件。kuaza 在 模型达到限制后应显示为淡色,选择时可升级订阅 中提出了模型使用限制的改进 UI 建议。在 自定义 AI 摘要器以使用非英语语言 中,jrgong 和 Ivan_Rapekas 探讨了多语言摘要。philh 在 帖子标记重复 中深入研究了重复标记,并在 AI 机器人 - 角色配置 中研究了角色配置。Discourse接入Openclaw机器人 和 Web3 银行项目构想 等集成提案引发了社区讨论。
有趣的话题
活动
感谢阅读,下周再见!
每周 AI 活动摘要 (2026-02-16 至 2026-02-23)
概览
本周在 meta.discourse.org 上的 ai 讨论涵盖了支持请求、错误报告和功能提案的混合内容:
在过去七天中,共有 13 条新帖子 、2 个新主题 ,主要贡献者包括 manton 、Yan_Fridland 、祁同伟 、tobiaseigen 、Falco 、philh 、Alon1 和 sam 。
热门话题
活动
引用分类和标签
感谢阅读,我们下周再见!
Overview
This week’s ai activity on meta.discourse.org centered on polishing the Discourse AI admin experience —from new guidance on safely managing secrets in Managing AI credentials to multiple UX papercuts reported (and quickly patched) in places like Error popup when suggesting tags in topic already having tags and Field alignment issues in LLM cost configuration in German .
A second theme was automation and agent integration : a self-hosted community explored whether AI should drive operational workflows in Creating a system to move topics based on given criteria such as a timestamp , while agent tooling and bot behavior (including adherence to llms.txt) came up in Discourse接入Openclaw机器人 and broader “who’s using AI bots” questions in AI Bots active on Discourse Powered Sites? .
Finally, translation and localization gaps continued to surface—both in UI strings (e.g., hardcoded labels) via Why are “Required” and “Enum” hardcoded in AI tool parameter configuration? and in admin-facing AI features where users asked for help translating output/UI such as How do I translate AI Summaries? , echoing earlier concerns about missing descriptions in AI settings without descriptions result in no non-English information about the settings .
Interesting Topics
LLM cost configuration UI breaks down in German (layout + readability).
Moin reported awkward spacing when localized labels get longer in Field alignment issues in LLM cost configuration in German . sam suggested reducing the 4-column layout into fewer rows in the follow-up , and derek proposed a clearer 2×2 grouping that also adapts better on mobile in their mockups .
AI tool editor: “Required” / “Enum” labels were hardcoded (not translatable).
Moin flagged that some AI-tool parameter UI strings weren’t localizable in Why are “Required” and “Enum” hardcoded in AI tool parameter configuration? . zogstrip agreed there was no good reason for it and moved toward fixing it in the response .
New admin guide: centralizing and rotating secrets with AI credentials.
sam published Managing AI credentials , documenting how to store API keys once and reference them across LLMs, embedding models, and custom tools—making key rotation and lifecycle management significantly safer and simpler.
“Move topics on expiration” workflow: using Discourse core vs. AI vs. structured fields.
In Creating a system to move topics based on given criteria such as a timestamp , jdc20181 explored auto-archiving “temporary ban” log topics by parsing timestamps. sam suggested avoiding AI and using core tooling like topic timers in their reply . Falco proposed a more robust approach: store expiration in a custom topic field (or use forms), add /filter views, and then automate with jobs + API integrations in their detailed guidance , with templates referenced via Introducing Experimental Form Templates .
AI tag suggestion UX: error popup + “phantom” tag behavior.
Canapin reported confusing errors when applying AI tag suggestions to already-tagged topics in Error popup when suggesting tags in topic already having tags . NateDhaliwal added observations about tags appearing then disappearing on reload in their report , and sam confirmed it should be treated as a real bug in the follow-up .
“Who’s using AI bots?” + examples and expectations.
ThisSource asked for real-world examples in AI Bots active on Discourse Powered Sites? . Moin pointed to Ask Discourse and noted Meta’s AI-bot availability model (and shared conversation links) in their answer , while Jagster prompted clarification on what “properly/completely” means in their reply . Related context about sharing bot threads appears in Share AI conversations via a public link .
OpenClaw agent integration + the llms.txt posting policy.
In the OpenClaw integration support thread Discourse接入Openclaw机器人 , pranciskus described a plugin exposing Discourse tools to an AI agent. sam emphasized the site’s automated-bot policy (including no posting ) and asked for compliance confirmation in the reminder . pranciskus confirmed newer versions read rules first in their follow-up , also linking details in OpenClaw plugin for Discourse integration .
AI spam detection: “test says SPAM” but it didn’t enter the review queue.
In Discourse AI - Spam detection , singi2016cn reported a mismatch between the spam test tool and moderation queue behavior. per1234 asked diagnostic questions and pointed to how to use the testing tool in their response . Moin then asked who performed the test post (and with what permissions) in their follow-up .
Translating AI outputs/UI: AI summaries translation request (Chinese).
singi2016cn asked how to translate the AI summary interface strings/content in How do I translate AI Summaries? . This fits into the broader translation theme raised in AI settings without descriptions result in no non-English information about the settings and the “fix broken strings, then translate in Crowdin” approach described in [AI语义搜索时出现missing %[count} value] 字样 (with the contribution path in Contributing translations to Discourse ).
UI polish: Suggested/Related underline indicator misalignment (AI-related tabs).
jack222 reported inconsistent underline positioning when toggling tabs in The underline indicator below the “Suggested” and “Related” tabs . awesomerobot noted changes were already in progress that should resolve it in their response .
Activity
sam shipped documentation and steered several threads toward pragmatic, maintainable admin workflows, publishing the new guide Managing AI credentials and recommending core automation (topic timers / logs) over AI in Creating a system to move topics based on given criteria such as a timestamp . They also pushed for UI improvements in Field alignment issues in LLM cost configuration in German and confirmed a genuine bug in Error popup when suggesting tags in topic already having tags . On policy and agents, they reiterated the “no automated posting” rule in Discourse接入Openclaw机器人 . They also contributed perspective on tokenizer precision in How to use AI models with custom tokenizers , suggested a feature direction for scanning delays in LLM and NSFW Content Detection Delay , and discussed reducing decision paralysis in model choice in Models that have reached their limit should appear in a faded color… . Finally, they encouraged opening focused topics for AI-bot adopters in Discourse AI - AI bot .
Moin drove multiple localization-and-UX reports, starting Field alignment issues in LLM cost configuration in German and raising translatability concerns in Why are “Required” and “Enum” hardcoded in AI tool parameter configuration? . They also answered “where can I see AI bots in action?” in AI Bots active on Discourse Powered Sites? , highlighted the absence of translatable descriptions in AI settings without descriptions result in no non-English information about the settings , and helped troubleshoot moderation/spam behavior by asking permission/context questions in Discourse AI - Spam detection . They also updated readers on improved string behavior pending translations in [AI语义搜索时出现missing %[count} value] 字样 .
jdc20181 outlined a detailed self-hosted moderation-log workflow and asked about AI-driven topic moves in Creating a system to move topics based on given criteria such as a timestamp , clarified constraints around variable ban lengths in their follow-up , and responded positively to structured-data suggestions (custom fields/templates) in their update .
Falco proposed a robust architecture for “expiration-driven” workflows—custom topic fields, sidebar-friendly filters, and automation hooks—in Creating a system to move topics based on given criteria such as a timestamp , then suggested post-workflow visualization via Kanban Board (and the referenced Kanban Board ). Their guidance also pointed readers toward forms via Introducing Experimental Form Templates and developer setup via Set up a local Discourse Development Environment .
Canapin provided a clear repro + recording for a confusing AI tagging UI error in Error popup when suggesting tags in topic already having tags and clarified why it was initially filed as “confusing but non-blocking” in their follow-up .
NateDhaliwal added extra behavioral detail to the AI tag suggestion issue (duplicate tags, vanishing-on-reload) in Error popup when suggesting tags in topic already having tags , helping distinguish UI state vs persisted state problems.
derek backed the idea that the LLM cost UI was too cramped and offered a concrete responsive design alternative in Field alignment issues in LLM cost configuration in German .
zogstrip quickly validated the localization bug report and moved toward addressing it in Why are “Required” and “Enum” hardcoded in AI tool parameter configuration? .
ThisSource asked for examples of “properly implemented” AI bots in AI Bots active on Discourse Powered Sites? and similarly sought implementation stories in the longer-running Discourse AI - AI bot .
Jagster pushed for clearer requirements/definitions around “complete” AI bot implementations in AI Bots active on Discourse Powered Sites? .
pranciskus described a Discourse+agent integration plugin (with read/write tools) in Discourse接入Openclaw机器人 and confirmed compliance behaviors (reading rules first) in their reply , with added details provided in OpenClaw plugin for Discourse integration .
singi2016cn raised two practical admin/operator questions: why spam-classified posts didn’t enter the review queue in Discourse AI - Spam detection (plus confirmation of the test behavior in the follow-up and user context in their later reply ), and how to localize AI summaries in How do I translate AI Summaries? .
per1234 helped troubleshoot spam scanning behavior, asking whether the admin test tool was used and pointing to the correct place to run it in Discourse AI - Spam detection .
jack222 reported a visual inconsistency in the AI-adjacent topic UI tabs in The underline indicator below the “Suggested” and “Related” tabs .
awesomerobot acknowledged the underline issue and noted ongoing work would address it in The underline indicator below the “Suggested” and “Related” tabs .
kuaza prompted discussion about communicating model limits and subscription upgrade paths in Models that have reached their limit should appear in a faded color, and when selected, the subscription can be upgraded .
Thanks for reading, and I’ll see you again next week!
