I don’t know if this exists. Is there any setting where TL_0 users can be limited to only posting or replying in one category or a group of categories?
I expect the answer is to go through all my Categories and under Security trash the “everyone” group and replace it with TL_1 can post and reply and see and TL_0 can only “see”. It’d be cool to be able to do this in reverse - an admin switch “Limit TL_0 to post in [these Categories]; Limit TL_0 to reply in [these Categories]” that overrode the “everyone” designation.
Not a big deal, but let me know if there is an efficient way to do this without paging through all my existing categories.
TL;DR:
My idea is to create a “New Users - Your First Post Goes Here” category so any spam account has to put their AI book-report or attempted stealth-link to a Viagara site in one place. This category would contain our ongoing “Introduce Yourself” topic, so ideally actual new users could “check in” before being allowed to post anywhere else on the site - I could set TL_1 requirement to just one reply or post in what is basically a “sandbox” category.
We’ve been having a lot of “trash” signups which are usually spammers, but sometimes they just make an account and then never come back. Discourse is great though and we can set it to clean up users with no-posts after a time period.
We also get a lot of signups that are using AI to post. These are likely spammers a lot of the time trying to build Trust as well, but our forum also does have meaningful discussion among people programming and interested in AI/LLM capabilities. Thus we get signups who are using the forum as a test ground to “pass the Turing Test” and some who might just be trolling. We have a rule that an AI account trying to fool people that it’s real is not allowed since an AI cannot agree to the CoC and can’t be moderated.
Right, that’s what I would intend. TL_0 can browse and read (just as an anonymous user could), but can only reply in the sandbox category, which has the one “introduce yourself” topic which replying to would trigger them to be TL_1 (set requirement to 1 reply plus the read/visit requirements) so their first post - whether genuine, or spam, or AI would be a lot easier to notice instead of them hiding it in an obscure thread.
That does sound better - set everyone to “see” public categories then post/reply requires TL_1 except for just TL_0 can reply in the sandboxed category.
포럼 전체적으로 오래된 주제에 대한 ‘번’ 처리(업)에 대한 인식이 다소 변했습니다. 조직적 지식의 보존과 해당 지식 베이스의 검색 용이성을 위한 모범 사례는 중복을 줄이는 방향으로 기울어지고 있습니다. 따라서 당신의 게시물은 원래 주제와 직접적으로 관련이 있으며, 이 주제를 찾아내 주셔서 감사합니다.
사실 그렇습니다. 그리고 새로운 사용자를 특정 카테고리(또는 카테고리들)에 샌드박싱(격리)하는 아이디어가 유용할 수 있습니다.
AND라고 생각합니다. (단, 저는 확신하지 못합니다)
즉, 모든 조건이 충족되어야 한다는 뜻입니다. 다만 이는 제 추측이며, 제가 틀렸다면 다른 분들이 수정해 주시기 바랍니다.
이 질문은 당신이 해당 포럼에 관리자 권한을 가지고 있다고 추측하여 답변할 수 있습니다. 관리자 권한으로 설정에 접근하면 신뢰 수준과 요구 조건을 무한정 조정할 수 있습니다.
또한 /admin/site_settings/category/all_results?filter=tl1%20requires 경로에서 사이트 설정의 프랑스어 설명을 확인할 수도 있습니다. 여기 Meta의 게시물들과 달리 AI로 번역되지 않았습니다(더 정확하다는 보장은 아니지만, 정확하지 않다면 알려주세요. 그러면 번역 플랫폼에 주석을 추가하여 누군가 개선하도록 하겠습니다).
위 예시처럼 설정된 모든 카테고리에서 방문객과 TL0 사용자는 읽기만 가능하고 게시할 수 없습니다. 소개 주제에 게시를 허용하려면 TL0 사용자에게 게시를 허용하는 카테고리가 필요합니다. TL0 사용자에게도 해당 주제에서 게시가 허용되므로, 다른 사용자에게 새 주제 생성을 허용하지 않는 것이 가장 좋다고 생각합니다.
즉, 이 카테고리에서는 trust_level_0에 대한 답글을 허용하되, 주제 생성은 허용하지 않습니다.
정확히 말씀드리면, 이 경우 “ouvrir”(열다)는 “participer”(참여하다)보다 훨씬 명확하지만, 여전히 모호합니다.
프랑스어에서는 주제를 열어서 읽을 수도 있고, 열어서 만들 수도 있기 때문입니다.
이 경우 "enter"는 생성이 아닌 읽기 열기를 의미하므로 “accéder”(접속하다)로 번역하겠습니다.
따라서 "TL1 requires topics entered"는 "TL1에는 접속한 주제가 필요합니다"로, 설명문은 "새 사용자가 신뢰 수준 1로 승급하려면 몇 개의 주제에 접속해야 하는가"로 번역하겠습니다.
번역이 때로는 어려운 작업이라는 것을 잘 알고 있습니다. 저도 사이트와 기타 문서를 번역하는 것이 오픈소스에 대한 제 최고의 기여이며, 특히 Discourse와 같은 포럼에서 사용자를 돕는 것도 제가 할 수 있는 일입니다.
