Discourse Assign provides the ability to assign topics and individual posts (both private and public) to a user or group.
Install Guide
This plugin is bundled with Discourse core. There is no need to install the plugin separately.
Features
Discourse Assign adds a “tag like” annotation on the topic list and topic header with the username of the assigned user.
It allows you to assign topics to users and list all of the assigned topics.
Also, user groups can be assigned to the topic. In that case, each group member will receive a notification. In group Interaction configuration, you can specify Who can assign this group. By default, is it set to nobody.
In addition to assign to specific topic, individual post can be assigned as well. This option is hidden under “…” (show more) post toolbar. When a post is assigned, information about that is included in the topic title. Also, first post contain link to assigned post.
assigns by staff mention if you would like mentions by a staff member of another staff member to assign a topic select this
unassign creates tracking post: out of the box when you unassign a topic a post is created in the stream to keep track of the fact it was unassigned, disable to remove the tracking post
assigns public : out of the box all assignments are hidden from non-staff, if you want non-staff to be able to see who owns which topic, enable this setting.
assign self regex if you would like to use a magic phrase to assign stuff to yourself add a regex here
assign other regex if you would like to restrict it so only mentions with a particular phrase are assigned to others add something here
unassign on close if a topic is closed it will automatically be silently unassigned
unassign on group archive when a message is archived unassign it, once it moves back to inbox reassign it.
reassign on open When a topic is opened reassign previously assigned users/groups
assigns user url path template to path that is used as a hyperlink for any user assigned tags.
assign mailer When to send notification email for assignments
remind assigns frequency` Frequency for reminding users about assigned topics.
max assigned topics Maximum number of topics that can be assigned to a user.
assign allowed on groups controls the list of groups you can assign to. When a topic is assigned to a group it shows up in the individual assign list for all group members. They are notified when this assignment happens.
enable assign status Add a customizable status field to every assignment.
assign statuses is a list of statuses available to each assignment. The first status is the default status applied to every new assignment.
Listing assigned topics
There are 2 ways of viewing assigned topics,
In topic list format:
https://sitename.com/latest?assigned=username to view all assigned topics for a user
https://sitename.com/latest?assigned=* to view all assigned topics for all users
https://sitename.com/latest?assigned=me to view all assigned to current user
https://sitename.com/latest?assigned=nobody to view all unassigned
The user page activity there is an extra assigned tab visible to staff on activity and messages tabs
Dies scheint derzeit nicht zu funktionieren. Wenn ich Teil der Gruppe A bin und jemand Gruppe A einem Thema zuweist, wird es mir nicht angezeigt, wenn ich /latest?assigned=me besuche.
Gibt es eine Möglichkeit, die Zeit für wiederkehrende Benachrichtigungen zu konfigurieren?
UPD: Wenn ein Thema einer Gruppe zugewiesen wird, erhalten die Benutzer in der Gruppe keine E-Mail-Benachrichtigungen. Ist das korrekt? Ich hatte erwartet, dass Benutzer E-Mails und wiederkehrende E-Mails (täglich, wöchentlich) wie bei einem einzelnen zugewiesenen Benutzer erhalten.
Entschuldigung, falls das bereits erwähnt wurde (ich konnte es nicht finden).
Können Nicht-Mitarbeiter dieses Plugin zur Zuweisung verwenden? Ich konnte dieses Plugin nicht zum Laufen bringen, selbst wenn der Benutzer Moderator ist. Der Benutzer muss Administrator sein.
Mein Anwendungsfall: Ein Teamleiter (kein Mitarbeiter/kein Administrator) schreibt ein Thema und weist es einem Teammitglied (TL0-3-Benutzer) zu. Der Teamleiter ist nicht unbedingt der Website-Administrator oder Mitarbeiter für das Discourse-Forum, da wir viele Teamleiter haben.
Es wäre hilfreich, wenn ich den Teamleiter zum Moderator machen und dieses Plugin zum Laufen bringen könnte.
Daher müssten Sie, mit diesen Worten, trust_level_0 wie von @Moin vorgeschlagen einstellen. Ich denke, es wäre zu erwarten, dass es ansonsten funktioniert, wenn Sie „alle“ auswählen, also ist dies vielleicht ein Fehler?
Wie kann ich die E-Mail-Vorlage finden und bearbeiten, die gesendet wird, wenn jemand zugewiesen wird? Sie existiert nicht zusammen mit den anderen E-Mail-Vorlagen?
Du findest ihn unter Admin > Seitentexte. Ich habe nach assign_mailer gesucht, was den Titel (assign_mailer.subject_template) und den Textkörper (assign_mailer.text_body_template) zurückgibt.
Ja, aber das wird erst angezeigt, wenn Sie eine Änderung vornehmen. Es gibt keine visuelle Anzeige, dass überhaupt ein Status zugewiesen wurde, bis Sie ihn von X auf Y ändern.
Sie meinen „Aufgaben bearbeiten“, die sich hinter der Schaltfläche „Zuweisung aufheben…“ verbirgt.
Wenn ich es nicht aufheben möchte, würde ich zögern, auf diese Schaltfläche zu klicken, oder?
Das ist unintuitiv.
Sagen Sie damit, dass Sie nicht der Meinung sind, dass eine visuelle Anzeige, die Ihnen zeigt, wie der zugewiesene Status eines Themas offen sichtbar ist, eine gute Idee ist?
Ich kann mir einfach nicht vorstellen, dass es vom Code her eine große Herausforderung ist, und es ist einfach sinnvoll, es offen zugänglich zu machen.
